path: root/sound/ppc/Kconfig
2009-10-27powerpc: Minor cleanup to sound/ppc/KconfigKumar Gala
We can replace PPC32 || PPC64 as a dependancy with just PPC as all powerpc platforms (32-bit and 64-bit) define PPC now. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-09ALSA: Add vmaster controls for Pmac 5500, iMac G3 SL, and PBook G3 LombardRisto Suominen
Add virtual master controls for PowerMac 5500 (AWACS) and iMac G3 Slot-loading and PowerBook G3 Lombard (Screamer). Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-27sound: Convert to menuconfigTakashi Iwai
Convert menu in sound Kconfig files to menuconfig and if. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2007-07-20[ALSA] Add PS3 sound driverMasakazu Mokuno
The patch adds the support for the sound feature of PS3 - the digital output of HDMI and SPDIF optical, and the analog output of AV multi. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-01-03[ALSA] powermac - Use platform_deviceTakashi Iwai
Modules: PPC,PPC PMAC driver,PPC PowerMac driver Rewrite the probe/remove with platform_device. Move the PM support to platform_device's callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] powermac - Add AUTO_DRC configTakashi Iwai
PPC,PPC Tumbler driver Added AUTO_DRC kernel config to enable/disable the auto-DRC-toggle feature on tumbler/snapper. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() callTakashi Iwai
ARM,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,MIPS MIPS AU1x00 driver,PPC,PPC PowerMac driver,SPARC,SPARC AMD7930 driver SPARC cs4231 driver,SPARC DBRI driver - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-04-26[PATCH] fix SND_POWERMAC dependenciesAl Viro
This beast is pmac-only; moreover, it won't build on other subarchitectures. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
