'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
'asoc/fix/pxa', 'asoc/fix/spear', 'asoc/fix/sti' and 'asoc/fix/wm0010' into asoc-linus
Fix the error path so that we can free the allocated memory on the error
path instead of releasing them individually on each error.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
We have requested for the firmware but we have missed releasing it both
on success and on error path.
While checking the code it turned out that the requested firmware is not
even used. More over the same firmware is being loaded by
wm0010_stage2_load().
We were aborting if the kzalloc of img_swap fails but without freeing the
already allocated out. Similarly we were aborting if spi_sync fails
without releasing out and img_swap.
This reverts 58d468328646 ("ASoC: wm0010: Add missing IRQF_ONESHOT").
The coccinelle warnings is false positive because the original code does
set IRQF_ONESHOT by "trigger |= IRQF_ONESHOT;".
Signed-off-by: Axel Lin <axel.lin@ingics.com>
In ancient times it was necessary to manually initialize the bus
field of an spi_driver to spi_bus_type. These days this is done in
spi_register_driver(), so we can drop the manual assignment.
Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com>
The dapm field of the snd_soc_codec struct is eventually going to be
removed, in preparation for this replace all manual access to
codec->dapm.bias_level with snd_soc_codec_get_bias_level().
All drivers have the same line at the end of the set_bias_level callback to
update the bias_level state. Move this update into
snd_soc_dapm_force_bias_level() and remove them from the drivers.
'asoc/topic/wm0010', 'asoc/topic/wm8904' and 'asoc/topic/wm8962' into asoc-next
Also add const to array
10946 2904 3528 17378 43e2 sound/soc/codecs/wm0010.o-before
10891 2840 3512 17243 435b sound/soc/codecs/wm0010.o-after
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Mark Brown <broonie@linaro.org>
Let memory subsystem handle the error logging.
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
Use WARN_ON() and handle the error cases accordingly.
Spotted by coverity CID 744701.
We should be allocating our buffers for the SPI transfers
from the DMA zone.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
If kzalloc() fails for `img' then we are going to leak the memory
for `out'. We are freeing the memory of all the tx/rx transfers
but the tx/rx buf pointers will be NULL if we drop out earlier.
Both clear the IRQ as being a wake source when we are finished with it
and include a missing header file that is required.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
The DSPs IRQ should be a wake source as several of the possible
algorithms may run whilst the AP is asleepi and require to wake the AP
to push or pull more data, such as compressed playback.
Fix to return -ENOMEM in the memory malloc of 'out' and 'img_swap' error
handling case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
The device should not be generating interrupts when it does not have power
so ignore incoming interrupts.
The info record at the start of the dsp firmware file has been
expanded to incorporate additional version information. We need
to check the version to make sure we understand the layout of
the information in the record. The srec2image tool is currently
used to create this record during creation of the .dfw file.
Signed-off-by: Scott Ling <sl@opensource.wolfsonmicro.com>
Increase timeout to be more reliable and avoid the chance of
missing interrupts during boot.
Move the firmware load and record parsing functionality out into
a separate function from the boot function.
Remove the boot_done counter variable and check the wm0010 state
variable instead.
Signed-off-by: Scott Ling <scott.ling@wolfsonmicro.com>
The interrupt handler uses the chip state.
We will fail to probe without one.
We never set the GPIO from atomic context so there's no reason why we
can't support a GPIO that needs to sleep when configuring.
Fix warning by using format specifier %zu for type size_t
Sparse warning:
sound/soc/codecs/wm0010.c:411:2: warning:
format ‘%d’ expects argument of type ‘int’,
but argument 4 has type ‘size_t’ [-Wformat]
Signed-off-by: Emil Goode <emilgoode@gmail.com>
We're holding the wm0010->lock mutex when we goto err_core.
FYI, there are new coccinelle warnings show up in
tree: git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound.git for-3.7
head: e3523e01869da20fdd12ffd19ae1df7bf492650e
commit: e3523e01869da20fdd12ffd19ae1df7bf492650e [95/95] ASoC: wm0010: Add initial wm0010 DSP driver
All coccinelle warnings:
+ sound/soc/codecs/wm0010.c:850:7-27: ERROR: Threaded IRQ with no primary handler requested without IRQF_ONESHOT
+ sound/soc/codecs/wm0010.c:660:1-7: preceding lock on line 359
vim +850 sound/soc/codecs/wm0010.c
847 trigger = IRQF_TRIGGER_FALLING;
848 trigger |= IRQF_ONESHOT;
849
> 850 ret = request_threaded_irq(irq, NULL, wm0010_irq, trigger,
851 "wm0010", wm0010);
852 if (ret)
853 dev_err(wm0010->dev, "Failed to request IRQ %d: %d\n",
Please consider folding the attached diff :-)
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
This is more idimatic for modern drivers. Also fix a couple of return
codes while we're at it.
Make it scan better by writing ROM with capitals.
We are using devm_ to allocate the GPIO so it will be freed automatically.
Doesn't make any practical difference given that _SUSPEND and _OFF are
equivalent for the driver but it's what we're really doing.
Make it easier to integrate the management of the clock supplying the
WM0010 with DAPM by providing a dummy supply widget which supplies the
interface widgets, this can be connected to clock outputs by the machines.
With appropriate clocking configuration the WM0010 driver supports 44.1kHz
audio; enable that.
The WM0010 is a compact digital signal processor that has been
highly optimised for low-power audio applications. Extensive memory
resources and core optimisation allow the device to manage all audio
processing algorithms efficiently and autonomously, while the host
processor sleeps or performs other tasks.
