Now we can replace Codec to Component. Let's do it.
Note:
xxx_codec_xxx() -> xxx_component_xxx()
.idle_bias_off = 0 -> .idle_bias_on = 1
.ignore_pmdown_time = 0 -> .use_pmdown_time = 1
- -> .endianness = 1
- -> .non_legacy_dai_naming = 1
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Check for snd_soc_codec_driver structures that are only passed to
snd_soc_register_codec or memcpy (2nd arg), for which the corresponding
parameters are declared const. Declare as const snd_soc_codec_driver
structures that have these properties.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct snd_soc_codec_driver i@p = { ... };
@ok@
identifier r.i;
expression e1,e2,e3;
position p;
snd_soc_register_codec(e1,&i@p,e2,e3)
memcpy(e1,&i@p,e2)
@bad@
position p != {r.p,ok.p};
identifier r.i;
i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct snd_soc_codec_driver i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
'asoc/topic/tegra', 'asoc/topic/tlv' and 'asoc/topic/topology' into asoc-next
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD()
that it automatically calculates the number of items in the TLV and is
hence less prone to manual error.
Generate using the following coccinelle script
// <smpl>
declarer name DECLARE_TLV_DB_RANGE;
identifier tlv;
constant x;
-unsigned int tlv[] = {
- TLV_DB_RANGE_HEAD(x),
+DECLARE_TLV_DB_RANGE(tlv,
// </smpl>
i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
The dapm field of the snd_soc_codec struct is eventually going to be
removed, in preparation for this replace all manual access to
codec->dapm.bias_level with snd_soc_codec_get_bias_level() and replace all
other manual access to codec->dapm with snd_soc_codec_get_dapm().
All drivers have the same line at the end of the set_bias_level callback to
update the bias_level state. Move this update into
snd_soc_dapm_force_bias_level() and remove them from the drivers.
The codec field of the snd_soc_widget struct is eventually going to be
removed, use snd_soc_dapm_to_codec(w->dapm) instead.
Set the CODEC driver's suspend_bias_off flag rather than manually going to
SND_SOC_BIAS_OFF in suspend and SND_SOC_BIAS_STANDBY in resume. This makes
the code a bit shorter and cleaner.
Since the ASoC core now takes care of setting the bias level to
SND_SOC_BIAS_OFF when removing the CODEC there is no need to do it manually
anymore either.
The manual transition to SND_SOC_BIAS_STANDBY at the end of CODEC probe()
can also be removed as the core will automatically do this after the CODEC
has been probed.
Let memory subsystem handle the error logging.
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
For some CODEC drivers like who act as the MFDs children are ignored
by this patch.
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
devm_regmap_init_i2c() is device managed and makes error
handling and code cleanup simpler.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
module_i2c_driver makes the code simpler by eliminating module_init
and module_exit calls.
Show the id we read when the id mismatch is detected.
This is useful for debugging.
Currently ASoC can only add kcontrols using codec and platform component device
handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for
SoC card machine drivers too. This allows the kcontrol to have a direct handle to
the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily
get it's private data.
This change makes snd_soc_add_controls() static and wraps it in the folowing
calls (card and dai are new) :-
snd_soc_add_card_controls()
snd_soc_add_codec_controls()
snd_soc_add_dai_controls()
snd_soc_add_platform_controls()
This patch also does a lot of small mechanical changes in individual codec drivers
to replace snd_soc_add_controls() with snd_soc_add_codec_controls().
It also updates the McBSP DAI driver to use snd_soc_add_dai_controls().
Finally, it updates the existing machine drivers that register controls to either :-
1) Use snd_soc_add_card_controls() where no direct codec control is required.
2) Use snd_soc_add_codec_controls() where there is direct codec control.
In the case of 1) above we also update the machine drivers to get the correct
component data pointers from the kcontrol (rather than getting the machine pointer
via the codec pointer).
Signed-off-by: Liam Girdwood <lrg@ti.com>
Devices that aren't MFDs don't need to distinguish this.
The existence of this parameter is purely historical. None of the CODEC drivers
uses it and we always pass in the same value anyway, so it should be safe to
remove it.
Acked-by: Liam Girdwood <lrg@ti.com>
Give the correct number of entries to TLV_DB_RANGE_HEAD to prevent
reading more data than actually is in the arrays.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Eliminate below build warning:
CC sound/soc/codecs/wm9090.o
sound/soc/codecs/wm9090.c: In function 'wm9090_probe':
sound/soc/codecs/wm9090.c:550: warning: unused variable 'wm9090'
The control_data field is used to initialize the codec's control_data field,
but since this is also done by the snd-soc-cache core, the redundant
assignment can be removed and the field can be dropped.
The WM9093 is an enhanced version of the WM9093. Add the device ID to
the driver, further patches will add support for the additional features
in the WM9093.
Directly accessing the register cache means that we can't use anything
except a flat register cache so use snd_soc_update_bits().
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
The multi-component patch(commit f0fba2ad1) moved the allocation of the
register cache from the driver to the ASoC core. Most drivers where adjusted to
this, but the wm9090 driver still uses its own register cache for its
private functions, while functions from the ASoC core use the generic cache.
Thus we end up with two from each other incoherent caches, which can lead to
undefined behaviour.
This patch fixes the issue by changing the wm9090 driver to use the
generic register cache in its private functions.
Cc: stable@kernel.org (for 2.6.37 only)
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
This fixes the following warning:
sound/soc/codecs/wm9090.c:668:12: warning: 'wm9090_i2c_remove' defined but not used
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The WM9090 is a high performance low power audio subsystem, including
headphone and class D speaker drivers.
Note that this driver is a standalone CODEC driver and so is only
immediately suitable for use with the WM9090 as a standalone sound card
taking line inputs, or with a DAC with no software control. The pending
ASoC multi-CODEC support will expand the range of systems that can use
the driver, or system-specific adaptations can be made.
