Add machine driver for Wolfson WM9712 AC97 codec connected to
Freescale SAI SoC audio transceiver. This combination needs
software emulated AC97 which is done by the fsl_sai_ac97
driver.
Initial support for AC97 using SAI peripheral. The SAI peripheral
does not support AC97 completely: Only the frame synchronization
and different slot length is taken care of, but all AC97 slots are
concatenated in one stream in a single FIFO. Hence the AC97 control
slots need to be handled completely in software. To do this in a
efficient manor the driver uses a ring buffer and prepares a whole
buffer at a time.
Due to the nature how variable sample rates are handled in AC97,
this software AC97 only supports AC97 native sample rate which is
48000Hz. However, the device announces this circumstances and the
upper stack should handle that correctly. Measurements showed a
overhead of about 3% CPU when playing a file with 44.1kHz sample
rate.
This adds a clock driver to use the bitclock (TX_BCLK) as a master
clock.
This adds an initial machine driver for the ES8328 audio codec on Freescale
boards. The driver supports headphones and an audio regulator for an onboard
speaker amp.
Signed-off-by: Sean Cross <xobs@kosagi.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
The Freescale Generic ASoC Sound Card is a general ASoC DAI Link driver that
can be used, ideally, for all Freescale CPU DAI drivers and external CODECs.
The idea of this generic sound card is a bit like ASoC Simple Card. However,
for Freescale SoCs (especially those released in recent years), most of them
have ASRC (Documentation/devicetree/bindings/sound/fsl,asrc.txt) inside. And
this is a specific feature that might be painstakingly controlled and merged
into the Simple Card driver.
So having this driver will allow all Freescale SoC users to benefit from the
simplification to support a new card and the capability of wide sample rates
support through ASRC.
The driver is initially designed for sound card using I2S or PCM DAI formats.
However, it's also possible to merge those non-I2S/PCM type sound cards, such
as S/PDIF audio and HDMI audio, into this card as long as the merge will not
break the original function and as long as there is something redundant that
can be abstracted along with I2S type sound cards.
As an initial version, it only supports three cards that I can test:
imx-audio-cs42888, a new card that links ESAI with CS42888 CODEC
imx-audio-sgtl5000, just like the old imx-sgtl5000.c driver
imx-audio-wm8962, just like the old imx-wm8962.c driver
The driver is also compatible with the old Device Tree bindings of WM8962 and
SGTL5000. So we may consider to remove those two drivers after this driver is
totally enabled. (It needs to be added into defconfig)
Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com>
The Asynchronous Sample Rate Converter (ASRC) converts the sampling rate of a
signal associated with an input clock into a signal associated with a different
output clock. The driver currently works as a Front End of DPCM with other Back
Ends DAI links such as ESAI<->CS42888 and SSI<->WM8962 and SAI. It converts the
original sample rate to a common rate supported by Back Ends for playback while
converts the common rate of Back Ends to a desired rate for capture. It has 3
pairs to support three different substreams within totally 10 channels.
Reviewed-by: Varka Bhadram <varkabhadram@gmail.com>
Move all code that is only used for debugging to a seperate file. This
makes it easier to see what functions are used for debugging only.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Tested-By: Michael Grzeschik <mgr@pengutronix.de>
This patch implements a device-tree-only CPU DAI driver for Freescale ESAI
controller that supports:
- 12 channels playback and 8 channels record.
[ Some of the inner transmitters and receivers are sharing same group of
pins. So the maxmium 12 output or 8 input channels are only valid if
there is no pin conflict occurring to it. ]
- Independent (asynchronous mode) or shared (synchronous mode) transmit and
receive sections with separate or shared internal/external clocks and frame
syncs, operating in Master or Slave mode.
[ Current ALSA seems not to allow CPU DAI drivers to configure DAI format
separately for PLAYBACK and CAPTURE. So this first version only supports
the case that uses the same DAI format for both directions. ]
- Various DAI formats: I2S, Left-Justified, Right-Justified, DSP-A and DSP-B.
- Programmable word length (8, 16, 20 or 24bits)
- Flexible selection between system clock or external oscillator as input
clock source, programmable internal clock divider and frame sync generation.
Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com>
This adds Freescale SAI ASoC Audio support.
This implementation is only compatible with device tree definition.
