path: root/sound/pci
2008-09-02ALSA: hda - Add mic-boost controls to ALC662/663 auto configurationTakashi Iwai
2008-09-02ALSA: hda - Fix ALC663 auto-probeTakashi Iwai
Fix the wrong DAC assignment for NID 0x17 mono-pin on ALC663. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-01ALSA: hda: Distortion fix for dell_m6_core_initMatthew Ranostay
Added the EQ distortion fix to the dell_m6_core_init. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-29ALSA: oxygen: fix distorted output on AK4396-based cardsClemens Ladisch
When changing the sample rate, the CMI8788's master clock output becomes unstable for a short time. The AK4396 needs the master clock to do SPI writes, so writing to an AK4396 control register directly after a sample rate change will garble the value. In our case, this leads to the DACs being misconfigured to I2S sample format, which results in a wrong output level and horrible distortions on samples louder than -6 dB. To fix this, we need to wait until the new master clock signal has become stable before doing SPI writes. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-27Revert "ALSA: hda - Added model selection for iMac 24""Takashi Iwai
This reverts commit 3e0e469fa216ec70c93b1593821b759d19ee2e6b. The patch introduced a wrong detection of other intel Macs with ALC88* codec because they share the same PCI SSID (but have different codec subsystem-IDs). See http://lkml.org/lkml/2008/8/24/143 Reported-and-tested-by: Guillaume Chazarain <guichaz@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-26ALSA: oxygen: prevent muting of nonexistent AC97 controlsClemens Ladisch
The Xonar DX does not have CD Capture controls, so we have to check that a control actually exists before muting it. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-25ALSA: fix for CA0106 on MSI K8N Diamond PLUS MotherboardStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-25ALSA: CA0106 on MSI K8N Diamond PLUS MotherboardTravis Place
Correct a previous patch for the ca0106 onboard the MSI K8N Diamond PLUS motherboard. Confirmed to have Line/Mic/Aux working for input, and sound output working as expected. Signed-off-by: Travis Place <wishie@wishie.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-22ALSA: hda - Fix call of alc888_coef_init()Takashi Iwai
Using init_hook to call alc888_coef_init() is problematic for configurations that already set another init_hook. Better to put it in alc_init() as is (although it looks a bit hackish). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-21ALSA: hda_intel: enable snoop for nvidia HDA controllerPeer Chen
Enable the snoop for nvidia hda controller to avoid data coherence issue. Signed-off-by: Peer Chen <peerchen@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-17ALSA: hda - Fix capture source widgets on ALC codecsTakashi Iwai
On some Realtek codecs like ALC882 or ALC883, the capture source is no mux but sum widget. We have to initialize all channels properly for this type, otherwise noises may come in from the unused route. The patch assures to mute unused routes, and unmute the currently selected route. Signed-off-by: Takashi Iwai <tiwai@suse.de> Tested-by: Daniel J Blueman <daniel.blueman@gmail.com>
2008-08-14ALSA: virtuoso: add Xonar D1 supportClemens Ladisch
Add support for the Asus Xonar D1. It is the same as the DX, but without the external power detection. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-12ALSA: hda - support new AMD HDMI Audio (1002:970f)Libin Yang
Signed-off-by: Libin Yang <libin.yang@amd.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-12ALSA: hda_intel: ALSA HD Audio patch for Intel Ibex Peak DeviceIDsSeth Heasley
This patch adds the Intel Ibex Peak (PCH) HD Audio Controller DeviceIDs. Signed-off by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-27ALSA: Allow to force model to intel-mac-v3 in snd_hda_intel (sigmatel).Nicolas Boichat
Currently, even if you pass model=intel-mac-v3 as a module parameter to snd_hda_intel, the function patch_stac922x (patch_sigmatel.c) will still try to auto-detect the model type. This is a problem on my MacBook Pro 1st generation, which needs intel-mac-v3, but sometimes incorrectly reports 0x00000100 as subsystem id, which causes the switch in patch_stac922x to select intel-mac-v4. To fix this, I added a new model called intel-mac-auto, so in case no module parameter is passed, and an Intel Mac board is detected, the model will be automatically detected, while no detection will be done if the model is forced to intel-mac-v3. This problem has been around for quite a while, and I used to fix it by moving the case statement for 0x00000100 in patch_stac922x so that intel-mac-v3 is chosen. Another way to fix the problem would be to check if a module parameter was set directly in patch_stac922x, using something like this: if (spec->board_config == STAC_INTEL_MAC_V3 && !codec->bus->modelname) { But I think it is less elegant (if you prefer that way, I can prepare a patch). Signed-off-by: Nicolas Boichat <nicolas@boichat.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-27ALSA: hda - Add automatic model setting for the Acer Aspire 5920G laptopTravis Place
Make the Acer Aspire 5920G (1025:0121) select ALC883_ACER_ASPIRE by default. Signed-off-by: Travis Place <wishie@wishie.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-27ALSA: make snd_ac97_add_vmaster() staticAdrian Bunk
This patch makes the needlessly global snd_ac97_add_vmaster() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-27ALSA: sound/pci/azt3328.h: no variables for enumsAdrian Bunk
AZF_FREQUENCIES and AZF_GAME_CONFIGS were variables, and this doesn't seem to have been intended. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-18ALSA: hda - Add support of ASUS Eeepc P90*Kailang Yang
- Support ASUS_P900A = P703 - Support ASUS_P901 Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-17ALSA: hda - Added support for Asus V1SnAlexander Holler
Added the necessary ID for Asus V1Sn to patch_realtek.c to use ALC861VD_LENOVO on these laptops. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-17ALSA: ALSA: ens1370: communicate PCI device to AC97Rene Herman
