commit 0b7dd6ad92b6cace35dc5d06d6e236c2751c85dc upstream.
commit 2af8de8c39cf58e5a5e40a9d5d71332da98e6ba7 upstream.
Since there is no current software control for these they would otherwise
be left enabled, consuming power.
commit 4f4488abc97c1c27ff029f887944e6a6da1f5733 upstream.
The WM8962 has a separate software reset for the PLL registers. Ensure that
these are reset also on startup.
commit fbc7c62a3ff831aef24894b7982cd1adb2b7e070 upstream.
Signed-off-by: Susan Gao <sgao@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmico.com>
commit 38f3f31a0a797bdbcc0cdb12553bbecc2f9a91c4 upstream.
Also fix return values for speaker switch updates.
This functionality is now subsumed within the bias management, using the
standard cache management functionality, without assuming the cache type.
Acked-by: Liam Girdwood <lrg@ti.com>
Ensure that we don't spuriously trigger early.
When the clocking registers are not overriden some of the registers are
not writable.
Cc: stable@kernel.org
This closes the small race between a status being read in response to an
interrupt and clearing the interrupt, meaning that if the status changes
between those periods we might not get a reassertion of the interrupt.
Don't require an audio rate SYSCLK in hw_params() in order to better
support microphone detection use cases.
ReTune Mobile modes are not currently supported.
We really should be getting the interrupt - if we don't get one it's very
likely that the configuration is incorrect and audio will fail. Also
increase the timeout substantially in this case for safety.
The chip can actually support SPI so we shouldn't assume we've got an I2C
device even though that's the most common configuration.
When bringing up audio low power modes boards may configure SYSCLK before
they actually start the FLL as we do much of the clocking setup prior to
the power up sequence.
DMIC support is automatically disabled when none of the GPIOs are set up
to bring out the DMICCLK and DMICDAT pins at startup.
Note that there's no support for controlling DMIC routing except the power
control so the board DAPM configuration will need to manage DMIC enable and
disable if analogue mics (eg, a headset) also exist.
There's only one DAI anyway.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Directly accessing the register cache means that we can't use anything
except a flat register cache so use snd_soc_update_bits().
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
The multi-component patch(commit f0fba2ad1) moved the allocation of the
register cache from the driver to the ASoC core. Most drivers where adjusted to
this, but the wm8962 driver still uses its own register cache for its
private functions, while functions from the ASoC core use the generic cache.
Thus we end up with two from each other incoherent caches, which can lead to
undefined behaviour.
This patch fixes the issue by changing the wm8962 driver to use the
generic register cache in its private functions.
Cc: stable@kernel.org (for 2.6.37 only)
No idea why this works on ARM but not x86.
Add jack detection interrupt trace to Wolfson CODEC drivers.
sound/soc/soc-core.c
Axel's fix on two different branches.
Fix mismerge from the out of tree BSP where this support was developed.
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
We allocated memory for wm8962 in wm8962_i2c_probe,
and will free the memory in either wm8962_i2c_probe error path
or wm8962_i2c_remove.
Thus we should not call kfree(wm8962) in wm8962_probe, otherwise
we have double free of wm8962.
The value makes no odds and it makes life easier with caches.
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Ensure that the system does not suspend while we process a WM8962 jack
event by using pm_wakeup_event() to block the suspend while we're waiting
for the jack to settle. Use a slightly longer timeout than the jack waits
to allow for other stuff to take over and delays in scheduling.
strict_strtoul() has been made __must_check so do so.
We unconditionally require SYSCLK since while only microphone detection
specifically requires SYSCLK any actual use case would enable it via
some other means but microphone detection may have nothing active other
than the bias itself.
Reduce the source code size still futher by only specifying non-zero
rows in the WM8962 access map.
Dramatically reduce the code size for the WM8962 register defaults table
by switching to explicitly initialise only defined registers, relying on
static defaulting to zero for the overwelming bulk of the register map.
Similar treatement for the register access table will come later and will
produce a similarly dramatic code size shrink.
GPIO2 and GPIO3 on the WM8962 are MFPs and need to be put into GPIO mode
before the GPIO block can be used to control them. We're already doing
this when used via gpiolib, factor out the code for use when setting static
configurations via platform data as well.
Allow microphone detection on WM8962 to be performed using the interrupt
signal, allowing the detection of both microphone presence and button
presses with a signal singal from the CODEC to CPU. Currently a 250ms
debounce time is applied to both short circuit and presence detection,
this has not been optimised.
The WM8962 features five GPIOs, add support for controlling their output
state via gpiolib.
The restrictions on configuring BCLK are overly cautious, other constraints
in the system should ensure that reconfiguration is not possible when the
device is sufficiently active to be unable to support reclocking.
Add the widget for MICBIAS power control and allow configuration of the
microphone bias setup via the platform data for the WM8962. When
microphone status signals are brought out to GPIO this should be
sufficient to enable microphone detection.
Provide an initial hookup for interrupts on the WM8962. Currently we simply
report error status via log messages if an IRQ is provided for the device.
For consistency.
When configuring the FLL we preserve the FLL enable configuration in order
to allow us to reenable the FLL after configuration but we do not clear
the other bits in the register, causing old configuration to be preserved.
