2009-05-23 | ASoC: Fix WM9081 PowerPC compiler issues | Mark Brown | |
Ensure that we always set a new sysclk when using the FLL in master mode and pick out the correct value for the sample rate in hw_params(). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> | |||
2009-05-22 | ASoC: WM9081 mono DAC with integrated 2.6W class AB/D amplifier driver | Mark Brown | |
The WM9081 is designed to provide high power output at low distortion levels in space-constrained portable applications. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> |
