commit 9c77b846ec8b4e0c7107dd7f820172462dc84a61 upstream.
BugLink: https://bugs.launchpad.net/bugs/619439
This ThinkPad model needs External Amplifier muted for audible playback,
so set the inv_eapd quirk for it.
Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit c3e68fad88143fd1fe8fe640207fb19c0f087dbc upstream.
model=dell-vostro is needed for Dell Vostro 1220 with Coexnat 5067.
Reference: Novell bnc#631066
https://bugzilla.novell.com/show_bug.cgi?id=631066
commit 53bacfbbb2ddd981287b58a511c8b8f5df179886 upstream.
I discovered tonight that ALSA no longer sets up a stream for the second ADC
provided by the Realtek ALC260 HDA codec. At some point alc_build_pcms()
started using stream_analog_alt_capture when constructing the second ADC
stream, but patch_alc260() was never updated accordingly. I have no idea
when this regression occurred. The trivial patch to patch_alc260() given
below fixes the problem as far as I can tell. The patch is against 2.6.35.
Signed-off-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au>
commit 56385a12d9bb9e173751f74b6c430742018cafc0 upstream.
With some hardware combinations, the PCM interrupts are acknowledged
before the period boundary from the emu10k1 chip. The midlevel PCM code
gets confused and the playback stream is interrupted.
It seems that the interrupt processing shift by 2 samples is enough
to fix this issue. This default value does not harm other,
non-affected hardware.
More information: Kernel bugzilla bug#16300
[A copmile warning fixed by tiwai]
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit a5ba6beb839cfa288960c92cd2668a2601c24dda upstream.
The detection and loading of firmeware on riptide driver has been broken
due to rewrite of some codes, checking the presense wrongly.
This patch fixes the logic again.
Reference: kernel bug 16596
https://bugzilla.kernel.org/show_bug.cgi?id=16596
commit 38faddb1afdd37218c196ac3db1cb5fbe7fc9c75 upstream.
The behavior of Nvidia HDMI codec regarding the pin-detection unsol events
is based on the old HD-audio spec, i.e. PD bit indicates only the update
and doesn't show the current state. Since the current code assumes the
new behavior, the pin-detection doesn't work relialby with these h/w.
This patch adds a flag for indicating the old spec, and fixes the issue
by checking the pin-detection explicitly for such hardware.
Tested-by: Wei Ni <wni@nvidia.com>
commit ac0547dc62e67a3e0b0c1628b6e49efba8f517db upstream.
Many codecs now clear the pin controls at suspend via snd_hda_shutup_pins()
for reducing the click noise at power-off. But this leaves some pins
uninitialized, and they'll be never recovered after resume.
This patch adds the proper recovery of cleared pin controls on resume.
Also it adds a check of bus->shutdown so that pins won't be cleared at
module unloading.
Reference: Kernel bug 16339
http://bugzilla.kernel.org/show_bug.cgi?id=16339
commit 3bfea98ff73d377ffce0d4c7f938b7ef958cdb35 upstream.
BugLink: https://bugs.launchpad.net/bugs/463178
Set Macbook 5,2 (106b:4a00) hardware to use ALC885_MB5
Signed-off-by: Luke Yelavich <luke.yelavich@canonical.com>
commit fbe618f216830f47b183858c3380d4767b1ad02f upstream.
With multiple codec configurations, some codec might have no ADC, thus
it keeps spec->adc_nids = NULL. This causes an Oops in alc_build_controls().
Reference: kernel bug #16156
https://bugzilla.kernel.org/show_bug.cgi?id=16156
commit 9f75c1b12c5ef392ddcea575b13560842c28b1b3 upstream.
BugLink: https://launchpad.net/bugs/587546
Symptom: On the reporter's ASUS M2V, using PulseAudio in Ubuntu 10.04 LTS
results in the PA daemon crashing shortly after attempting playback of an
audio file.
Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or
Linux 2.6.34, attempt playback of an audio file while PulseAudio is
active.
Resolution: add SSID for this machine to the position_fix quirk table,
explicitly specifying the LPIB method.
Reported-and-Tested-By: D Tangman
commit b90c076424da8166797bdc34187660fd0124f530 upstream.
BugLink: https://launchpad.net/bugs/580749
Symptom: on the original reporter's VIA VT1708-based board, the
PulseAudio daemon dies shortly after the user attempts to play an audio
file.
Test case: boot from Ubuntu 10.04 LTS live cd; attempt to play an audio
file.
Resolution: add SSID for the original reporter's hardware to the
position_fix quirk table, explicitly specifying the LPIB method.
