path: root/sound/soc/codecs/wm8990.c
2011-01-17ASoC: WM8990: msleep() takes milliseconds not jiffiesDimitris Papastamos
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-15ASoC: Remove needless codec->bias_level assignment to SND_SOC_BIAS_OFFJarkko Nikula
This assignment is done by the snd_soc_register_codec so there is no need to redo it in probe function of a codec driver. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: Remove unneeded control_data management from Wolfson driversMark Brown
Now soc-cache.c can figure out the I2C and SPI control data from the device for the CODEC we don't need to manually assign it in drivers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-31Merge commit 'v2.6.35-rc1' into for-2.6.36Mark Brown
2010-05-27Merge branch 'for-2.6.35' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into fix/asoc
2010-05-26ASoC: Fix dB scales for WM8990Mark Brown
These should be regular, not linear. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Cc: stable@kernel.org
2010-05-25ASoC: Fix dB scales for WM8990Mark Brown
These should be regular, not linear. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2010-05-25ASoC: Remove version display from WM8990Mark Brown
It's not needed and the version number never gets updated anyway. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-04-17ASoC: Add indirection for CODEC private dataMark Brown
One of the features of the multi CODEC work is that it embeds a struct device in the CODEC to provide diagnostics via a sysfs class rather than via the device tree, at which point it's much better to use the struct device private data rather than having two places to store it. Provide an accessor function to allow this change to be made more easily, and update all the CODEC drivers are updated. To ensure use of the accessor the private data structure member is renamed, meaning that if code developed with older an older core that still uses private_data is merged it will fail to build. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-31ASoC: Remove unneeded suspend checks from CODEC driversMark Brown
Better integration of the core with the device model means that we now no longer get the ASoC suspend and resume callbacks without the card having been set up. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-11-12ASoC: Remove redundant snd_soc_dapm_new_widgets() callsMark Brown
The DAPM widgets are now insntantiated by the core when creating the card so there is no need for the individual CODEC drivers to do so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-03ASoC: Factor out snd_soc_init_card()Mark Brown
snd_soc_init_card() is always called as the last part of the CODEC probe function so we can factor it out into the core card setup rather than have each CODEC replicate the code to do the initialiastation. This will be required to support multiple CODECs per card. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-09-05ASoC: Add source argument to PLL configurationMark Brown
More and more devices feature PLLs and FLLs with the ability to select between multiple input clocks. In order to better support these devices a new argument, source, has been added to the set_pll() configuration API. Using set_clkdiv() is often difficult due to the need to stop the PLL/FLL before any reconfiguration can be done. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-08-03ASoC: Factor out I/O for Wolfson 8 bit data 16 bit register CODECsMark Brown
2009-05-28ASoC: correct print specifiers for unsignedsRoel Kluin
Unsigned variables should use `%u' rather than `%d'. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-05ASoC: Fix errors in WM8990Jinyoung Park
The mis-typing exist in dapm controller definitions and dapm route definitions, so happen mis-matched error when snd_soc_dapm_add_routes(). Cc: stable@kernel.org Signed-off-by: Jinyoung Park <parkjy@mtekvision.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com
2009-03-04ASoC: make ops a pointer in 'struct snd_soc_dai'Eric Miao
Considering the fact that most cpu_dai or codec_dai are using a same 'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better made a pointer instead, to make sharing easier and code a bit cleaner. The patch below is rather preliminary since the asoc tree is being actively developed, and this touches almost every piece of code, (and possibly many others in development need to be changed as well). Building of all codecs are OK, yet to every SoC, I didn't test that. Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-06Merge branch 'for-2.6.29' into for-2.6.30Mark Brown
2009-02-06ASoC: WM8990: Fix kcontrol's private value use in put callbackJarkko Nikula
Function wm899x_outpga_put_volsw_vu misuses the kcontrol's private value by still accessing it as bitfields even SOC_SINGLE_VALUE constructs it as a pointer into struct soc_mixer_control after the commit 4eaa9819dc08d7bfd1065ce530e31b18a119dcaf. This is very similar fix than fix to TLV320AIC3X codec made by Eero Nurkkala <ext-eero.nurkkala@nokia.com>. This fix is compile tested only. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-03Merge branch 'fix/asoc' into topic/asocTakashi Iwai
2009-02-03ALSA: ASoC: email - update email addresses.Liam Girdwood
This just updates my email address on some drivers I'd forgotten in a previous patch. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-27ASoC: Push the codec runtime storage into the card structureMark Brown
This is a further stage on the road to refactoring away the ASoC platform device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-19ASoC: fixes to caching implementationsIan Molton
This patch takes fixes a number of bugs in the caching code used by several ASoC codec drivers. Mostly off-by-one fixes. Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-01-09ASoC: cleanup duplicated code.Ian Molton
