"DRC Mode" and "EQ Mode" ctls in wm8904 codec driver are enum, while
the current driver accesses wrongly via value.integer.value[]. They
have to be via value.enumerated.item[] instead.
Signed-off-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
We try to check that "deemph" is zero or one, but because of an
underflow bug, it can also be negative. It's fine, negative values are
handled as non-zero. But it's messy and static checkers complain so
let's fix it.
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
'asoc/topic/wm8904', 'asoc/topic/wm8960' and 'asoc/topic/wm8983' into asoc-next
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
clk_prepare_enable() may fail, so we should better check its return value
and propagate it in the case of error.
The dapm field of the snd_soc_codec struct is eventually going to be
removed, in preparation for this replace all manual access to
codec->dapm.bias_level with snd_soc_codec_get_bias_level() and replace all
other manual access to codec->dapm with snd_soc_codec_get_dapm().
All drivers have the same line at the end of the set_bias_level callback to
update the bias_level state. Move this update into
snd_soc_dapm_force_bias_level() and remove them from the drivers.
The correct values referred by a boolean control are
value.integer.value[], not value.enumerated.item[].
The former is long while the latter is int, so it's even incompatible
on 64bit architectures.
Cc: <stable@vger.kernel.org>
'asoc/topic/wm8804' and 'asoc/topic/wm8904' into asoc-next
The WM8904 and WM8918 has the same data type, while the WM8912
has different data type. So, use the data in dt ids table to
distinguish them.
Signed-off-by: Alexander Morozov <linux@meltdown.ru>
[voice.shen@atmel.com: add code to distinguish device type]
Signed-off-by: Bo Shen <voice.shen@atmel.com>
The codec field of the snd_soc_widget struct is eventually going to be
removed, use snd_soc_dapm_to_codec(w->dapm) instead.
Correct the path name for mux to get rid of the following warning:
--->8---
wm8904 1-001a: Control not supported for path ADCL -> [Left] -> AIFOUTL
wm8904 1-001a: ASoC: no dapm match for ADCL --> Left --> AIFOUTL
wm8904 1-001a: ASoC: Failed to add route ADCL -> Left -> AIFOUTL
wm8904 1-001a: Control not supported for path ADCR -> [Right] -> AIFOUTL
wm8904 1-001a: ASoC: no dapm match for ADCR --> Right --> AIFOUTL
wm8904 1-001a: ASoC: Failed to add route ADCR -> Right -> AIFOUTL
wm8904 1-001a: Control not supported for path ADCL -> [Left] -> AIFOUTR
wm8904 1-001a: ASoC: no dapm match for ADCL --> Left --> AIFOUTR
wm8904 1-001a: ASoC: Failed to add route ADCL -> Left -> AIFOUTR
wm8904 1-001a: Control not supported for path ADCR -> [Right] -> AIFOUTR
wm8904 1-001a: ASoC: no dapm match for ADCR --> Right --> AIFOUTR
wm8904 1-001a: ASoC: Failed to add route ADCR -> Right -> AIFOUTR
wm8904 1-001a: Control not supported for path AIFINR -> [Right] -> DACL
wm8904 1-001a: ASoC: no dapm match for AIFINR --> Right --> DACL
wm8904 1-001a: ASoC: Failed to add route AIFINR -> Right -> DACL
wm8904 1-001a: Control not supported for path AIFINL -> [Left] -> DACL
wm8904 1-001a: ASoC: no dapm match for AIFINL --> Left --> DACL
wm8904 1-001a: ASoC: Failed to add route AIFINL -> Left -> DACL
wm8904 1-001a: Control not supported for path AIFINR -> [Right] -> DACR
wm8904 1-001a: ASoC: no dapm match for AIFINR --> Right --> DACR
wm8904 1-001a: ASoC: Failed to add route AIFINR -> Right -> DACR
wm8904 1-001a: Control not supported for path AIFINL -> [Left] -> DACR
wm8904 1-001a: ASoC: no dapm match for AIFINL --> Left --> DACR
wm8904 1-001a: ASoC: Failed to add route AIFINL -> Left -> DACR
---8<---
'asoc/topic/wm0010', 'asoc/topic/wm8904' and 'asoc/topic/wm8962' into asoc-next
The CODEC doesn't care how data is laid out in memory.
Signed-off-by: Mark Brown <broonie@linaro.org>
Let memory subsystem handle the error logging.
