path: root/sound/soc/codecs/wm8731.h
2010-08-17ASoC: Support non-crystal master clocks for WM8731Mark Brown
Instead of unconditionally enabling the crystal oscillator on the WM8731 only enable it when explicitly selected via set_sysclk(), allowing machine drivers to specify that they drive a clock into MCLK alone. This avoids any conflicts between the oscillator and the external MCLK source and saves power for systems which do not need the oscillator. This should also deliver a small power saving on systems using the crystal since the oscillator will only be enabled when the ADC or DAC is active. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-02-18ASoC: Refactor WM8731 device registrationMark Brown
Move the WM8731 driver to use a more standard device registration scheme where the device can be registered independantly of the ASoC probe. As a transition measure push the current manual code for registering the WM8731 into the individual machine driver probes. This allows separate patches to update the relevant architecture files with less risk of merge issues. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-09-04ALSA: ASoC: Add SPI support for WM8731Cliff Cai
[Modified to allow runtime selection between I2C and SPI and to select SPI_MASTER for all codecs build so this is included. -- broonie] Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-09-04ALSA: ASoC: Convert wm8731 to a new-style i2c driverJean Delvare
Convert the wm8731 codec driver to the new (standard) device driver binding model. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-10ALSA: asoc: codecs - merge structs snd_soc_codec_dai and snd_soc_cpu_dai.Liam Girdwood
This patch merges struct snd_soc_codec_dai and struct snd_soc_cpu_dai into struct snd_soc_dai for the codec drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-02-09[ALSA] soc - ASoC 0.13 WM8731 codecFrank Mandarino
This patch updates the WM8731 codec driver to the new API in ASoC 0.13. Changes:- o Removed DAI capabilities matching code in favour of manual matching in the machine drivers. o Added DAI operations for codec and CPU interfaces. o Removed config_sysclk() function and struct snd_soc_clock_info. No longer needed as clocking is now configured manually in the machine drivers. Also removed other clocking data from structures. Signed-off-by: Frank Mandarino <fmandarino@endrelia.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC codecs: WM8731 supportRichard Purdie
This patch adds ASoC support for the WM8731 codec. Supported features:- o Capture/Playback/Sidetone/Bypass. o 16 & 24 bit audio. o 8k - 96k sample rates. o DAPM. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
