commit 3012f43eaf7592d8121426918e43e3b5db013aff upstream.
According to DM365 voice codec data sheet at [1], before starting
recording or playback, ADC/DAC modules should follow a reset and
enable cycle. Writing a 1 to the ADC/DAC bit in the register resets
the module and clearing the bit to 0 will enable the module. But the
driver seems to be doing the reverse of it.
[1] http://focus.ti.com/lit/ug/sprufi9b/sprufi9b.pdf
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Acked-by: Liam Girdwood <lrg@ti.com>
commit 82d1d521036eb3f5aae48b847f939d99a44c18bb upstream.
In davinci_vcif_trigger() function, a break() statement was missing
causing the davinci_vcif_stop() function to be called as a fallback
after calling davinci_vcif_start().
With the addition of a platform device mfd_cell pointer, MFD drivers
can go back to passing platform back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Cc: Miguel Aguilar <miguel.aguilar@ridgerun.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
The davinci-i2s driver copies the platform data for playback and capture
sram sizes which is in turn used by davinci-pcm to allocate ping-pong
buffers.
Copy also the platform data in davinci-mcasp probe.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
The current davinci_mcasp_set_dai_fmt() sets bits ACLKX and ACLKR in the PDIR
register for the codec clock-master/frame-slave mode; however, this results in
the ACLKX and ACLKR pins being outputs according to SPRUFM1 [1] which
conflicts with "codec is clock master."
Similarly to the previous patch in this series, "fix _CBM_CFS hw_params" --
For codec clock-master/frame-slave mode (_CMB_CFS), clear bits ACLKX and ACLKR
in the PDIR register to set the pins as inputs and hence allow externally
sourced bit-clocks.
[1] http://www.ti.com/litv/pdf/sprufm1
Reviewed-by: James Nuss <jamesnuss@nanometrics.ca>
The current davinci_mcasp_set_dai_fmt() sets bits ACLKXE and ACLKRE (CLKXM
and CLKRM as they are reffered to in SPRUFM1 [1]) for codec clock-slave/
frame-slave mode (_CBS_CFS) which selects internally generated bit-clock and
frame-sync signals; however, it does the same thing again for codec
clock-master/frame-slave mode (_CBM_CFS) in the very next case statement which
is incorrectly selecting internally generated bit-clocks in this mode.
For codec clock-master/frame-slave mode (_CBM_CFS), clear bits ACLKXE and
ACLKRE to select externally-generated bit-clocks.
The current driver creates value for set/clr of PDIR using (x<<26) instead
of the #defines that are convieniently made available.
Update the driver to use the bitfield definitions of PDIR. There is no
functional change introduced by this patch.
The current check for the number of tdm-slots specified by platform data is
always true (x >= 2 || x <= 32); therefore the else branch that warns of an
incorrect number of slots can never be taken.
Check that the number of tdm slots specified by platform data is between 2
and 32, inclusive.
Use mfd_data for passing information from mfd drivers to soc
clients. The mfd_cell's driver_data field is being phased out.
Clients that were using driver_data now access .mfd_data
via mfd_get_data().
Signed-off-by: Andres Salomon <dilinger@queued.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch modifies the Davinci i2s and mcasp drivers to make use of
ioremap() instead of IO_ADDRESS()
Signed-off-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
In case of any error in probe() function, clk_disable() and clk_put()
should be called if clk_enable() and clk_get() went through.
to make use of the resource_size() helper function for readability.
McASP1 is used on the DA830/OMAP-L137 platform for the codec.
This is different from the DA850/OMAP-L138 platform which uses McASP0.
This is fixed by adding a new snd_soc_dai_link struct.
The codec_name entry for da8xx evm in sound/soc/davinci/davinci-evm.c
is not matching with the i2c ids in the board file. Without this fix the
soundcard does not get detected on da850/omap-l138/am18x evm.
Tested-by: Dan Sharon <dansharon@nanometrics.ca>
Cc: stable@kernel.org (for 2.6.37)
After multi-component conversion these machine drivers don't actually need
anything from sound/soc/codecs/tlv320aic3x.h so don't include it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
There is no need to include soc-dapm.h since soc.h includes it.
Multi-component commit f0fba2ad broke a few things which this patch should
fix. Tested on the DM355 EVM. I've been as careful as I can, but it would be
good if those with access to other Davinci boards could test.
The multi-component commit put the initialisation of
snd_soc_dai.[capture|playback]_dma_data into snd_soc_dai_ops.hw_params of the
McBSP, McASP & VCIF drivers (davinci-i2s.c, davinci-mcasp.c & davinci-vcif.c).
The initialisation had to be moved from the probe function in these drivers
because davinci_*_dai changed from snd_soc_dai to snd_soc_dai_driver.
Unfortunately, the DMA params pointer is needed by davinci_pcm_open (in
davinci-pcm.c) before hw_params is called. I have moved the initialisation to
a new snd_soc_dai_ops.startup function in each of these drivers. This fix
indicates that all platforms that use davinci-pcm must have been broken and
need to test with this fix.
