[ Upstream commit 85a7555575a0e48f9b73db310d0d762a08a46d63 ]
The error handling frees "ctl" but it's still on the "dsp->ctl_list"
list so that could result in a use after free. Remove it from the list
before returning.
Fixes: 2323736dca72 ("ASoC: wm_adsp: Add basic support for rev 1 firmware file format")
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Link: https://lore.kernel.org/r/X9B0keV/02wrx9Xs@mwanda
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 1cab2a84f470e15ecc8e5143bfe9398c6e888032 ]
Protect against corrupt firmware files by ensuring that the length we
get for the data in a region actually lies within the available firmware
file data buffer.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
The rate controls are codec-specific, it's not possible to
generically say what the range or the meaning of each control
is (or even if they exist at all) - that depends on the
particular codec.
This is currently being handled for Arizona codecs by putting
an Arizona-specific table of controls inside the wm_adsp driver.
This creates a dependency between wm_adsp and arizona.c, and is an
awkward solution if the ADSP is used in another family of codecs
Fix this by moving the Arizona-specific rate controls into the
Arizona codec drivers.
This patch adds some debugfs nodes to get information
about the currently running firmware.
Now that we have a codec_probe stage initialization in the wm_adsp
driver, we can make the wm_adsp driver create its own ALSA controls
instead of having that responsibility pushed to every codec driver.
Currently the only init function in wm_adsp is called by the
codec driver early in its probe before the codec has been
registered with SOC.
This patch adds stubs for the codec_probe and codec_remove stages
and calls them from WM5102 and WM5110 codec drivers. This allows us
to hang anything that needs setup during the codec probe stage off
these functions without further modification of the codec drivers.
In theory the ADSP driver should not need to know anything
about the codec it is part of. But the WM5102 needs DVFS
control based on ADSP clocking speed. This was being handled
by bundling part of the knowledge of this into the ADSP driver.
This change moves this handling out of the ADSP driver and
into the WM5102 driver.
The SCRATCH registers are used by firmwares to hold diagnostic
information. Log this during shutdown to assist analysis and debug
of firmwares.
The DSP control information contains various hints about the usage of
the control use these when handling the control.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Using uXX for little endian data, was triggering some warnings through
sparse:
sound/soc/codecs/wm_adsp.c:716:26: sparse: cast to restricted __le16
sound/soc/codecs/wm_adsp.c:736:23: sparse: cast to restricted __le16
sound/soc/codecs/wm_adsp.c:739:23: sparse: cast to restricted __le32
Correct this by changing the casts to use __leXX instead of uXX.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
There are very few version 0 firmwares in the wild and at some point in
the future it would be nice to remove support for them from the driver,
as they require several work arounds to be present to create controls
properly.
This patch adds a depreciated warning if someone is using this file
format.
Version 2 of the firmware file format includes length fields for the
various strings associated with control creation, to reduce file size.
However this does increase the parsing complexity slightly. This patch
adds support for the revision of the file format.
This patch also adds a new naming scheme for controls created from rev 2
firmware files. This version of the file format is commonly used to
add multiple controls per algorithm per memory region and the old
control naming scheme would cause multiple controls to have the same
name in this case.. Note that the naming scheme for older firmware
versions is left intact to ensure backwards compatibility.
Revision one of the file format includes new algorithm and coefficient
blocks which provide additional information about the controls exported
by the firmware. This patch updates the processing to handle this
version of the file format. Note that whilst this version of the format
adds support for specifying a name for the control through the firmware
file this has not been used and to keep compatibility with existing
deployments no changes to the firmware control naming are made by this
patch.
This is slightly logically better and avoids some unnecessary forward
declarations in the following refactoring.
The private field in wm_coeff_ctl is currently unused and given the
controls are entirely handled within the ADSP code it is not clear what
it would be used for in the future. Remove the field for now it can be
readded if it is ever required.
Tidy up the code a little by factoring out the creation of the algorithm
regions.
