commit 7c04241acbdaf97f1448dcccd27ea0fcd1a57684 upstream.
ak4535_reg should be 8bit, but cache table is defined as 16bit.
The DAPM widgets are now insntantiated by the core when creating the card
so there is no need for the individual CODEC drivers to do so.
snd_soc_init_card() is always called as the last part of the CODEC probe
function so we can factor it out into the core card setup rather than
have each CODEC replicate the code to do the initialiastation. This will
be required to support multiple CODECs per card.
Nothing uses it and the existing hw_read operation needs to be
refectored so it's easier to remove it rather than work with it.
Support can be re-added if the code requires volatile registers.
ak4535_remove() from sound/soc/codecs/ak4535.c calls
i2c_unregister_device() with a possibly null pointer.
This bug was found by smatch (http://repo.or.cz/w/smatch.git/).
Considering the fact that most cpu_dai or codec_dai are using a same
'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better
made a pointer instead, to make sharing easier and code a bit cleaner.
The patch below is rather preliminary since the asoc tree is being
actively developed, and this touches almost every piece of code,
(and possibly many others in development need to be changed as
well). Building of all codecs are OK, yet to every SoC, I didn't test
that.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Acked-by: Timur Tabi <timur@freescale.com>
This is a further stage on the road to refactoring away the ASoC
platform device.
Many codec drivers were implementing cookie-cutter copies of the function
that adds kcontrols to the codec.
This patch moves this code to a common function snd_soc_add_controls() in
soc-core.c and updates all drivers using copies of this function to use the
new common version.
[Edited to raise priority of error log message and document parameters.
-- broonie]
Signed-off-by: Ian Molton <ian@mnementh.co.uk>
The module init entries should be __init instead of __devinit.
Currently this is done at module probe time since ASoC ties in codec
device probe to the instantiation of the entire ASoC device. Subsequent
patches will refactor the codec drivers to handle probing separately.
Note that the core does not yet use this information.
AC97 is special since the codec is controlled over the AC97 link but
we want to give the machine driver a chance to set up the system before
trying to instantiate since it may need to do configuration before the
AC97 link will operate
Currently ASoC card initialisation is completed by a function called
snd_soc_register_card(). As part of the work to allow independant
registration of cards, codecs and machines in ASoC v2 a new function of
the same name has been added so rename the existing function to
facilitate the merge of v2.
Liam Girdwood's ASoC v2 work avoids having two different ops structures
for DAIs by merging the members of struct snd_soc_ops into struct
snd_soc_dai_ops, allowing per DAI configuration for everything.
Backport this change.
This paves the way for future work allowing any combination of DAIs to
be connected rather than having fixed purpose CODEC and CPU DAIs and
only allowing CODEC<->CPU interconnections.
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
Currently the boiler plate code used by most ASoC codecs to provide a
placeholder for SPI access suggests making the selection of SPI a
compile time option which is suboptimal when trying to build kernels
supporting multiple systems. Change this template to suggest allowing
runtime selection instead.
Leave the drivers not yet converted to new style I2C access for now to
avoid collisions.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Convert the ak4535 codec driver to the new (standard) device driver
binding model. After this change, AK4535 devices are no longer
discovered automatically and must instead be instantiated explicitly.
Many SoC audio codec drivers have improper freeing of memory in error
paths.
* codec is allocated in the platform device probe function, but is not
freed there in case of error. Instead it is freed in the i2c device
probe function's error path. However the success or failure of both
functions is not linked, so this could result in a double free (if
the platform device is successfully probed, the i2c device probing
fails and then the platform driver is unregistered.)
* codec->private_data is allocated in many platform device probe
functions but not freed in their error paths.
This patch hopefully solves all these problems.
This patch merges struct snd_soc_codec_dai and struct
snd_soc_cpu_dai into struct snd_soc_dai for the codec drivers.
Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
The AK4535 codec is included in some HP iPAQ systems.
This driver was originally written by Richard Purdie and with some bug
fixes from Milan Plzik. While out of tree it has also had some
mechanical updates for new APIs and current best practices from Liam
Girdwood, Graeme Gregory and Mark Brown.
Signed-off-by: Richard Purdie <richard@openedhand.com>
Signed-off-by: Milan Plzik <milan.plzik@gmail.com>
Signed-off-by: Graeme Gregory <gg@opensource.wolfsonmicro.com>