Features:
o Supports playback/capture
o Supports 16/20/24 bit PCM
o Supports 8k - 96k sample rates
o Supports master and slave mode.
Signed-off-by: Alison Wang <b18965@freescale.com>
Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com>
There is a blank space missing between ':=' and 'imx-spdif.o', thus add it.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
This patch implements a device-tree-only machine driver for Freescale
i.MX series Soc. It works with spdif_transmitter/spdif_receiver and
fsl_spdif.c drivers.
S/PDIF controller that supports stereo playback and record feature.
This is the initial imx-wm8962 device-tree-only machine driver working with
fsl_ssi driver. More features can be added on top of it later.
With imx-pcm-dma moving to generic dmaengine pcm driver and the removal
of imx-pcm-audio/imx-fiq-pcm-audio platform device use, now imx-pcm
driver contains a few functions that are only used by imx-pcm-fiq.c.
Move these functions into imx-pcm-fiq.c and remove imx-pcm.c completely.
This reverts commit 25b8d31488a3fb3611651991969526b2ea475764.
While the commit fixes multiple init_module definition error with
module build, it breaks build when both imx-pcm-fiq and imx-pcm-dma
are built in as below.
LD sound/soc/fsl/snd-soc-fsl-ssi.o
LD sound/soc/fsl/snd-soc-fsl-utils.o
LD sound/soc/fsl/snd-soc-imx-ssi.o
LD sound/soc/fsl/snd-soc-imx-audmux.o
LD sound/soc/fsl/snd-soc-imx-pcm-fiq.o
LD sound/soc/fsl/snd-soc-imx-pcm-dma.o
LD sound/soc/fsl/snd-soc-eukrea-tlv320.o
LD sound/soc/fsl/snd-soc-imx-sgtl5000.o
LD sound/soc/fsl/snd-soc-imx-mc13783.o
LD sound/soc/fsl/built-in.o
sound/soc/fsl/snd-soc-imx-pcm-dma.o: In function `imx_pcm_free':
imx-pcm.c:(.text+0x464): multiple definition of `imx_pcm_free'
sound/soc/fsl/snd-soc-imx-pcm-fiq.o:imx-pcm-fiq.c:(.text+0x1a8): first defined here
sound/soc/fsl/snd-soc-imx-pcm-dma.o: In function `snd_imx_pcm_mmap':
imx-pcm.c:(.text+0x35c): multiple definition of `snd_imx_pcm_mmap'
sound/soc/fsl/snd-soc-imx-pcm-fiq.o:imx-pcm-fiq.c:(.text+0xa0): first defined here
sound/soc/fsl/snd-soc-imx-pcm-dma.o: In function `imx_pcm_new':
imx-pcm.c:(.text+0x3dc): multiple definition of `imx_pcm_new'
sound/soc/fsl/snd-soc-imx-pcm-fiq.o:imx-pcm-fiq.c:(.text+0x120): first defined here
make[4]: *** [sound/soc/fsl/built-in.o] Error 1
Let's revert the commit and find a proper fix for multiple init_module
definition error later.
With commit f2818d0 (ASoC: fsl: fix miscompilation of snd-soc-imx-pcm),
we will see the following build error when building modules with
CONFIG_SND_IMX_SOC=m in imx_v6_v7_defconfig.
CC [M] sound/soc/fsl/phycore-ac97.o
LD [M] sound/soc/fsl/snd-soc-fsl-ssi.o
LD [M] sound/soc/fsl/snd-soc-fsl-utils.o
LD [M] sound/soc/fsl/snd-soc-imx-ssi.o
LD [M] sound/soc/fsl/snd-soc-imx-audmux.o
LD [M] sound/soc/fsl/snd-soc-imx-pcm.o
sound/soc/fsl/imx-pcm-dma.o: In function `init_module':
imx-pcm-dma.c:(.init.text+0x0): multiple definition of `init_module'
sound/soc/fsl/imx-pcm-fiq.o:imx-pcm-fiq.c:(.init.text+0x0): first defined here
sound/soc/fsl/imx-pcm-dma.o: In function `cleanup_module':
imx-pcm-dma.c:(.exit.text+0x0): multiple definition of `cleanup_module'
sound/soc/fsl/imx-pcm-fiq.o:imx-pcm-fiq.c:(.exit.text+0x0): first defined here
make[4]: *** [sound/soc/fsl/snd-soc-imx-pcm.o] Error 1
Instead of using bool for SND_SOC_IMX_PCM_FIQ and SND_SOC_IMX_PCM_DMA
to fix the original issue, we should completely remove SND_SOC_IMX_PCM
and have imx-pcm.o statically linked with imx-pcm-fiq.o or imx-pcm-dma.o.