Physically reading and writing controls to/from the DSP are handled by
two low level functions (wm_coeff_{write|read}_control, these currently
take in a snd_kcontrol pointer but immediately pull out a wm_coeff_ctl
pointer from the private data. These functions don't handle the kcontrols
at all they just shuttle data to and from the chip and all the call
sites have a wm_coeff_ctl pointer available. This patch just passes the
wm_coeff_ctl pointer straight into these functions.
Now we only allocate 44 bytes for the control name keep it on the stack
to avoid a lot of pointless memory allocation.
ALSA only supports control names up to 44 bytes, so there is no point
allocating a whole page of memory to hold the control name, just limit
the control name to 44 bytes.
The algorithm region information in the firmware doesn't contain a
length field, explicitly pass this to the create_control function rather
than bundling into wm_adsp_alg_region.
We have wm_adsp_region, wm_adsp_alg_region, and wmfw_region, the
variables for which are all frequently called region, this can get quite
confusing when reviewing the code especially given some functions are
quite long. Consistently use mem for wm_adsp_regions, alg_region for
wm_adsp_alg_region and region for wmfw_region.
Additionally, we use a mix of adsp and dsp for pointers to the wm_adsp
structure standardise this on dsp.
Finally, we use algs to refer to the number of algorithms quite
frequently, change this to the more descriptive n_algs.
The vast majority of the wm_adsp_setup_algs function is case statements
for ADSP1 or ADSP2, this patch splits this out into two separate
functions wm_adsp1_setup_algs and wm_adsp2_setup_algs. The small amount
of shared code between them is factored out into an extra helper
function. This makes the code a lot cleaner.
'asoc/topic/simple', 'asoc/topic/tegra' and 'asoc/topic/wm-adsp' into asoc-next
Whilst the existing code does correctly round to the next 4-byte boundary
it does so rather inefficiently. This patch changes the rounding to be
simpler and more efficient.
Currently DSP controls are persistent (across DSP On/Off) only
if they were set whilst the DSP is off. This change makes the
controls persistent irrespective of when they are set.
Signed-off-by: Nikesh Oswal <Nikesh.Oswal@wolfsonmicro.com>
The codec field of the snd_soc_widget struct is eventually going to be
removed, use snd_soc_dapm_to_codec(w->dapm) instead.
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
'asoc/topic/ak4535', 'asoc/topic/ak4641' and 'asoc/topic/ak4642' into asoc-next
Many firmwares do not wait for the start bit before they begin
processing audio, whilst this is a bug on the firmware side there are
too many such firmwares in the wild to ignore the situation. This patch
moves the core enable to happen at same time as the start, the firmware
looses the ability to overlap its own startup with the audio path bring
up but we ensure that all firmwares behave.
Signed-off-by: JS Park <aitdark.park@samsung.com>
We should not free any buffers associated with writing out coefficients
to the DSP until all the async writes have completed. This patch updates
the out of memory path when allocating a new buffer to include a call to
regmap_async_complete.
Reported-by: JS Park <aitdark.park@samsung.com>
Cc: stable@vger.kernel.org
Use vmalloc to allocate the buffer for firmware/coefficient download and
rely on the SPI core to split this up into DMA-able chunks. This should
give better performance and means we no longer need to manually split
the download into page size chunks to avoid allocating overly large
continuous memory regions.
Both the snd_soc_codec and snd_soc_platform struct do have a pointer to the
parent card and both handle this pointer in mostly the same way. This patch
moves the card field to the component level which will allow further code
consolidation between platforms and CODECS.
Since there are only a handful of users of the snd_soc_codec struct's card field
(and none of the snd_soc_platform's) these are update in this patch as well,
which allows it to be removed from the snd_soc_codec struct.
Signed-off-by: Mark Brown <broonie@linaro.org>
Since MODULE_LICENSE is missing the module load fails,
so add this for module.
Signed-off-by: Praveen Diwakar <praveen.diwakar@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Reviewed-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
asoc-next
We have defines for adsp messages best to consistently use them.