Many codec drivers were implementing cookie-cutter copies of the function that adds kcontrols to the codec. This patch moves this code to a common function snd_soc_add_controls() in soc-core.c and updates all drivers using copies of this function to use the new common version. [Edited to raise priority of error log message and document parameters. -- broonie] Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-10ALSA: ASoC - Fix wrong section typesTakashi Iwai
The module init entries should be __init instead of __devinit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-09ASoC: Register non-AC97 codec DAIsMark Brown
Currently this is done at module probe time since ASoC ties in codec device probe to the instantiation of the entire ASoC device. Subsequent patches will refactor the codec drivers to handle probing separately. Note that the core does not yet use this information. AC97 is special since the codec is controlled over the AC97 link but we want to give the machine driver a chance to set up the system before trying to instantiate since it may need to do configuration before the AC97 link will operate Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-01ASoC: Rename snd_soc_register_card() to snd_soc_init_card()Mark Brown
Currently ASoC card initialisation is completed by a function called snd_soc_register_card(). As part of the work to allow independant registration of cards, codecs and machines in ASoC v2 a new function of the same name has been added so rename the existing function to facilitate the merge of v2. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-21ASoC: Merge snd_soc_ops into snd_soc_dai_opsMark Brown
Liam Girdwood's ASoC v2 work avoids having two different ops structures for DAIs by merging the members of struct snd_soc_ops into struct snd_soc_dai_ops, allowing per DAI configuration for everything. Backport this change. This paves the way for future work allowing any combination of DAIs to be connected rather than having fixed purpose CODEC and CPU DAIs and only allowing CODEC<->CPU interconnections. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-17ASoC: Manage VMID mode for WM8990Mark Brown
A small additional power saving can be achieved for the WM8990 by maintaining VMID using a 2*250k divider when in standby mode. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-17ASoC: Enable WM8990 ADC clocking workaroundMark Brown
Enable a hardware workaround which avoids problems with the clocking of the ADCs in certain configurations. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-17ASoC: Allow writes to uncached registers in WM8990Mark Brown
Only fully documented registers are cached in the WM8990 but additional registers exist. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-10-13ALSA: ASoC: Remove unused AUDIO_NAME define from codec driversJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-09-04ALSA: ASoC: Don't suggest compile time selection of codec accessMark Brown
Currently the boiler plate code used by most ASoC codecs to provide a placeholder for SPI access suggests making the selection of SPI a compile time option which is suboptimal when trying to build kernels supporting multiple systems. Change this template to suggest allowing runtime selection instead. Leave the drivers not yet converted to new style I2C access for now to avoid collisions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-09-04ALSA: ASoC: Convert wm8990 to a new-style i2c driverJean Delvare
Convert the wm8990 codec driver to the new (standard) device driver binding model. After this change, WM8990 devices are no longer discovered automatically and must instead be instantiated explicitly. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-25ALSA: ASoC: Fix double free and memory leak in many codec driversJean Delvare
Many SoC audio codec drivers have improper freeing of memory in error paths. * codec is allocated in the platform device probe function, but is not freed there in case of error. Instead it is freed in the i2c device probe function's error path. However the success or failure of both functions is not linked, so this could result in a double free (if the platform device is successfully probed, the i2c device probing fails and then the platform driver is unregistered.) * codec->private_data is allocated in many platform device probe functions but not freed in their error paths. This patch hopefully solves all these problems. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-15ALSA: wm8990: Implement speaker volume PGAMark Brown
The latest revisions of the WM8990 provide a programmable gain amplifier for the speaker - configure the register cache and implement controls for this. Older revisions of the device ignore writes to these controls. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-15ALSA: wm8990: Fix routing of left DAC to speaker mixerMark Brown
2008-07-10ALSA: asoc: codecs - merge structs snd_soc_codec_dai and snd_soc_cpu_dai.Liam Girdwood
This patch merges struct snd_soc_codec_dai and struct snd_soc_cpu_dai into struct snd_soc_dai for the codec drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-26ALSA: ASoC: Replace custom debug macros with pr_ equivalentsMark Brown
Several ASoC codec drivers use custom macros equivalent to the standard pr_ macros, most of which are not actually used. Replace these custom macros with the standard ones. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-06-06[ALSA] ASoC: Add WM8990 driverMark Brown
The WM8990 is a highly integrated ultra-low power hi-fi codec designed for handsets rich in multimedia features such as mobile TV, digital audio playback and gaming. The bulk of this driver was written by Liam Girdwood with some additional development and updates for new ASoC APIs by me. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
