LINE_IN also needs VAG_POWER on or we may hear noise when directly
route LINE_IN to Headphone Mux.
Tested on imx28evk.
Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org>
There's a driver bug that sgtl5000 dapm widget kcontrols do not work.
e.g. can not select capture mux with amixer tool(no error info prompted).
The root cause is that we still call snd_soc_dapm_new_widgets in
codec driver probe function afer converting to table based widgets.
This will cause the card dapm widgets are instantiated before the
dapm_routes are registered.
Then, no available dapm widget pathes can be found during instantiation
which finally will cause soc_dapm_mux_update_power to fail(can not find
correct path with kcontrol) in snd_soc_dapm_put_enum_double function.
Here we remove the unneeded snd_soc_dapm_new_widgets in codec probe
and let the soc core to handle the register sequence properly.
Then we can fix above issue.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This is the first big chunk for 3.5 merges of sound stuff.
There are a few big changes in different areas. First off, the
streaming logic of USB-audio endpoints has been largely rewritten for
the better support of "implicit feedback". If anything about USB got
broken, this change has to be checked.
For HD-audio, the resume procedure was changed; instead of delaying
the resume of the hardware until the first use, now waking up
immediately at resume. This is for buggy BIOS.
For ASoC, dynamic PCM support and the improved support for digital
links between off-SoC devices are major framework changes.
Some highlights are below:
* HD-audio
- Avoid accesses of invalid pin-control bits that may stall the codec
- V-ref setup cleanups
- Fix the races in power-saving code
- Fix the races in codec cache hashes and connection lists
- Split some common codes for BIOS auto-parser to hda_auto_parser.c
- Changed the PM resume code to wake up immediately for buggy BIOS
- Creative SoundCore3D support
- Add Conexant CX20751/2/3/4 codec support
* ASoC
- Dynamic PCM support, allowing support for SoCs with internal
routing through components with tight sequencing and formatting
constraints within their internal paths or where there are multiple
components connected with CPU managed DMA controllers inside the
SoC.
- Greatly improved support for direct digital links between off-SoC
devices, providing a much simpler way of connecting things like
digital basebands to CODECs.
- Much more fine grained and robust locking, cleaning up some of the
confusion that crept in with multi-component.
- CPU support for nVidia Tegra 30 I2S and audio hub controllers and
ST-Ericsson MSP I2S controolers
- New CODEC drivers for Cirrus CS42L52, LAPIS Semiconductor ML26124,
Texas Instruments LM49453.
- Some regmap changes needed by the Tegra I2S driver.
- mc13783 audio support.
* Misc
- Rewrite with module_pci_driver()
- Xonar DGX support for snd-oxygen
- Improvement of packet handling in snd-firewire driver
- New USB-endpoint streaming logic
- Enhanced M-audio FTU quirks and relevant cleanups
- Increment the support of OSS devices to 256
- snd-aloop accuracy improvement
There are a few more pending changes for 3.5, but they will be sent
slightly later as partly depending on the changes of DRM."
Fix up conflicts in regmap (due to duplicate patches, with some further
updates then having already come in from the regmap tree). Also some
fairly trivial context conflicts in the imx and mcx soc drivers.
* tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (280 commits)
ALSA: snd-usb: fix stream info output in /proc
ALSA: pcm - Add proper state checks to snd_pcm_drain()
ALSA: sh: Fix up namespace collision in sh_dac_audio.
ALSA: hda/realtek - Fix unused variable compile warning
ASoC: sh: fsi: enable chip specific data transfer mode
ASoC: sh: fsi: call fsi_hw_startup/shutdown from fsi_dai_trigger()
ASoC: sh: fsi: use same format for IN/OUT
ASoC: sh: fsi: add fsi_version() and removed meaningless version check
ASoC: sh: fsi: use register field macro name on IN/OUT_DMAC
ASoC: tegra: Add machine driver for WM8753 codec
ALSA: hda - Fix possible races of accesses to connection list array
ASoC: OMAP: HDMI: Introduce codec
ARM: mx31_3ds: Add sound support
ASoC: imx-mc13783 cleanup
mx31moboard: Add sound support
ASoC: mc13783 codec cleanups
ASoC: add imx-mc13783 sound support
ASoC: Add mc13783 codec
mfd: mc13xxx: add codec platform data
ASoC: don't flip master of DT-instantiated DAI links
'regulator/topic/regmap' and 'regulator/topic/register' into regulator-next
Linux 3.4-rc3 contains a bunch of Tegra changes which are conflicting
annoyingly with the new development that's going on for Tegra so merge
it up to resolve those conflicts.
sound/soc/soc-core.c
sound/soc/tegra/tegra_i2s.c
sound/soc/tegra/tegra_spdif.c
Rather than adding new arguments to regulator_register() every time we
want to add a new bit of dynamic information at runtime change the function
to take these via a struct. By doing this we avoid needing to do further
changes like the recent addition of device tree support which required each
regulator driver to be updated to take an additional parameter.
