path: root/sound/soc/codecs/stac9766.c
2010-11-22Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-22ASoC: stac9766 - set reg_cache_default to stac9766_regAxel Lin
Looks like this is missing during multi-component conversion. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-05-10ASoC: Remove unneeded suspend bias managment from CODEC driversMark Brown
The core will ensure that the device is in either STANDBY or OFF bias before suspending, restoring the bias in the driver is unneeded. Some drivers doing slightly more roundabout things have been left alone for now. Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-04-17ASoC: Add indirection for CODEC private dataMark Brown
One of the features of the multi CODEC work is that it embeds a struct device in the CODEC to provide diagnostics via a sysfs class rather than via the device tree, at which point it's much better to use the struct device private data rather than having two places to store it. Provide an accessor function to allow this change to be made more easily, and update all the CODEC drivers are updated. To ensure use of the accessor the private data structure member is renamed, meaning that if code developed with older an older core that still uses private_data is merged it will fail to build. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16ASoC: Fix disable of SPDIF on STAC9766 codecJon Smirl
Change code so that switching to playing music through the analog output disables SPDIF out instead of disabling it when stream ends. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-13ASoC: Keep index within stac9766_reg[]Roel Kluin
Keep index within stac9766_reg[] Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-24ASoC: Fix minor issues in STAC9766 driverMark Brown
Fairly minor issues: - Don't register the DAIs, it's not required for AC97 devices. - Make unexported functions static. - Wrap some excessively long lines. - Undo tab/space breakage. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-24ASoC: Codec for STAC9766 used on the EfikaJon Smirl
Datasheet: http://www.idt.com/products/getDoc.cfm?docID=13134007 Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
