The multi-component patch(commit f0fba2ad1) moved the allocation of the
register cache from the driver to the ASoC core. Most drivers where adjusted to
this, but there are quite a few drivers left which now have an unused reg_cache field in
their private device struct.
This patch removes these unused fields.
Acc to WM8580 manual, the default value for R8 is 0x10, not 0x1c.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: stable@kernel.org
sound/soc/soc-core.c
Axel's fix on two different branches.
In case of SNDRV_PCM_FORMAT_S32_LE, we need to set WM8580_AIF_LENGTH_32,
rather than WM8580_AIF_LENGTH_24.
Also, the BCLK has to be 64fs, for sample size of 20, 24 and 32 bits.
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
We want the index of DAI's driver here.
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
There is no need to use '&' in this case. Either way, if a is an array
of some type, then a == &a == &a[0].
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
The variable is not used anyway.
The reg_cache_size is the number of elements in the register cache,
not the size of the cache itself. This is not a problem if the size
of each element of the cache is 1 byte but it matters in any other
case.
Reported-by: Seungwhan Youn <claude.youn@gmail.com>
The RX and TX directions were inverted.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into for-2.6.37
Trivial overlap with the removal of the local revision variable.
sound/soc/codecs/wm8994.c
The DAC OSR should be selected based on the sample clock ratio.
Drive a minimal supported number of clocks required for the current
bit format in master mode. In slave mode this setting has no effect.
Implement set_sysclk() and then rather than assuming 256fs use the
supplied value to calculate and configure the clock ratio for the
currently used sample rate. As a side effect we also end up
implementing clock selection for the ADC path.
In order to avoid confusion remove the existing set_clkdiv() based
configuration of the clock source for the DAC and update the SMDK64xx
driver (which is the only in-tree user of the CODEC).
In the case of the BCLK rate the defines are at best misleading anyway.
All the cool kids are using snd_soc_update_bits() these days.
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into for-2.6.37
Now soc-cache.c can figure out the I2C and SPI control data from the
device for the CODEC we don't need to manually assign it in drivers.
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Should use Capture rather than ADC so the UI tools can identify their
function more readily.
sound/soc/codecs/ad1938.c
One of the features of the multi CODEC work is that it embeds a struct
device in the CODEC to provide diagnostics via a sysfs class rather than
via the device tree, at which point it's much better to use the struct
device private data rather than having two places to store it. Provide
an accessor function to allow this change to be made more easily, and
update all the CODEC drivers are updated.
To ensure use of the accessor the private data structure member is
renamed, meaning that if code developed with older an older core that
still uses private_data is merged it will fail to build.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The DAPM widgets are now insntantiated by the core when creating the card
so there is no need for the individual CODEC drivers to do so.
snd_soc_init_card() is always called as the last part of the CODEC probe
function so we can factor it out into the core card setup rather than
have each CODEC replicate the code to do the initialiastation. This will
be required to support multiple CODECs per card.
The PM core will grow pm_link infrastructure in 2.6.33 which can be
used to implement the intended functionality of the ASoC-specific
device suspend and resume callbacks so drop them.
More and more devices feature PLLs and FLLs with the ability to select
between multiple input clocks. In order to better support these devices
a new argument, source, has been added to the set_pll() configuration
API. Using set_clkdiv() is often difficult due to the need to stop the
PLL/FLL before any reconfiguration can be done.
Bug was caught while trying to use WM8580 as I2S master on SMDK.
Symptoms were lesser LRCLK read by CRO(41.02 instead of 44.1 KHz) Solved
by referring to WM8580A manual and setting mask value correctly and
making the code to not touch 'reserved' bits of PLL4 register.
Signed-off-by: Jassi <jassi.brar@samsung.com>
While writes tend to be able to use a fairly bus independant format to
do the writes reads are all bus specific. To allow us to factor out
this code include the bus type as a parameter when setting up the
cache.
Initially just use this to factor out hw_write_t for I2C.
Note the slightly tricky cache usage in the volume update function due
to the requirement for a separate write for the VU bit.
Add basic support for integration with the regulator API to WM8580.
Since the core cannot yet disable biases when the CODEC is idle we
simply request and enable the regulators for the entire time the
driver is active.
Unsigned variables should use `%u' rather than `%d'.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
The driver is out of sync with the core functions it is using.
Refactor the WM8580 device registration to probe via standard I2C device
registration, registering the DAIs once the device has probed via I2C.
Merge Eric Maio's patch to merge snd_soc_dai_ops out of line. Fixed
merge issues and updated drivers, plus an issue with the ops for the two
s3c2443 AC97 DAIs having been merged.
Considering the fact that most cpu_dai or codec_dai are using a same
'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better
made a pointer instead, to make sharing easier and code a bit cleaner.
The patch below is rather preliminary since the asoc tree is being
actively developed, and this touches almost every piece of code,
(and possibly many others in development need to be changed as
well). Building of all codecs are OK, yet to every SoC, I didn't test
that.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
This is a further stage on the road to refactoring away the ASoC
platform device.
This patch takes fixes a number of bugs in the caching code used by
several ASoC codec drivers. Mostly off-by-one fixes.
Signed-off-by: Ian Molton <ian@mnementh.co.uk>
Many codec drivers were implementing cookie-cutter copies of the function
that adds kcontrols to the codec.
This patch moves this code to a common function snd_soc_add_controls() in
soc-core.c and updates all drivers using copies of this function to use the
new common version.
[Edited to raise priority of error log message and document parameters.
-- broonie]
The module init entries should be __init instead of __devinit.
Currently this is done at module probe time since ASoC ties in codec
device probe to the instantiation of the entire ASoC device. Subsequent
patches will refactor the codec drivers to handle probing separately.
Note that the core does not yet use this information.
AC97 is special since the codec is controlled over the AC97 link but
we want to give the machine driver a chance to set up the system before
trying to instantiate since it may need to do configuration before the
AC97 link will operate