Reported-and-Tested-By: Harald
commit 26fd74fc01991a18f0e3bd54f8b1b75945ee3dbb upstream.
BugLink: https://launchpad.net/bugs/542550
Symptom: On the reporter's iMac, in Ubuntu 10.04 LTS neither playback
nor capture appear audible out-of-the-box.
Test case: Boot from an Ubuntu 10.04 LTS live cd or from an installed
configuration and attempt to play or capture audio.
Resolution: Specify the mb31 quirk for this machine in the codec SSID
table.
Reported-and-Tested-By: f3a97
commit dd37f8e8659bc617c3f2a84e007a4824ccdac458 upstream.
BugLink: https://launchpad.net/bugs/465942
Symptom: On the reporter's ASUS device, using PulseAudio in Ubuntu 10.04
LTS results in the PA daemon crashing shortly after attempting to select
capture or to configure the audio hardware profile.
Linux 2.6.34, adjust the HDA device's capture volume with PulseAudio.
Reported-and-Tested-By: Irihapeti
commit 61bb42c37dfa9016dcacc86bcd41362ab2457d4a upstream.
BugLink: https://launchpad.net/bugs/551949
Symptom: On the reporter's Shuttle device, using PulseAudio in Ubuntu
10.04 LTS results in "popping clicking" audio with the PA crashing
shortly thereafter.
Linux 2.6.34, adjust the HDA device's volume with PulseAudio.
Reported-and-Tested-By: Christian Mehlis <mehlis@inf.fu-berlin.de>
commit e96d3127760a2fc509bca6bf7e61e8bc61497aeb upstream.
BugLink: https://launchpad.net/bugs/586347
Symptom: On the Sony VPCS11V9E, using GStreamer-based applications with
PulseAudio in Ubuntu 10.04 LTS results in stuttering audio. It appears
to worsen with increased I/O.
Test case: use Rhythmbox under increased I/O pressure. This symptom is
reproducible in the current daily stable alsa-driver snapshots (at least
up until 21 May 2010; later snapshots fail to build from source due to
missing preprocessor directives when compiled against 2.6.32).
Reported-and-Tested-By: Lauri Kainulainen <lauri@sokkelo.net>
commit 7a68be94e22e7643038726ebc14360752a91800b upstream.
BugLink: https://launchpad.net/bugs/583983
Symptom: on a significant number of hardware, booting from a live cd
results in capture working correctly, but once the distribution is
installed, booting from the install results in capture not working.
Test case: boot from Ubuntu 10.04 LTS live cd; capture works correctly.
Install to HD and reboot; capture does not work. Reproduced with 2.6.32
mainline build (vanilla kernel.org compile).
Resolution: add SSID for Acer Aspire 5110 to the position_fix quirk
I'll be sending additional patches for these SSIDs as bug reports are
confirmed.
Reported-and-Tested-By: Leo
commit 4e0938dba7fccf37a4aecba4d937da7f312b5d55 upstream.
BugLink: https://launchpad.net/bugs/549560
Resolution: add SSID for Toshiba A100-259 to the position_fix quirk
confirmed.
This patch also trivially sorts the quirk table in ascending order by
subsystem vendor.
Reported-and-Tested-by: <davide.molteni@gmail.com>
commit 66668b6fb6861fad7f6bfef6646ac84693474c9a upstream.
BugLink: https://launchpad.net/bugs/576160
Symptom: Currently (2.6.32.12) the Dell M1730 uses the 3stack model
quirk. Unfortunately this means that capture is not functional out-
of-the-box despite ensuring that capture settings are unmuted and
raised fully.
Test case: boot from Ubuntu 10.04 LTS live cd; capture does not
work.
Resolution: Correct the model quirk for Dell M1730 to rely on the
BIOS configuration.
This patch also trivially sorts the quirk into the correct section
based on the comments.
Reported-and-Tested-By: <picdragon99@msn.com>
Tested-By: Daren Hayward
Tested-By: Tobias Krais
The capture source control of maya44 was wrongly coded with the bit
shift instead of the bit mask. Also, the slot for line-in was
wrongly assigned (slot 5 instead of 4).
Reported-by: Alex Chernyshoff <alexdsp@gmail.com>
Cc: <stable@kernel.org>
Commit 65c3ac885ce9852852b895a4a62212f62cb5f2e9 in 2.6.33 accidentally
left out the initialization of the AC97 codec FMIC2MIC bit, which broke
recording from the front panel microphone.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
It turned out that HP dv series have inconsistent the mute-LED GPIO
mapping among various models. dv4/7 seem to use GPIO 0 while dv 5/6
seem to use GPIO 3. The previous commit
26ebe0a28986f4845b2c5bea43ac5cc0b9f27f0a
ALSA: hda - Fix mute-LED GPIO pin for HP dv series
breaks dv5/6.