The multi-component commit also changed the McBSP driver name from
"davinci-asp" to "davinci-i2s" in davinci-i2s.c without updating the board
level references to the driver name. This change is understandable, as there
is a similarly named "davinci-mcasp" driver in davinci-mcasp.c.
There is probably no 'correct' name for this driver. The DM6446 datasheet
calls it the "ASP" and describes it as a "specialised McBSP". The DM355
datasheet calls it the "ASP" and describes it as a "specialised ASP". The
DM365 datasheet calls it the "McBSP". Rather than fix this problem by
reverting to "davinci-asp", I've elected to avoid future confusion with the
"davinci-mcasp" driver by changing it to "davinci-mcbsp", which is also
consistent with the names of the functions in the driver. There are other
fixes required, so it was never going to be as simple as a revert anyway.
The DM365 only has one McBSP port (of the McBSP platforms, only the DM355 has
2 ports), so I've changed the the id of the platform_device from 0 to -1.
In davinci-evm.c, the DM6446 EVM can no longer share a snd_soc_dai_link
structure with the DM355 EVM as they use different cpu DAI names (the DM355
has 2 ports and the EVM uses the second port, but the DM6446 only has 1 port).
This also means that the 2 boards need different snd_soc_card structures.
The codec_name entries in davinci-evm.c didn't match the i2c ids in the board
files. I have only checked and fixed the details of the names used for the
McBSP based platforms. Someone with a McASP based platform (eg DA8xx) should
check the others.
Signed-off-by: Chris Paulson-Ellis <chris@edesix.com>
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
arch/powerpc/platforms/85xx/p1022_ds.c
In this code, 0 is returned on failure, even though other
failures return -ENOMEM or other similar values.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@a@
identifier alloc;
identifier ret;
constant C;
expression x;
x = alloc(...);
if (x == NULL) { <+... \(ret = -C; \| return -C; \) ...+> }
identifier f, a.alloc;
expression ret;
expression x,e1,e2,e3;
ret = 0
... when != ret = e1
*x = alloc(...)
... when != ret = e2
if (x == NULL) { ... when != ret = e3
return ret;
// </smpl>
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Since only 4 mainline ASoC codecs support the trigger
callback, we cannot rely upon them stopping the frame clock
if they are master and must assume it is running even if the
sound is paused. Thus we cannot start the ASP until the trigger
method.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Signed-off-by: Martin Ambrose <martin@ti.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Currently the EDMA queue to be used by for servicing ASP through
internal RAM is fixed to EDMAQ_0 and that to service internal RAM
from external RAM is fixed to EDMAQ_1.
This may not be the desirable configuration on all platforms. For
example, on DM365, queue 0 has large fifo size and is more suitable
for video transfers. Having audio and video transfers on the same
queue may lead to starvation on audio side.
platform data as defined currently passes a queue number to the driver
but that remains unused inside the driver.
Fix this by defining one queue each for ASP and RAM transfers in the
platform data and using it inside the driver.
Since EDMAQ_0 maps to 0, thats the queue that will be used if
the asp queue number is not initialized. None of the platforms
currently utilize ping-pong transfers through internal RAM so that
functionality remains unchanged too.
This patch has been tested on DM644x and OMAP-L138 EVMs.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
The code checks 'davinci_vc' after kzalloc() and do not checks
'davinci_vcif_dev' that kzalloc() result is assigned to. It seems that
it is a typo (autocompletion?).
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
i2s_accurate_sck switch can be used to have a better approximate
sampling frequency.
The clock is an externally visible bit clock and it is named
i2s continuous serial clock (I2S_SCK).
The trade off is between more accurate clock (fast clock)
and less accurate clock (slow clock).
The waveform will be not symmetric.
Probably it is possible to get a better algorithm for calculating
the divider, trying to keep a slower clock as possible.
This patch has been developed against the
http://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci.git
git tree and has been tested on bmx board (similar to dm365 evm, but using
uda1345 as external audio codec).
Signed-off-by: Raffaele Recalcati <raffaele.recalcati@bticino.it>
Signed-off-by: Davide Bonfanti <davide.bonfanti@bticino.it>
Acked-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
When McBSP peripheral gets the clock from an external pin,
there are three possible chooses, MCBSP_CLKX, MCBSP_CLKR
and MCBSP_CLKS.
evm-dm365 uses MCBSP_CLKR, instead in bmx board I have a different
hardware connection and I use MCBSP_CLKS, so I have added
this possibility.
This patch has been developed against the:
git tree and has been tested on bmx board (similar to dm365 evm)
Added two clocking options for dm365 McBSP peripheral when used
with I2S timings, that are SND_SOC_DAIFMT_CBS_CFS (the cpu generates
clock and frame sync) and SND_SOC_DAIFMT_CBS_CFM (the cpu gets clock
from external pin and generates frame sync).
A slave clock management can be important when the external codec needs
the system clock and the bit clock synchronized (tested with uda1345).
