The MCLK clock is made optional for cs42l51 codec.
However, ASoC DAPM clock supply widget, expects the clock to be defined
unconditionally.
Register MCLK DAPM conditionally in codec driver,
depending on clock presence in DT.
Fixes: 5e8d63a726f8 ("ASoC: cs42l51: add mclk support")
Signed-off-by: Olivier Moysan <olivier.moysan@st.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Add MCLK dapm to allow configuration of cirrus CS42l51
codec as a master clock consumer.
Now we can replace Codec to Component. Let's do it.
Note:
xxx_codec_xxx() -> xxx_component_xxx()
.idle_bias_off = 0 -> .idle_bias_on = 1
.ignore_pmdown_time = 0 -> .use_pmdown_time = 1
- -> .endianness = 1
- -> .non_legacy_dai_naming = 1
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Declare snd_soc_codec_driver structures as const as they are only passed
as an argument to the function snd_soc_register_codec. This argument is
of type const, so declare the structures with this property as const.
In file codecs/sn95031.c, snd_soc_codec_driver structure is also used in
a copy operation along with getting passed to snd_soc_register_codec.
So, it can be made const too.
Done using Coccinelle:
@match disable optional_qualifier@
identifier s;
position p;
static struct snd_soc_codec_driver s@p={...};
@good1@
identifier match.s;
position p;
snd_soc_register_codec(...,&s@p,...)
@bad@
identifier match.s;
position p!={match.p,good1.p};
s@p
@depends on !bad disable optional_qualifier@
identifier match.s;
static
+const
struct snd_soc_codec_driver s={...};
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
codec driver and component driver has duplicated callback functions,
and codec side functions are just copied to component side when
register timing. This was quick-hack, but no longer needed.
This patch moves these functions from codec driver to component driver.
"PCM channel mixer" ctl in cs42l51 codec driver is enum, while the
current driver accesses wrongly via value.integer.value[]. They have
to be via value.enumerated.item[] instead.
'asoc/topic/cs42l51' and 'asoc/topic/cs42l73' into asoc-next
The codec field of the snd_soc_widget struct is eventually going to be
removed, use snd_soc_dapm_to_codec(w->dapm) instead.
Acked-by: Brian Austin <brian.austin@cirrus.com>
In commit a1253ef6d3fa ("ASoC: cs42l51: split i2c from codec driver"),
the I2C part of the CS42L51 was moved to a separate file, but the
definition of the of_device_id array was left in the driver file
itself, no longer connected to the platform_driver structure using the
.of_match_table pointer.
This commit exports the of_device_id array in cs42l51, and uses it as
.of_match_able in cs42l51-i2c.c. This solution was suggested by Brian
Austin.
Fixes: a1253ef6d3fa ("ASoC: cs42l51: split i2c from codec driver")
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: <stable@vger.kernel.org>
and 'asoc/topic/davinci' into asoc-next
The REVID mask was changed by commit a1253ef6d3fa
"ASoC: cs42l51: split i2c from codec driver". Fix it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
This patch removes the i2c bus code from the codec driver and creates seperate i2c driver.
Signed-off-by: Brian Austin <brian.austin@cirrus.com>
For CODEC controls snd_kcontrol_chip() currently returns a pointer to the
CODEC that registered the control. With the upcoming consolidation of
platform and CODEC controls this will change. Prepare for this by introducing
the snd_soc_kcontrol_codec() helper function that will hide the implementation
details of how the CODEC for a control can be obtained. This will allow us to
change this easily in the future.
The patch also updates all CODEC drivers to use the new helper function.
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
ASoC: Updates for v3.15
This is mostly a few additional fixes from Lars-Peter, a new driver and
cleaning up a git failure with merging the Intel branch (combined with
an xargs failure to pay attention to error codes). The history lists a
bunch of additional commits for the branch but the content of those
commits is actually present already but not recorded in history due to
git failing. Unfortunately xargs is used in the merge script and it
doesn't do a good job of noticing errors from the commands it invokes.
# gpg: Signature made Thu 13 Mar 2014 14:25:44 GMT using RSA key ID 7EA229BD
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>"
# gpg: aka "Mark Brown <broonie@debian.org>"
# gpg: aka "Mark Brown <broonie@kernel.org>"
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>"
# gpg: aka "Mark Brown <broonie@linaro.org>"
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
Quite a busy release for ASoC this time, more on janitorial work than
exciting new features but welcome nontheless:
- Lots of cleanups from Takashi for enumerations; the original API for
these was error prone so he's refactored lots of code to use more
modern APIs which avoid issues.
