The drivers don't require the exclusive irqs. Let's fix the deprecated
warnings.
Make declarations of struct pcmcia_device_id const.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
pcmcia_enable_device() now replaces pcmcia_request_configuration().
Instead of config_req_t, all necessary flags are either passed as
a parameter to pcmcia_enable_device(), or (in rare circumstances)
set in struct pcmcia_device -> flags.
With the last remaining user of include/pcmcia/cs.h gone, remove
all references.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-ide@vger.kernel.org
CC: linux-usb@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: alsa-devel@alsa-project.org
CC: linux-serial@vger.kernel.org
CC: Jiri Kosina <jkosina@suse.cz>
CC: linux-scsi@vger.kernel.org
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth)
Several drivers prefer to explicitly set config_{base,index,regs},
formerly known as ConfigBase, ConfigIndex and Present. Instead of
passing these values inside config_req_t, store it in struct
pcmcia_device.
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO
(all other drivers). As this flags seems to relate to ioport access, make
it conditional to the driver having requested IO port access. There are two
drivers which do not request IO ports, but did set INT_MEMORY_AND_IO:
ray_cs and b43. For those, we consistently only set INT_MEMORY in future.
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
CC: Michael Buesch <mb@bu3sch.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
After pcmcia_request_io(), do not make use of the values stored in
io_req_t, but instead use those found in struct pcmcia_device->resource[].
dev_node_t was only used to transport some minor/major numbers
from the PCMCIA device drivers to deprecated userspace helpers.
However, only a few drivers made use of it, and the userspace
helpers are deprecated anyways. Therefore, get rid of dev_node_t .
As a first step, remove any usage of dev_node_t from drivers which
only wrote to this typedef/struct, but did not make use of it.
CC: linux-bluetooth@vger.kernel.org
CC: Harald Welte <laforge@gnumonks.org>
Instead of the old pcmcia_request_irq() interface, drivers may now
choose between:
- calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq.
- use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will
clean up automatically on calls to pcmcia_disable_device() or
device ejection.
- drivers still not capable of IRQF_SHARED (or not telling us so) may
use the deprecated pcmcia_request_exclusive_irq() for the time
being; they might receive a shared IRQ nonetheless.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Most of the irq_req_t typedef'd struct can be re-worked quite
easily:
(1) IRQInfo2 was unused in any case, so drop it.
(2) IRQInfo1 was used write-only, so drop it.
(3) Instance (private data to be passed to the IRQ handler):
Most PCMCIA drivers using pcmcia_request_irq() to actually
register an IRQ handler set the "dev_id" to the same pointer
as the "priv" pointer in struct pcmcia_device. Modify the two
exceptions (ipwireless, ibmtr_cs) to also work this waym and
set the IRQ handler's "dev_id" to p_dev->priv unconditionally.
(4) Handler is to be of type irq_handler_t.
(5) Handler != NULL already tells whether an IRQ handler is present.
Therefore, we do not need the IRQ_HANDLER_PRESENT flag in
irq_req_t.Attributes.
CC: Jaroslav Kysela <perex@perex.cz>
CC: Karsten Keil <isdn@linux-pingi.de>
for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org>
Update remaining users and remove deprecated handle_to_dev() macro
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of
requiring manual settings of PCMCIA_DEBUG.
Also, remove all usages of the CS_CHECK macro and replace them with proper
Linux style calling and return value checking. The extra error reporting may
be dropped, as the PCMCIA core already complains about any (non-driver-author)
errors.
Convert from snd_card_new() to the new snd_card_create() function
in other sound subdirectories.
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
It seems noone ever tried to use this driver with more than one device.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Mark TLV data as 'const'
Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost
all PCMICA driver right at the beginning, using the same calls but slightly
different implementations. Unfiy this in the PCMCIA core.
Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused
label") from and Signed-off-by Adrian Bunk <bunk@stusta.de>
Added the dB scale information to vxpocket and vx222 drivers.
Deprecated snd_card_free_in_thread(), replaced with
snd_card_free_when_closed().
Fix a typo of return value from vxpocket_config().
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present().
Instead of the two status values struct pcmcia_device->p_state and state,
use descriptive bitfields. Most value-checking in drivers was invalid, as
the core now only calls the ->remove() (a.k.a. detach) function in case the
attachement _and_ configuration was successful.
Most of the driver initialization isn't done in the .probe function, but in
the internal _config() functions. Make them return a value, so that .probe
can properly report whether the probing of the device succeeded or not.
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now.
Therefore, remove all such indirections.
Embed dev_link_t into struct pcmcia_device(), as they basically address the
same entity. The actual contents of dev_link_t will be cleaned up step by step.
This patch includes a bugfix from and signed-off-by Andrew Morton.
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and
Vpp2 can only be set to the same value, a lot of code can be
streamlined.
In all but one case, the suspend and resume functions of PCMCIA drivers
contain mostly of calls to pcmcia_release_configuration() and
pcmcia_request_configuration(). Therefore, move this code out of the
drivers and into the core.
Convert the remaining drivers which use pcmcia_release_io or
pcmcia_release_irq, and remove the EXPORT of these symbols.
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary
cleanups upon device or driver removal: it calls the appropriate
pcmcia_release_* functions, and can replace (most) of the current drivers'
_release() functions.
Update the PCMCIA sound drivers to handle the recent changes to the PCMCIA
core. A part of this merge was done by Takashi Iwai <tiwai@suse.de>.
Fix PM support on VX drivers (vxpocket and vx222).
Remove xxx_t typedefs from the VXdriver codes
(vx_core support, vx222 and vxpocket).
Digigram VX Pocket driver
Add snd_card_set_dev() to register the device pointer.
Fixed the wrong index number assignment.
Added the missing event callback.
Documentation,PCMCIA Kconfig,Digigram VX Pocket driver
- Fixed Oops with request_firmware()
- Detect the card type in runtime (vxpoocket v2 or 440)
- snd-vxp440 driver is merged to snd-vxpocket
- Clean up the code
As a follow-up, remove the inclusion of pcmcia/version.h in many files.
Add pcmcia_device_id table.
infrastructure for it.
Let it rip!
