path: root/sound/soc/codecs/wm8988.c
2010-09-30ASoC: Remove unneeded use of spi_bus_typeDimitris Papastamos
No need to explicitly set the bus type, spi_register_driver does that for us. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-10ASoC: Fix incorrect register cache size configurationDimitris Papastamos
The reg_cache_size is the number of elements in the register cache, not the size of the cache itself. This is not a problem if the size of each element of the cache is 1 byte but it matters in any other case. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: Remove unneeded control_data management from Wolfson driversMark Brown
Now soc-cache.c can figure out the I2C and SPI control data from the device for the CODEC we don't need to manually assign it in drivers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-14ASoC:: remove a redundant snd_soc_unregister_codec call in wm8988_registerAxel Lin
snd_soc_unregister_codec is called twice if snd_soc_register_dai fail. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-04-17ASoC: Add indirection for CODEC private dataMark Brown
One of the features of the multi CODEC work is that it embeds a struct device in the CODEC to provide diagnostics via a sysfs class rather than via the device tree, at which point it's much better to use the struct device private data rather than having two places to store it. Provide an accessor function to allow this change to be made more easily, and update all the CODEC drivers are updated. To ensure use of the accessor the private data structure member is renamed, meaning that if code developed with older an older core that still uses private_data is merged it will fail to build. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-12ASoC: Remove redundant snd_soc_dapm_new_widgets() callsMark Brown
The DAPM widgets are now insntantiated by the core when creating the card so there is no need for the individual CODEC drivers to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-10-15ASoC: Remove snd_soc_suspend_device()Mark Brown
The PM core will grow pm_link infrastructure in 2.6.33 which can be used to implement the intended functionality of the ASoC-specific device suspend and resume callbacks so drop them. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-09-10Merge branch 'topic/asoc' into for-linusTakashi Iwai
* topic/asoc: (226 commits) ASoC: au1x: PSC-AC97 bugfixes ASoC: Fix WM835x Out4 capture enumeration ASoC: Remove unuused hw_read_t ASoC: fix pxa2xx-ac97.c breakage ASoC: Fully specify DC servo bits to update in wm_hubs ASoC: Debugged improper setting of PLL fields in WM8580 driver ASoC: new board driver to connect bfin-5xx with ad1836 codec ASoC: OMAP: Add functionality to set CLKR and FSR sources in McBSP DAI ASoC: davinci: i2c device creation moved into board files ASoC: Don't reconfigure WM8350 FLL if not needed ASoC: Fix s3c-i2s-v2 build ASoC: Make platform data optional for TLV320AIC3x ASoC: Add S3C24xx dependencies for Simtec machines ASoC: SDP3430: Fix TWL GPIO6 pin mux request ASoC: S3C platform: Fix s3c2410_dma_started() called at improper time ARM: OMAP: McBSP: Merge two functions into omap_mcbsp_start/_stop ASoC: OMAP: Fix setup of XCCR and RCCR registers in McBSP DAI OMAP: McBSP: Use textual values in DMA operating mode sysfs files ARM: OMAP: DMA: Add support for DMA channel self linking on OMAP1510 ASoC: Select core DMA when building for S3C64xx ...
2009-08-03ASoC: Factor out 7 bit register 9 bit data SPI writeMark Brown
This converts all the Wolfson drivers using this format (the only devices that do) except WM8753 to use it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Add I/O control bus information to factored out cache setupMark Brown
While writes tend to be able to use a fairly bus independant format to do the writes reads are all bus specific. To allow us to factor out this code include the bus type as a parameter when setting up the cache. Initially just use this to factor out hw_write_t for I2C. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-12Sound: remove direct access of driver_dataGreg Kroah-Hartman
This is the last in-kernel direct usage of driver_data, replace it with the proper dev_get/set_drvdata() calls. Cc: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@perex.cz> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-05ASoC: Begin to factor out register cache I/O functionsMark Brown
A lot of CODECs share the same register data formats and therefore replicate the code to manage access to and caching of the register map. In order to reduce code duplication centralised versions of this code will be introduced with drivers able to configure the use of the common code by calling the new snd_soc_codec_set_cache_io() API call during startup. As an initial user the 7 bit address/9 bit data format used by many Wolfson devices is supported for write only CODECs and the drivers with straightforward register cache implementations are converted to use it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-05ASoC: Fix leaks in WM8988 registration error handlingMark Brown
2009-06-13ASoC: Add suspend and resume callbacks to Wolfson CODEC driversMark Brown
2009-04-07ASoC: Add WM8988 CODEC driverMark Brown
The WM8988 is a low power, high quality stereo CODEC designed for portable digital audio applications. The device integrates complete interfaces to 2 stereo headphone or line out ports. External component requirements are drastically reduced as no separate headphone amplifiers are required. Advanced on-chip digital signal processing performs graphic equaliser, 3-D sound enhancement and automatic level control for the microphone or line input. The WM8988 can operate as a master or a slave, with various master clock frequencies including 12 or 24MHz for USB devices, or standard 256fs rates like 12.288MHz and 24.576MHz. Different audio sample rates such as 96kHz, 48kHz, 44.1kHz are generated directly from the master clock without the need for an external PLL. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