- Elimination of the ASoC level wrappers for I2C and SPI moving us
closer to converting to regmap completely and avoiding some
randconfig hassle.
- Provide both manually and transparently locked DAPM APIs rather than
a mix of the two fixing some concurrency issues.
- Start converting CODEC drivers to use separate bus interface drivers
rather than having them all in one file helping avoid dependency
issues.
- DPCM support for Intel Haswell and Bay Trail platforms.
- Lots of work on improvements for simple-card, DaVinci and the Renesas
rcar drivers.
- New drivers for Analog Devices ADAU1977, TI PCM512x and parts of the
CSR SiRF SoC.
# gpg: Signature made Wed 12 Mar 2014 23:05:45 GMT using RSA key ID 7EA229BD
kcontrols
The shift values for the ADC,PCM, and Analog kcontrols were wrong causing wrong values for the SOC_DOUBLE_R_SX_TLV macros
Fixed the TLV for aout_tlv to show -102dB correctly
Fixes: 1d99f2436d (ASoC: core: Rework SOC_DOUBLE_R_SX_TLV add SOC_SINGLE_SX_TLV)
Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: stable@vger.kernel.org
'asoc/topic/tlv320aic26', 'asoc/topic/tlv320aic32x4', 'asoc/topic/tlv320aic3x', 'asoc/topic/tlv320dac33', 'asoc/topic/twl4030', 'asoc/topic/twl6040', 'asoc/topic/uda1380', 'asoc/topic/wl1273' and 'asoc/topic/wm2200' into asoc-next
For some CODEC drivers like who act as the MFDs children are ignored
by this patch.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Just replace with the helper macros. No functional change at all.
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
‘cs42l51’ is not used. Remove it.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
As part of phasing out the ASoC level register I/O code (which is now just
a thin wrapper around regmap anyway) convert the cs42l51 driver to use the
regmap API directly.
We now no longer initialise the cache from hardware at startup, the regmap
caches are smart enough to understand which registers are actually cached
and read on demand. This should have no visible effect on the system.
The VM subsystem already logs quite loudly if we run out of memory so
don't bother here.
This commit adds a trivial Device Tree binding to the I2C-based
cs42l51 sound codec, so that it can be used from Device Tree based
platforms.
module_i2c_driver makes the code simpler by eliminating module_init
and module_exit calls.
In order to support CODEC<->CODEC links remove the assumption that there
is only a single CODEC on a DAI link by removing the use of the CODEC
pointer in the rtd from the CODEC drivers. They are already being passed
their DAI whenever they are passed an rtd and can get the CODEC from
there.
Some codecs namely Cirrus Logic Codecs have a way of wrapping the dB scale around 0dB without 0dB being in the middle.
Rework of SOC_DOUBLE_R_SX_TLV to be more consistent with other asoc tlv macros.
Add single register macro : SOC_SINGLE_SX_TLV.
Use snd_soc_info_volsw for .info
Use snd_soc_get_volsw_sx, snd_soc_put_volsw_sx for single and double.
kcontrols for CS42L51 and CS42L73 are adjusted to these new TLV Macros.
The max value is determined by: (number of steps) +1 for 0dB +max from codec datasheet.
Acked-by: Liam Girdwood <lrg@ti.com>
They've not been needed for a long time if they were ever required.
Just checking the code in cs42l51_fill_cache():
The cache pointer points to codec->reg_cache + 1.
I think it is because CS42L51_FIRSTREG is 0x01,
so codec->reg_cache[0] is not used here.
Then we read CS42L51_NUMREGS bytes to cache.
So we need reg_cache_size to be CS42L51_NUMREGS + 1.
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
snd_soc_update_bits already does read-modify-write,
no need to read the register before calling snd_soc_update_bits.
Acked-by: Timur Tabi <timur@freescale.com>
The control_data field is used to initialize the codec's control_data field,
but since this is also done by the snd-soc-cache core, the redundant
assignment can be removed and the field can be dropped.
The multi-component patch(commit f0fba2ad1) moved the allocation of the
register cache from the driver to the ASoC core. Most drivers where adjusted to
this, but there are quite a few drivers left which now have an unused reg_cache field in
their private device struct.
This patch removes these unused fields.
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Like other coworkers, I'm about leave Mandriva/Edge-It so I'm changing
my mail address to use my personal one.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
multicomponent support added/changed some device name but added some typos,
breaking existing OpenRD Client support.
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch is adding a ASoC driver for the cs42l51 from Cirrus Logic.
Master mode and spi mode are not supported.
Acked-by: Liam Girdwood <lrg@slimlogic.co.ul>