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
Enable WM8904 to support common clock framework.
For CODEC controls snd_kcontrol_chip() currently returns a pointer to the
CODEC that registered the control. With the upcoming consolidation of
platform and CODEC controls this will change. Prepare for this by introducing
the snd_soc_kcontrol_codec() helper function that will hide the implementation
details of how the CODEC for a control can be obtained. This will allow us to
change this easily in the future.
The patch also updates all CODEC drivers to use the new helper function.
'asoc/topic/wm8731', 'asoc/topic/wm8737', 'asoc/topic/wm8741', 'asoc/topic/wm8753', 'asoc/topic/wm8903', 'asoc/topic/wm8904', 'asoc/topic/wm8940' and 'asoc/topic/wm8955' into asoc-next
For some CODEC drivers like who act as the MFDs children are ignored
by this patch.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
Just replace with the helper macro. No functional change at all.
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
The name "max" in struct soc_enum is rather confusing since it
actually takes the number of items. With "max", one might try to
assign (nitems - 1) value.
Rename the field to a more appropriate one, "items", which is also
used in struct snd_ctl_elem_info, too.
This patch also rewrites some code like "if (x > e->nitems - 1)" with
"if (x >= e->nitems)". Not only the latter improves the readability,
it also fixes a potential bug when e->items is zero.
When wm8904 work in DSP mode B, we still need to configure it to
work in DSP mode. Or else, it will work in Right Justified mode.
Cc: stable@vger.kernel.org
BUG() used in the driver is just to spit the stack trace on buggy
points, not really needed to stop the whole operation. For that
purpose, it'd be more convenient to use WARN() instead with more
error information.
Cc: patches@opensource.wolfsonmicro.com
Use WARN_ON() and handle the error cases accordingly.
The core will call snd_soc_dapm_new_widgets() once all components of the card
have been initialized, so there is no need to do this manually in the driver.
Calling it earlier also might result in a partially instantiated system being
powered up which cause undesired side effects.
fix the typo error, from "LINEL Mux" to "LINER Mux"
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Linux 3.6-rc6 has all our bug fixes.
Conflicts (trivial overlap):
sound/soc/omap/am3517evm.c
The core_intercon is added two times, remove the redundant one
Get it done as early as possible, it's neater and minimises the time the
pins aren't configured as requested.
It's more idiomatic to have the resource allocation at this level.
Even though the WM8904 is able to use idle_bias_off during both probe
and resume we were needlessly leaving the device in standby mode. Instead
power the device down as soon as we've confirmed that we can talk to it
and don't manage the bias level at all over suspend and resume, the core
will take us down to our minimum power level.
Linux 3.5-rc4 contains some bug fixes which overlap with new features.
We should be using the regmap API consistently for all the cache only
configuration and we should be going cache only before we power down
the supplies.
We no longer have a flat ASoC cache so can't peer directly into the array
any more but should instead use the register I/O functions to update the
cache.
Cc: stable@vger.kernel.org (v3.4)
Currently ASoC can only add kcontrols using codec and platform component device
handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for
SoC card machine drivers too. This allows the kcontrol to have a direct handle to
the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily
get it's private data.
This change makes snd_soc_add_controls() static and wraps it in the folowing
calls (card and dai are new) :-
snd_soc_add_card_controls()
snd_soc_add_codec_controls()
snd_soc_add_dai_controls()
snd_soc_add_platform_controls()
This patch also does a lot of small mechanical changes in individual codec drivers
to replace snd_soc_add_controls() with snd_soc_add_codec_controls().
It also updates the McBSP DAI driver to use snd_soc_add_dai_controls().
Finally, it updates the existing machine drivers that register controls to either :-
1) Use snd_soc_add_card_controls() where no direct codec control is required.
2) Use snd_soc_add_codec_controls() where there is direct codec control.
In the case of 1) above we also update the machine drivers to get the correct
component data pointers from the kcontrol (rather than getting the machine pointer
via the codec pointer).
Signed-off-by: Liam Girdwood <lrg@ti.com>
Since commit 33c5f969 "ASoC: Allow idle_bias_off to be specified in CODEC
drivers", now we can set idle_bias_off flag in struct snd_soc_codec_driver
for devices can unconditionally support idle_bias_off.
The device has a very sparse register map so should benefit from using a
rbtree cache.
