path: root/sound/sh
2007-07-24sh: Fix Dreamcast DMA issues.Adrian McMenamin
The current SH DMA API is somewhat broken, not correctly matching virtual channel to the correct SH DMAC. This wasn't noticeable when using g2 DMA for the sound driver - one channel 0 is as good as any other! - but caused the pvr2 driver to fail. This patch fixes the pvr2 problem and consequently fixes the sound driver to ensure it continues to function. Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20[ALSA] aica - fix behaviour in poor resource conditionsTakashi Iwai
Fix behaviour in poor resource conditions. With this new patch, tidied with indent and with SNDRV_PCM_TRIGGER_STOP being used. Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-07-20[ALSA] Add ALSA support for the SEGA Dreamcast PCM deviceAdrian McMenamin
ALSA support for the SEGA Dreamcast Yamaha AICA sound device (pcm) This patch adds ALSA sound support for pcm playback on two channels on the SEGA Dreamcast built-in sound device (the Yamaha AICA) Add driver for the AICA sound device built into the SEGA Dreamcast Hook it all up with the build system. Signed-off-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
