path: root/sound/soc/codecs/cs4271.c
2011-03-09ASoC: Manage mode and rate bits correctly for CS4271 CODEC.Alexander Sverdlin
Manage mode and rate bits correctly, according to datasheet in CS4271 CODEC. This is done to make capture work properly. Signed-off-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-03-07ASoC: Extend range of supported sample rates for CS4271 CODEC.Alexander Sverdlin
Extend range of supported sample rates for CS4271 CODEC. Signed-off-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-03-07ASoC: Constify i2c_device_id tableAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: Timur Tabi <timur@freescale.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-02-08ASoC: CS4271: Move Chip Select control out of the CODEC code.Alexander Sverdlin
Move Chip Select control out of the CODEC code for CS4271. Signed-off-by: Alexander Sverdlin <subaparts@yandex.ru> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-26ASoC: Staticise non-exported symbols in cs4271Mark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-25ASoC: cs4271.c: improve error handlingAlexander Sverdlin
CS4271 CODEC driver adapted to recently introduced error handling in snd_soc_update_bits(). Added snd_soc_cache_sync() error handling. Signed-off-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-21ASoC: CS4271 codec supportAlexander Sverdlin
Added support for CS4271 codec to ASoC. Signed-off-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