On DA830/OMAP-L137 and DA850/OMAP-L138 SoCs, the McASP peripheral
has FIFO support. This FIFO provides additional data buffering. It
also provides tolerance to variation in host/DMA controller response
times. More details of the FIFO operation can be found at
http://focus.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=sprufm1&fileType=pdf
Existing sequence of steps for audio playback/capture are:
a. DMA configuration
b. McASP configuration (configures and enables FIFO)
c. Start DMA
d. Start McASP (enables FIFO)
During McASP configuration, while FIFO was being configured, FIFO
was being enabled in davinci_hw_common_param() function of
sound/soc/davinci/davinci-mcasp.c file. This generated a transmit
DMA event, which gets serviced when DMA is started.
https://patchwork.kernel.org/patch/84611/ patch clears the DMA
events before starting DMA, which is the right thing to do. But
this resulted in a state where DMA was waiting for an event from
McASP (after step c above), but the event which was already there,
has got cleared (because of step b above).
The fix is not to enable the FIFO during McASP configuration as
FIFO was being enabled as part of McASP start.
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
sound/soc/codecs/ad1938.c
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: mixart: range checking proc file
ALSA: hda - Fix a wrong array range check in patch_realtek.c
ALSA: ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_stream
ALSA: hda - Enable amplifiers on Acer Inspire 6530G
ASoC: Only do WM8994 bias off transition from standby
ASoC: Don't use DCS_DATAPATH_BUSY for WM hubs devices
ASoC: Don't do runtime wm_hubs DC servo updates if using offset correction
ASoC: Support second DC servo readback method for wm_hubs
ASoC: Avoid wraparound in wm_hubs DC servo correction
ALSA: echoaudio - Eliminate use after free
ALSA: i2c: cleanup: change parameter to pointer
ALSA: hda - Add MSI blacklist for Aopen MZ915-M
ASoC: OMAP: Fix capture pointer handling for OMAP1510 to work correctly with recent ALSA PCM code
ALSA: hda - Update document about MSI and interrupts
ALSA: hda: Fix 0 dB offset for Lenovo Thinkpad models using AD1981
ALSA: hda - Add missing printk argument in previous patch
ASoC: Fix passing platform_data to ac97 bus users and fix a leak
ALSA: hda - Fix ADC/MUX assignment of ALC269 codec
ALSA: hda - Fix invalid bit values passed to snd_hda_codec_amp_stereo()
ASoC: wm8994: playback => capture
This fixes a memory corruption when ASoC devices are used in
full-duplex mode. Specifically for pxa-ssp code, where this pointer
is dynamically allocated for each direction and destroyed upon each
stream start.
All other platforms are fixed blindly, I couldn't even compile-test
them. Sorry for any breakage I may have caused.
[Note that this is a backported version for 2.6.34.
Upstream commit is fd23b7dee]
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Reported-by: Sven Neumann <s.neumann@raumfeld.com>
Reported-by: Michael Hirsch <m.hirsch@raumfeld.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Implicit slab.h inclusion via percpu.h is about to go away. Make sure
gfp.h or slab.h is included as necessary.
stream start.
Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
The DM365 EVM has two codecs: the Audio Codec (AIC3x) and the Voice Codec,
the idea is to have both enabled in the same kernel simultaneously. However,
the current soc-core doesn't support simultaneous codecs, once that
support will have added, a patch will be posted to enable both codecs in
the DM365 EVM.
Signed-off-by: Miguel Aguilar <miguel.aguilar@ridgerun.com>
This patch adds the support for the interface needed by the DaVinci
Voice Codec CQ93VC.
On TI DM6467 EVM, S/PDIF DIT codec fails to open as it is unable to install
hardware params. This dummy codec has no set_fmt and set_sysclk implementations
and calls from the application to these functions cause errors. This patch adds
a new hardware params callback function for S/PDIF transciever codec.
Signed-off-by: Chaithrika U S <chaithrika@ti.com>
Tested-by: Anuj Aggarwal <anuj.aggarwal@ti.com>
Sometimes after a suspend-resume cycle, the ALSA application
restarts the stream when resume fails and McASP fails to work
as the clock is not enabled. This patch corrects this bug.
Testes on TI DA850/OMAP-L138 EVM.
Add clock enable and disable calls to resume and suspend respectively.
Also add a member to the audio device data structure which tracks the clock
status.
Tested on DA850/OMAP-L138 EVM. For the purpose of testing, the patches[1] which
add suspend-to-RAM support to DA850/OMAP-L138 SoC were applied.
[1] http://linux.davincidsp.com/pipermail/davinci-linux-open-source/
2009-November/016958.html
Use edma_pause and edma_resume to make missing dma_events
less likely. This may not be needed, but it looks better.
Fix underruns by using dma to copy 1st to sram
in a ping/pong buffer style and then copying from
the sram to the ASP. This also has the advantage
of tolerating very long interrupt latency on dma
completion.
Rename variable master_lch to asp_channel
Rename variable slave_lch to asp_link[0]
Rename local variables:
lch to link
count to asp_count
src to asp_src
dst to asp_dst
Allow the left and right 16 bit samples to be shifted out as 1
32 bit sample.
Remove requirement that dma_params is 1st in the structures
davinci_audio_dev and davinci_mcbsp_dev.