This patch adds the new quirk model, hp-dv4, to handle HP dv4/7
separately from HP dv5/6.
Tested-by: Kunal Gangakhedkar <kunal.gangakhedkar@gmail.com> (for dv6-1110ax)
Acked-by: Kunal Gangakhedkar <kunal.gangakhedkar@gmail.com>
Old HP dv series seem to use the GPIO pin 0 for controlling the mute LED
although the pin is a large package, where the newer models use GPIO 3
in such a case. For fixing the regression from the previous kernels,
set spec->gpio_led statically for these model quirks.
Reference: http://mailman.alsa-project.org/pipermail/alsa-devel/2010-May/027525.html
As reported on the mailing list, we also need to cap to the 0 dB offset
for Lenovo models, else the sound will be distorted.
Reported-and-Tested-by: Tim Starling <tstarling@wikimedia.org>
This reverts commit 7aee67466536bbf8bb44a95712c848a61c5a0acd.
As it doesn't seem to be universally valid for all mainboard revisions of
the D945GCLF2 and breaks snd-hda-intel/ snd-hda-codec-realtek on the Intel
Corporation "D945GCLF2" (LF94510J.86A.0229.2009.0729.0209) mainboard.
00:1b.0 Audio device [0403]: Intel Corporation N10/ICH 7 Family High Definition Audio Controller [8086:27d8] (rev 01)
Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Cc: <stable@kernel.org> [2.6.33]
Ideapad quirks working for my ThinkPad X100e (microphone is not tested).
Signed-off-by: Andrej Gelenberg <andrej.gelenberg@udo.edu>
This reverts part of commit 52dc438606d1e, in order to fix a regression:
broken SPDIF output on Intel DG45FC motherboard (IDT 92HD73E1X5 codec).
--- DG45FC-IDT-codec-2.6.32 (SPDIF OK)
+++ DG45FC-IDT-codec-2.6.33 (SPDIF broken)
Node 0x22 [Pin Complex] wcaps 0x400301: Stereo Digital
Pincap 0x00000010: OUT
- Pin Default 0x40f000f0: [N/A] Other at Ext N/A
- Conn = Unknown, Color = Unknown
- DefAssociation = 0xf, Sequence = 0x0
- Pin-ctls: 0x00:
+ Pin Default 0x014510a0: [Jack] SPDIF Out at Ext Rear
+ Conn = Optical, Color = Black
+ DefAssociation = 0xa, Sequence = 0x0
+ Pin-ctls: 0x40: OUT
Connection: 3
0x25* 0x20 0x21
Node 0x23 [Pin Complex] wcaps 0x400301: Stereo Digital
- Pin Default 0x01451140: [Jack] SPDIF Out at Ext Rear
+ Pin Default 0x074510b0: [Jack] SPDIF Out at Ext Rear Panel
- DefAssociation = 0x4, Sequence = 0x0
- Misc = NO_PRESENCE
- Pin-ctls: 0x40: OUT
+ DefAssociation = 0xb, Sequence = 0x0
+ Pin-ctls: 0x00:
Connection: 3
0x26* 0x20 0x21
Cc: Alexey Fisher <bug-track@fisher-privat.net>
Tested-by: David Härdeman <david@hardeman.nu>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
BugLink: https://launchpad.net/bugs/541802
The OR's hardware distorts at PCM 100% because it does not correspond to
0 dB. Fix this in patch_cxt5045() for all Packard Bell models.
Reported-by: Valombre
Add a quirk for all-in-one computer Dell Inspiron One 19 Touch to have proper
HP and Mic support.
Signed-off-by: Anisse Astier <anisse@astier.eu>
BugLink: https://launchpad.net/bugs/549267
The OR verified that using the olpc-xo-1_5 model quirk allows the
headphones to be audible when inserted into the jack. Capture was
also verified to work correctly.
Reported-by: Richard Gagne
Tested-by: Richard Gagne
BugLink: https://launchpad.net/bugs/573284
Reported-by: Andy Couldrake <acouldrake@googlemail.com>
Tested-by: Andy Couldrake <acouldrake@googlemail.com>
This fixes a problem where cards show up as only having a single mixer
element, suppressing all sound output.