communicate the ES137x PCI device to the AC97 code for its subsys_vendor/device values Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-17ALSA: ens1370: SRC stands for Sample Rate ConverterRene Herman
2008-07-16ALSA: hda - Align BDL position adjustment parameterTakashi Iwai
It seems NVidia and other hardwares require the alignment for period update timing. For satisfying this condition, align the position adjustment for delayed wake-up to the initial bdl_pos_adj value. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-07-15ALSA: add TriTech 28023 AC97 codec ID and Wolfson 9701 name.Rene Herman
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-14ALSA: correct kcalloc usageMilton Miller
kcalloc is supposed to be called with the count as its first argument and the element size as the second. Both arguments are size_t so does not affect correctness. This callsite is during module_init and therefore not performance critical. Another patch will optimize the case when the count is variable but the size is fixed. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda - Fix FSC V5505 modelTakashi Iwai
model=laptop-hpmicsense matches better to FSC V5505 laptop. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda - Fix missing init for unsol events on micsense modelTakashi Iwai
Fixed the missing initialization for unsolicited events on Cx5045 micsense model. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda - Fix internal mic vref pin setupTakashi Iwai
Set the vref80 to the internal mic pin 0x12 for Cx5045. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: hda: 92hd71bxx PC BeepMatthew Ranostay
Added volume controls for the analog PC Beep on 92hd71bxx codecs. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10firmware: convert ymfpci driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10firmware: convert maestro3 driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10firmware: convert korg1212 driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10Fix a const pointer usage warning in the Digigram miXart soundcard driverDavid Howells
Fix a const pointer usage warning in the Digigram miXart soundcard driver. A const pointer is being passed to copy_from_user() to load the firmware into. This is okay in this case because the function has allocated the firmware struct itself, but the const qualifier is part of the firmware struct - so the patch casts the const away. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10Fix a const pointer usage warning in the Digigram pcxhr soundcard driverDavid Howells
Fix a const pointer usage warning in the Digigram pcxhr compatible soundcard driver. A const pointer is being passed to copy_from_user() to load the firmware into. This is okay in this case because the function has allocated the firmware struct itself, but the const qualifier is part of the firmware struct - so the patch casts the const away. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-10ymfpci: treat firmware data as constDavid Woodhouse
Standardise both in-kernel and loaded firmware to be stored as little-endian instead of host-endian. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10maestro3: treat firmware data as constDavid Woodhouse
The maestro3 driver is byte-swapping its firmware to be host-endian in advance, when it doesn't seem to be necessary -- we could just use le16_to_cpu() as we load it. Doing that means that we need to switch the in-tree firmware to be little-endian too. Take the least intrusive way of doing this, which is to switch the existing snd_m3_convert_from_le() function to convert _to_ little-endian instead, and use it on the in-tree firmware instead of the loaded firmware. It's a bit suboptimal but doesn't matter much right now because we're about to remove the special cases for the in-tree version anyway. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-07-10pcxhr: treat firmware data as constDavid Woodhouse
2008-07-10riptide: treat firmware data as constDavid Woodhouse
2008-07-10vx222: treat firmware data as constDavid Woodhouse
2008-07-10ALSA: HDA - HP dc7600 with pci sub IDs 0x103c/0x3011 belongs to hp-3013 modelJaroslav Kysela
As reported and tested by an RedHat customer, HP dc7600 with pci sub IDs 0x103c/0x3011 works with the hp-3013 model and not with the hp only model. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: hda - removed redundant gpio_maskMatthew Ranostay
An gpio_mask value was defined twice needlessly. Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: hda - Add support for Lenovo 3000 N200Takashi Iwai
Added the model entry (model=lenovo) for Lenovo N3000 N200 laptop with ALC861-VD. Reference below: https://bugzilla.novell.com/show_bug.cgi?id=406425 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: ac97 - fix patch_ucb1400 for proper resumeMike Rapoport
Replace 'snd_ac97_write' with snd_ac97_write_cache' in pacth_ucb1400 to allow proper codec wakeup. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: ALSA: hda - Fix speaker output on Toshiba P105Takashi Iwai
Toshiba Satellite P105 with cx5045 has no HP pin but only a speaker pin and does the speaker-muting on hardware. Thus the matching model is laptop-micsense. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: hda - Add missing Thinkpad Z60m supportTakashi Iwai
Added the missing SSID of Thinkpad Z60m for model=thinkpad with AD1981HD. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: ALSA: hda - Fix ALC883 medion modelTakashi Iwai
ALC883 medion model doesn't unmute the proper amps so no output can be heard. Replaced the mute switches to behave just like other models. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: Fix AC97 power downTakashi Iwai
Some laptops don't like PR3 powerdown. Do PR3 powerdown only for the real power-saving. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: via82xx - Add VIA audio device #1841 to ac97_quirk listWalter Sheets
Signed-off-by: Walter Sheets <w41ter@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-27ALSA: hda - disable amp override on non-HP machinesTakashi Iwai
Some machines with Cx5045 seem to have no problem with the volume over 0dB on NID 0x17. Disable amp overrides for other devices but HP. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