The regulator_desc which should (mostly) be static data is still passed
separately as most drivers are able to configure this statically at build
time.
In order to support CODEC<->CODEC links remove the assumption that there
is only a single CODEC on a DAI link by removing the use of the CODEC
pointer in the rtd from the CODEC drivers. They are already being passed
their DAI whenever they are passed an rtd and can get the CODEC from
there.
Fix the following warning during kernel boot:
0-000a: 850 <--> 1600 mV at 1200 mV normal
0-000a: Voltage range but no REGULATOR_CHANGE_VOLTAGE
As manual described, VAG is an internal voltage reference of DAC/ADC,
So enabled it before DAC/ADC up.
One more thing should care about is VAG fully ramped down requires 400ms,
wait it to avoid pop.
Signed-off-by: Zeng Zhaoming <zengzm.kernel@gmail.com>
No current users and it's the last user of MICBIAS_E().
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
Acked-by: Zeng Zhaoming <zengzm.kernel@gmail.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Convert to table based DAPM and control init.
Throughout the sgtl5000 driver source code and also in the sgtl5000 datasheet
the revision code is shown in hexadecimal.
Print it hex format, for consistency.
Correct SGTL5000_CHIP_CLK_CTRL to SGTL5000_CHIP_REF_CTRL in
sgtl5000_restore_regs(), and add comment to explain the
restore order.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
* 'fix/asoc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: Wait for WM8993 FLL to stabilise
ASoC: core - Free platform DAPM context at platform removal.
ASoC: dapm - Fix check for codec context in dapm_power_widgets().
ASoC: sgtl5000: update author email address
ASoC: Fix DMA channel leak in imx-pcm-dma-mx2 driver.
Update MODULE_AUTHOR email address.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits)
ASoC: twl6040 - Add method to query optimum PDM_DL1 gain
ALSA: hda - Fix the lost power-setup of seconary pins after PM resume
ALSA: usb-audio: add Yamaha MOX6/MOX8 support
ALSA: virtuoso: add S/PDIF input support for all Xonars
ALSA: ice1724 - Support for ooAoo SQ210a
ALSA: ice1724 - Allow card info based on model only
ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations
ALSA: hdspm - Provide unique driver id based on card serial
ASoC: Dynamically allocate the rtd device for a non-empty release()
ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC
ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs
ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs
ALSA: hda - Use auto-parser for HP laptops with cx20459 codec
ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info()
ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref()
ALSA: hda/cirrus - support for iMac12,2 model
ASoC: cx20442: add bias control over a platform provided regulator
ALSA: usb-audio - Avoid flood of frame-active debug messages
ALSA: snd-usb-us122l: Delete calls to preempt_disable
mfd: Put WM8994 into cache only mode when suspending
Fix up trivial conflicts in:
- arch/arm/mach-s3c64xx/mach-crag6410.c:
renamed speyside_wm8962 to tobermory, added littlemill right
next to it
- drivers/base/regmap/{regcache.c,regmap.c}:
duplicate diff that had already come in with other changes in
the regmap tree
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (40 commits)
regulator: set constraints.apply_uV to 0 in of_get_fixed_voltage_config
regulator: max8925: fix enabled/disabled judgement mistake
regulator: add regulator_bulk_force_disable function
regulator: pass regulator_register of_node in fixed voltage driver
regulator: add regulator_force_disable() definition for !CONFIG_REGULATOR
regulator: Enable supply regulator if child rail is enabled.
regulator: mc13892: Convert to devm_kzalloc()
regulator: mc13783: Convert to devm_kzalloc()
regulator: Fix checking return value of create_regulator
regulator: Fix the error handling if create_regulator fails
regulator: Export regulator_is_supported_voltage()
regulator: mc13892: add device tree probe support
regulator: mc13892: remove the unnecessary prefix from regulator name
regulator: Convert wm831x regulator drivers to devm_kzalloc()
regulator: da9052: Staticize non-exported symbols
regulator: Replace kzalloc with devm_kzalloc and if-else with a switch-case for da9052-regulator
regulator: Update da9052-regulator for DT changes
regulator: DA9052/53 Regulator support
regulator: pass device_node to of_get_regulator_init_data()
regulator: If a single voltage is set with device tree then set apply_uV
Convert sgtl5000 codec driver to use devm_kzalloc().
vdda, vddio and vddd are voltages expressed in milivolts (mV), so use the
proper annotation.