'asoc/topic/ak4104', 'asoc/topic/ak4642', 'asoc/topic/alc5623', 'asoc/topic/arizona', 'asoc/topic/atmel' and 'asoc/topic/cache' into asoc-next
Reported-by: kbuild test robot <fengguang.wu@intel.com>
For CODEC controls snd_kcontrol_chip() currently returns a pointer to the
CODEC that registered the control. With the upcoming consolidation of
platform and CODEC controls this will change. Prepare for this by introducing
the snd_soc_kcontrol_codec() helper function that will hide the implementation
details of how the CODEC for a control can be obtained. This will allow us to
change this easily in the future.
The patch also updates all CODEC drivers to use the new helper function.
The firmware files can be quite large and allocating the whole firmware
a single DMA safe buffer can be problematic if the system is under a
high memory load. Ease the requirements slightly by writing the firmware
out in page sized chunks.
It can be useful for debugging purposes to see at what point the DSP has
powered down, so add a message to inform us of this.
'asoc/topic/bcm2835', 'asoc/topic/docs', 'asoc/topic/fsl', 'asoc/topic/generic', 'asoc/topic/kirkwood', 'asoc/topic/mc13783', 'asoc/topic/mxs', 'asoc/topic/nuc900', 'asoc/topic/sai', 'asoc/topic/sh', 'asoc/topic/ssm2602', 'asoc/topic/tlv320aic3x', 'asoc/topic/twl4030', 'asoc/topic/ux500', 'asoc/topic/width' and 'asoc/topic/x86' into for-tiwai
Move the start of booting the DSP to earlier in the DAPM process, and
move the final starting of the DSP to later in the DAPM process. This
allows us to overlap some of the processing with other components of the
system being brought up.
Move the ADSP2 boot proceedure into a work structure in preparation for
running it asynchronously with the reset of the audio path bring up.
'asoc/topic/adav80x', 'asoc/topic/adsp', 'asoc/topic/ak4641', 'asoc/topic/ak4642', 'asoc/topic/arizona', 'asoc/topic/atmel', 'asoc/topic/au1x', 'asoc/topic/axi', 'asoc/topic/bcm2835', 'asoc/topic/blackfin', 'asoc/topic/cs4271', 'asoc/topic/cs42l52', 'asoc/topic/da7210', 'asoc/topic/davinci', 'asoc/topic/ep93xx', 'asoc/topic/fsl', 'asoc/topic/fsl-mxs', 'asoc/topic/generic', 'asoc/topic/hdmi', 'asoc/topic/jack', 'asoc/topic/jz4740', 'asoc/topic/max98090', 'asoc/topic/mxs', 'asoc/topic/omap', 'asoc/topic/pxa', 'asoc/topic/rcar', 'asoc/topic/s6000', 'asoc/topic/sai', 'asoc/topic/samsung', 'asoc/topic/sgtl5000', 'asoc/topic/spear', 'asoc/topic/ssm2518', 'asoc/topic/ssm2602', 'asoc/topic/tegra', 'asoc/topic/tlv320aic3x', 'asoc/topic/twl6040', 'asoc/topic/txx9', 'asoc/topic/uda1380', 'asoc/topic/width', 'asoc/topic/wm8510', 'asoc/topic/wm8523', 'asoc/topic/wm8580', 'asoc/topic/wm8711', 'asoc/topic/wm8728', 'asoc/topic/wm8731', 'asoc/topic/wm8741', 'asoc/topic/wm8750', 'asoc/topic/wm8753', 'asoc/topic/wm8776', 'asoc/topic/wm8804', 'asoc/topic/wm8900', 'asoc/topic/wm8901', 'asoc/topic/wm8940', 'asoc/topic/wm8962', 'asoc/topic/wm8974', 'asoc/topic/wm8985', 'asoc/topic/wm8988', 'asoc/topic/wm8990', 'asoc/topic/wm8991', 'asoc/topic/wm8994', 'asoc/topic/wm8995', 'asoc/topic/wm9081' and 'asoc/topic/x86' into asoc-next
Some devices are getting very close to the limit whilst polling the RAM
start, this patch adds a small delay to this loop to give a longer
startup timeout.
This will allow a marginal speed improvement when used with a bus that
supports async I/O by reducing the amount of context thrashing between
writes, allowing the bus to be more fully utilised.
