Bug 949219
Change-Id: I9c2a0aa22432c586a7e72273ad935d42332e873f
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/95087
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
The bias control must be done after the default register value
been restored.
Bug 964400
Change-Id: Iefbd96506573d5ea0e1b3123bb34c38e34e75068
Signed-off-by: Joseph Lo <josephl@nvidia.com>
Reviewed-on: http://git-master/r/96658
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Clock function for non-integral of sample
rate clocks does not work correctly and
generates incorrect sample rate.
Signed-off-by: ScottPeterson <speterson@nvidia.com>
Reviewed-on: http://git-master/r/75792
Change-Id: I39977c9e2b647d4eabc8d9209c2d05665f708ab0
Reviewed-on: http://git-master/r/77752
Instead of using tight bitclk use 2x of minimum bitclk requirement
in codec master mode. This change is needed to have clean audio
in codec master mode on Tegra30 based cardhu platform.
Bug 915107
Change-Id: Ia59e1a906415ad8fd1ed324ab4dabef61746b62f
Reviewed-on: http://git-master/r/75706
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-on: http://git-master/r/76467
When codec enters suspend mic bias gets turned off. As a result if a
mic is already plugged in a mic removal event gets triggered. Once
codec driver gets mic removal interrupt it sleeps for the duration
of debounce time which causes kernel power manager to abort suspend.
To avoid this scenario disable mic detect IRQ before powering off
codec and enable the same during resume.
Change-Id: Ic3c90d73c9f2742b6771f7e3fe0e3fb1f59e1cd9
Reviewed-on: http://git-master/r/68662
Reviewed-by: Nikesh Oswal <noswal@nvidia.com>
Without this, request_irq on subsequent device initialization fails, and
the codec cannot be used.
Acked-by: Liam Girdwood <lrg@ti.com>
Commit fafd217 ("ASoC: Store a list of widgets in a DAPM mux/mixer kcontrol")
changed the control private data type that is passed to snd_soc_cnew when
creating dapm mixer and mux controls. Commit did not update a few codec
drivers that are using their own put callbacks and thus are accessing a
wrong data type.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Increase the range of the Digital Capture Volume control to be 120 steps.
Each step is 0.75dB, and the range starts at -72dB, giving a max setting
of 18dB, which matches the latest datasheet, to the precision of the step
size.
In addition to the currently supported analog capture path, the WM8903
also supports digital mics.
The analog and digital capture paths are exclusive; a mux is present to
select the capture source.
Logically, the mux exists to select the decimator's input, from either
the ADC or DMIC block outputs. However, the ADC power domain also
includes the DMIC interface. Consequently, this change represents the
mux as existing immediately before the ADC, and selecting between the
Input PGA and DMIC block outputs.
An alternative might be to represent the mux in its correct location,
and associate the ADC power enable controls with both the real ADC, and
a fake ADC for the DMIC?
Update the headphone and line out mixers and PGAs use the same logical
set of register bits and sequencing as the speaker mixer/PGA.
This allows ALSA controls for mute and volume on headphone and line out
to operate correctly.
Per conversation on alsa-devel, earlier datasheets indicated that the
POWER_MANAGEMENT_* register bits 0 and 1 were aliases to ANALOG_* register
bits 0 and 4, and hence only one copy of those bits was programmed.
However, later datasheets corrected this.
[swarren: Applied same change to headphone widgets]
The WM8903 interrupts are clear on read so if the WM8903 detection is
enabled from platform data when the IRQ is in use (rather than using a
direct signal from a GPIO) status may be lost during startup. Help users
spot this misconfiguration by adding a WARN_ON().
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
The mic detection HW should be enabled when either mic or short detection
is required, not when only both are required.
Cc: stable@kernel.org
This makes no real difference compared to the write sequencer sequence
that was previously used but can run without a clock being provided.
Also remove the write sequencer support code as this was the last use
of it.
The write sequencer sequencer sequence takes longer than is desirable
as it brings up a full playback path which is not required at this
point. Open coding the sequence cuts the startup time by two thirds.
Explicitly cache the DC servo offsets for digital paths in the driver,
allowing them to be preserved over suspend and resume, and ensure that
we recalibrate analogue outputs paths when they are in use so that we
cover any changes in the input offset.
The WM8903 register map does not mute the DAC by default at startup
so we need to explicitly do so.
This simplfies the code and slightly reduces the startup time.
It causes noisy -codecs to appear in things like .codec_name.
Also, update platform_data GPIO handling to have an explicit "don't
touch this pin" option.
Add #defines for the GPIO pin functions.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
The multi-component patch(commit f0fba2ad1) moved the allocation of the
register cache from the driver to the ASoC core. Most drivers where adjusted to
this, but there are quite a few drivers left which now have an unused reg_cache field in
their private device struct.
This patch removes these unused fields.
Due to a typographical error in the erratum workaround it was never
functional so just remove it.
No idea why this works on ARM but not x86.
Add jack detection interrupt trace to Wolfson CODEC drivers.
Provide the user with a boolean control then automatically select
the deemphasis filter most closely matching the sample rate.
We're already flagged as using symmetric rates so we don't need to
have a custom implementation.
There is no need to include soc-dapm.h since soc.h includes it.
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Now soc-cache.c can figure out the I2C and SPI control data from the
device for the CODEC we don't need to manually assign it in drivers.
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
sound/soc/codecs/ad1938.c
The core will ensure that the device is in either STANDBY or OFF bias
before suspending, restoring the bias in the driver is unneeded. Some
drivers doing slightly more roundabout things have been left alone
for now.
Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
One of the features of the multi CODEC work is that it embeds a struct
device in the CODEC to provide diagnostics via a sysfs class rather than
via the device tree, at which point it's much better to use the struct
device private data rather than having two places to store it. Provide
an accessor function to allow this change to be made more easily, and
update all the CODEC drivers are updated.
To ensure use of the accessor the private data structure member is
renamed, meaning that if code developed with older an older core that
still uses private_data is merged it will fail to build.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Don't force enable the microphone bias on WM8903 when doing jack
detection, and don't force enable microphone bias. This allows
platforms to only enable microphone detection when a jack has been
inserted.
Support use of the WM8903 IRQ for reporting of microphone presence
and short detection.
Currently used to detect completion of the write sequencer.
Provide support for WM8903 microphone presence and short detection
using the GPIOs to route out a logic signal suitable for handling
using snd_soc_jack_add_gpios() on the processor GPIOs.
Allow users to pass in a default configuration for the GPIOs of
the WM8903 as platform data. This allows configuration of the pin
muxing of the device.