The existence of this parameter is purely historical. None of the CODEC drivers
uses it and we always pass in the same value anyway, so it should be safe to
remove it.
Acked-by: Liam Girdwood <lrg@ti.com>
They've not been needed for a long time if they were ever required.
With device tree support for regulators, its needed that the
regulator_dev->dev device has the right of_node attached.
To be able to do this add an additional parameter to the
regulator_register() api, wherein the dt-adapted driver can
then pass this additional info onto the regulator core.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure")
introduced the possibility to have constant DAI ops structures, yet this is
barley used in both existing drivers and also new drivers being submitted,
although none of them modifies its DAI ops structure. The later is not
surprising since existing drivers are often used as templates for new drivers.
So this patch just constifies all existing snd_soc_dai_ops structs to eliminate
the issue altogether.
The patch was generated with the following coccinelle semantic patch:
// <smpl>
identifier ops;
-struct snd_soc_dai_ops ops =
+const struct snd_soc_dai_ops ops =
// </smpl>
Give the correct number of entries to TLV_DB_RANGE_HEAD to prevent
reading more data than actually is in the array.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Ensure all mask bits are clear before setting new value.
Acked-by: Dong Aisheng <b29396@freescale.com>
We have defined SGTL5000_LINREG_VDDD_MASK in sgtl5000.h,
use it instead of hardcoded (0x1 << 4) - 1 for the mask.
Otherwise calling ldo_regulator_remove() does not unregister regulator
and free memories.
According to the datasheet:
CHIP_MIC_CTRL 0x002A
BITS[9:8] BIAS_RESISTOR
0x0 = Powerd off
0x1 = 2.0 kohm
0x2 = 4.0 kohm
0x3 = 8.0 kohm
To set mic bias resistor, we need to update bits[9:8] of
SGTL5000_CHIP_MIC_CTRL register.
The module device table for of_device_id should use "of" type.
Conflict due to the fix for the register map failure - taken the for-3.1
version.
sound/soc/codecs/sgtl5000.c
Cache handling in this driver is broken. The chip has 16-bit registers, yet the
register numbers also increase by 2 per register, i.e. there are only
even-numbered registers. The cache in this driver, though, simply increments
register numbers, so it does need some mapping as seen in
sgtl5000_restore_regs(), note the '>> 1':
snd_soc_write(codec, SGTL5000_CHIP_LINREG_CTRL,
cache[SGTL5000_CHIP_LINREG_CTRL >> 1]);
That, of course, won't work with snd_soc_update_bits(). (Thus, we won't even
notice the missing register 0x1c in the default regs which shifted all follwing
registers to wrong values.) Noticed on the MX28EVK where enabling the regulators
simply locked up the chip.
Refactor the routines and use a properly sized default_regs array which matches
the register layout of the underlying chip, i.e. create a truly flat cache.
This also saves some code which should make up for the bigger array a little.
When soc-core will somewhen have another cache type which handles a step size,
this conversion will also ease the transition.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Tested-by: Dong Aisheng <b29396@freescale.com>
Cc: stable@kernel.org
Signed-off-by: Dong Aisheng <b29396@freescale.com>
Signed-off-by: Zeng Zhaoming <zhaoming.zeng@freescale.com>
It adds device tree probe support for sgtl5000 driver.
Print a hint when the user has a setup where CONFIG_REGULATOR is really
needed to make the driver work.
Tested-by: Shawn Guo <shawn.guo@freescale.com>
The code for registering the internal ldo was present twice. Turn it
into a function instead. Also, inform the user if LDO is used now.
The regulator is optional depending on board design.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
The "ldo" variable was dereferenced after free on the error path.
Remove unnecessary headers:
- mach/hardware.h in sgtl5000.c
- linux/i2c.h in sgtl5000.h
Signed-off-by: Zeng Zhaoming <b32542@freescale.com>
Add Freescale SGTL5000 codec support.
Supported features:
- line-in and mic input
- headphone and line-out output
- line-in bypass ADC and DAC to headphone
- 16, 20, 24, 32 bit audio
- 8 ~ 96k sample rates