Signed-off-by: Brian J. Tarricone <brian@tarricone.org>
BugLink: https://launchpad.net/bugs/568600
The OR has verified that the dell-m6 model quirk is necessary for audio
to be audible by default on the Dell Studio XPS 1645.
This change is necessary for 2.6.32.11 and 2.6.33.2 alike.
Reported-by: Andy Ross <andy@plausible.org>
Tested-by: Andy Ross <andy@plausible.org>
BugLink: https://launchpad.net/bugs/459083
The OR has verified with 2.6.32.11 and the latest alsa-driver stable
daily snapshot that position_fix=1 is necessary for the external mic
to work and for PulseAudio not to crash constantly.
This patch is necessary also for 2.6.32.11 and 2.6.33.2.
Reported-by: <imwithid@yahoo.com>
Tested-by: <imwithid@yahoo.com>
Ignore spurious HV interrupts during suspend / resume, this avoids
mistaking them for a mute button press. This is not very pretty but
it seems the only way to fix the master volume control gets muted
after suspend issue I'm seeing. Note that the es1968 driver is doing
exactly the same.
Without this quirk sound stops working after suspend resume. With this quirk,
one still needs to manually unmute the master volume control after a suspend /
/ resume cycle. That is fixed in another patch in this set.
Note that this patch was submitted to the alsa bug tracker a long time ago:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4319
CC: <stable@kernel.org>
BugLink: https://launchpad.net/bugs/567494
The OR has verified that the existing model quirk, ALC880_UNIWILL,
is insufficient for audible playback and capture by default. Instead,
the ALC880_F1734 model quirk needs to be used.
This change is necessary for both 2.6.32.11 and 2.6.33.2.
Reported-by: Arnaud Malpeyre <amalpeyre@gmail.com>
Tested-by: Arnaud Malpeyre <amalpeyre@gmail.com>
BugLink: https://launchpad.net/bugs/553002
Reported-by: Robert Chambers
Tested-by: Robert Chambers
When HP laptop with AD1981 codec is suspended and the docking-station
is connected before the resume, the outputs get confused, and wrongly
routed still to the speaker. This is because of a change in 2.6.34-rc1
ea52bf260ecbb175339af3178c15788df21b7516
ALSA: hda: Add powerdown for Analog Devices HDA codecs
The problem was the added resume callback that doesn't consider the
modified init hook. The fix is simply remove the resume callback here
and make the resume normally. This doesn't change any behavior intended
in the commit above (for shutting down the sound at suspend) but only
fixes the resume.
Reported-and-tested-by: Frans Pop <elendil@planet.nl>
The Biostar mobo seems to give a wrong DMA position, resulting in
stuttering or skipping sounds on 2.6.34. Since the commit
7b3a177b0d4f92b3431b8dca777313a07533a710, "ALSA: pcm_lib: fix "something
must be really wrong" condition", makes the position check more strictly,
the DMA position problem is revealed more clearly now.
The fix is to use only LPIB for obtaining the position, i.e. passing
position_fix=1. This patch adds a static quirk to achieve it as default.
Reported-by: Frank Griffin <ftg@roadrunner.com>
Cc: Eric Piel <Eric.Piel@tremplin-utc.net>
Added the matching model for Clevo laptop M570U.
Signed-off-by: Joerg Schirottke <master@kanotix.com>
Tested-by: Maximilian Gerhard <maxbox@directbox.com>
Some VIA codecs have no multiple source selection for headphone pins,
thus it's useless (and wrong) to create "Independent HP" control on them.
This patch adds the check of connections to skip the control in such a
case.
The commit 5b0cb1d850c26893b1468b3a519433a1b7a176be
ALSA: hda - add more NID->Control mapping
breaks the control element allocation by returning a wrong value.
Let's fix it.
Sony VAIO models with ALC269 need to initialize the pin 0x19 to VREF
ground or Hi-Z to make the headphone working. Other than that, model=auto
works fine, so let's use model=auto with a specific fix-up table.
A few enhancement / fixes for fix-up table of some Realtek codecs:
- Apply fix-ups only for the auto model
- Apply additional verbs after normal init verbs
- Add a debug print to show the fix-up application
This is basically a preliminary work for the next fix for Sony VAIO.
The widget connections of ADC of ALC880 and ALC2260 aren't initialized,
thus it might point to invalid pin. This can be a problem when mode=auto
and there is only one input pin. Then user can't change the connection
at all.
This patch adds the code to initialize the input pin connection of these
codecs.
Reference: Novell bnc#594363
https://bugzilla.novell.com/show_bug.cgi?id=594363