Due to a broken make rule, sound/soc/fsl/imx-pcm-dma.c or
sound/soc/fsl/imx-pcm-fiq.c (whatever is selected via Kconfig) will
not be compiled into imx-pcm.o when building as module, i.e.:
CONFIG_SND_SOC_IMX_PCM=m
CONFIG_SND_SOC_IMX_PCM_DMA=m
resulting in a non-functional sound driver.
This gives the error messages:
| imx-sgtl5000 sound.1: platform imx-pcm-audio not registered
| imx-sgtl5000 sound.1: snd_soc_register_card failed (-517)
| platform sound.1: Driver imx-sgtl5000 requests probe deferral
when loading the driver instead of what's to be expected:
| imx-sgtl5000 sound.1: sgtl5000 <-> 63fcc000.ssi mapping ok
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
This small reference boards has a Freescale P1022 dual-core PowerPC SOC
and a Wolfson Microelectronics WM8960 codec.
Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch>
This is the initial imx-sgtl5000 machine driver support with only
playback dai link implemented. More features can be added on top
of it later.
It's a device tree only machine driver working with fsl_ssi driver.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Timur Tabi <timur@freescale.com>
There is some amount of code duplication between mpc8610_hpcd and
p1022_ds machine drivers, and the same code will be duplicated again
when another new machine driver is added. The patch creates fsl_utils
to accommodate the common functions to stop the code duplication.
Rename a couple of imx-pcm Kconfig options and filename to get them
well named and less confusing.
Freescale PowerPC and ARM/IMX families share the same SSI IP block.
The patch merges sound/soc/imx into sound/soc/fsl, so that the possible
code sharing and consolidation can happen.
This is a plain merge, except that menuconfig SND_POWERPC_SOC is added
in Kconfig for PowerPC platform as a correspondence to SND_IMX_SOC for
IMX platform.
The fsl_ssi driver will possibly be shared between Freescale PowerPC
and ARM/IMX families, so give it a separate Kconfig option. Then
fsl_ssi driver can possibly be selected independently from selecting
PowerPC DMA based PCM driver.
The Freescale P1022 is a dual-core e500-based SOC with multimedia capabilities,
specifically the same SSI audio controller on the MPC8610. The P1022 DS
reference board includes a P1022 and a Wolfson Microelectronics WM8776
codec.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Signed-off-by: Jon Smirl <jonsmirl@gmail.com>
A wm9712 AC97 codec is used.
I've implemented retries for when the AC97 hardware doesn't reset on
first try. About 10% of the time both the Efika and pcm030 AC97 codecs
don't reset on first try and need to be poked multiple times. Failure
is indicated by not having the link clock start ticking. Every once in
a while even five pokes won't get the link started and I have to power
cycle.
Basic split of mpc5200 DMA code out from i2s into a standalone file.
Change the Kconfig and Makefile options for Freescale MPC8610 audio drivers
so that they can be compiled as modules, and simplify the Kconfig choices
so that only the platform is selected.
Also fix the naming of the driver files to conform to ALSA standards.
[Removed extraneous SND_SOC dependency -- broonie]
This is an I2S bus driver for the MPC5200 PSC device. It depends on the
soc-of helper functions to match a PSC device with a codec based on data
in the device tree.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Simple utility layer for creating ASoC machine instances based on data
in the OpenFirmware device tree. OF aware platform drivers and codec
drivers register themselves with this framework and the framework
automatically instantiates a machine driver. At the moment, the driver
is not very capable and it is expected to be extended as more features
are needed for specifying the configuration in the device tree.
This is most likely temporary glue code to work around limitations in
the ASoC v1 framework. When v2 is merged, most of this driver will
need to be reworked.
Add the ASoC drivers for the Freescale MPC8610 SoC and the MPC8610 HPCD
reference board.
