path: root/sound/soc/fsl
2010-08-12Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: mmc_spi: Fix unterminated of_match_table of/sparc: fix build regression from of_device changes of/device: Replace struct of_device with struct platform_device
2010-08-09Merge remote branch 'gcl/next' into nextBenjamin Herrenschmidt
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-08-06sound/soc: mpc5200_psc_ac97: Use gpio pins for cold resetEric Millbrandt
Call the gpio reset platform function instead of using the flawed ac97 functionality of the MPC5200(b) From MPC5200B User's Manual: "Some AC97 devices goes to a test mode, if the Sync line is high during the Res line is low (reset phase). To avoid this behavior the Sync line must be also forced to zero during the reset phase. To do that, the pin muxing should switch to GPIO mode and the GPIO control register should be used to control the output lines." Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-05Merge branch 'topic/asoc' into for-linusTakashi Iwai
2010-08-04Merge branch 'master' into for-nextJiri Kosina
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-15powerpc/5200: Fix build error in sound code.Grant Likely
Compiling in the MPC5200 sound drivers results in the following build error: sound/soc/fsl/mpc5200_psc_ac97.o: In function `to_psc_dma_stream': mpc5200_psc_ac97.c:(.text+0x0): multiple definition of `to_psc_dma_stream' sound/soc/fsl/mpc5200_dma.o:mpc5200_dma.c:(.text+0x0): first defined here sound/soc/fsl/efika-audio-fabric.o: In function `to_psc_dma_stream': efika-audio-fabric.c:(.text+0x0): multiple definition of `to_psc_dma_stream' sound/soc/fsl/mpc5200_dma.o:mpc5200_dma.c:(.text+0x0): first defined here make[3]: *** [sound/soc/fsl/built-in.o] Error 1 make[2]: *** [sound/soc/fsl] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 This patch fixes it by declaring the inline function in the header file to also be a static. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Jon Smirl <jonsmirl@gmail.com> Tested-by: John Hilmar Linkhorst <John.Linkhorst@rwth-aachen.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-06-12ASoC: Remove unused header from MPC5200 PSC driverGrant Likely
The header contains an extern that isn't used by anything. Remove. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-09of: add 'of_' prefix to machine_is_compatible()Grant Likely
machine is compatible is an OF-specific call. It should have the of_ prefix to protect the global namespace. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Michal Simek <monstr@monstr.eu>
2009-11-10ASoC: mpc5200: remove duplicate identical IRQ handlerGrant Likely
The TX and RX irq handlers are identical. Merge them Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-07ASoC/mpc5200: fix enable/disable of AC97 slotsGrant Likely
The MPC5200 AC97 driver is disabling the slots when a stop trigger is received, but not reenabling them if the stream is started again without processing the hw_params again. This patch fixes the problem by caching the slot enable bit settings calculated at hw_params time so that they can be reapplied every time the start trigger is received. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-07ASoC/mpc5200: add to_psc_dma_stream() helperGrant Likely
Move the resolving of the psc_dma_stream pointer to a helper function to reduce duplicate code Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-07ASoC/mpc5200: Improve printk debug output for triggerGrant Likely
2009-11-07ASoC/mpc5200: get rid of the appl_ptr tracking nonsenseGrant Likely
Sound drivers PCM DMA is supposed to free-run until told to stop by the trigger callback. The current code tries to track appl_ptr, to avoid stale buffer data getting played out at the end of the data stream. Unfortunately it also results in race conditions which can cause the audio to stall. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-07ASoC/mpc5200: Track DMA position by period number instead of bytesGrant Likely
All DMA blocks are lined up to period boundaries, but the DMA handling code tracks bytes instead. This patch reworks the code to track the period index into the DMA buffer instead of the physical address pointer. Doing so makes the code simpler and easier to understand. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-09-17Merge branch 'fix/asoc' into for-linusTakashi Iwai
* fix/asoc: ASoC: remove unused #include <linux/version.h> ASoC: S3C lrsync function made to work with IRQs disabled. ASoC: Fix display of stream name in DAPM debugfs ASoC: Clean up error handling in MPC5200 DMA setup
2009-09-12ASoC: Clean up error handling in MPC5200 DMA setupJulia Lawall
Error handling code following a kzalloc should free the allocated data. Error handling code following an ioremap should iounmap the allocated data. The semantic match that finds the first problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,f1,l; position p1,p2; expression *ptr != NULL; @@ x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S <... when != x when != if (...) { <+...x...+> } ( x->f1 = E | (x->f1 == NULL || ...) | f(...,x->f1,...) ) ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-09-10Merge branch 'topic/asoc' into for-linusTakashi Iwai
* topic/asoc: (226 commits) ASoC: au1x: PSC-AC97 bugfixes ASoC: Fix WM835x Out4 capture enumeration ASoC: Remove unuused hw_read_t ASoC: fix pxa2xx-ac97.c breakage ASoC: Fully specify DC servo bits to update in wm_hubs ASoC: Debugged improper setting of PLL fields in WM8580 driver ASoC: new board driver to connect bfin-5xx with ad1836 codec ASoC: OMAP: Add functionality to set CLKR and FSR sources in McBSP DAI ASoC: davinci: i2c device creation moved into board files ASoC: Don't reconfigure WM8350 FLL if not needed ASoC: Fix s3c-i2s-v2 build ASoC: Make platform data optional for TLV320AIC3x ASoC: Add S3C24xx dependencies for Simtec machines ASoC: SDP3430: Fix TWL GPIO6 pin mux request ASoC: S3C platform: Fix s3c2410_dma_started() called at improper time ARM: OMAP: McBSP: Merge two functions into omap_mcbsp_start/_stop ASoC: OMAP: Fix setup of XCCR and RCCR registers in McBSP DAI OMAP: McBSP: Use textual values in DMA operating mode sysfs files ARM: OMAP: DMA: Add support for DMA channel self linking on OMAP1510 ASoC: Select core DMA when building for S3C64xx ...
2009-08-07ASoC: Add missing DRV_NAME definitions for fsl/* driversTakashi Iwai
Module builds are broken due to missing DRV_NAME for efika-audio-fabric and pcm030-audio-fabric. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-08-05ASoC: MPC5200: Support for buffer wrap aroundJohn Bonesio
The code in psc_dma_bcom_enqueue_tx() didn't account for the fact that s->runtime->control->appl_ptr can wrap around to the beginning of the buffer. This change fixes this problem. Signed-off-by: John Bonesio <bones@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-22ASoC: MPC5200: Increase the delay time between resetsJohn Bonesio
Reset was failing with the original udelay(50) between the code in psc_ac97_cold_reset() and the call to psc_ac97_warm_reset(). Through testing it was found that a delay of 1ms was necessary for the cold_reset code to consistently complete successfully. Signed-off-by: John Bonesio <bones@secretlab.ca> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-03ASoC: add locking to mpc5200-psc-ac97 driverGrant Likely
AC97 bus register read/write hooks need to provide locking, but the mpc5200-psc-ac97 driver does not. This patch adds a mutex around the register access routines. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-03ASoC: Fix mpc5200-psc-ac97 to ensure the data ready bit is clearedGrant Likely
When doing register reads, it is possible for there to be a stale data ready bit set which will cause subsequent reads to return prematurely with incorrect data. This patch fixes the issues by ensuring stale data is cleared before starting another transaction. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-30ASoC: remove BROKEN from Efika and pcm030 fabric driversGrant Likely
The needed spin_event_timeout() macro is now merged in from the powerpc tree, so these drivers are no longer broken. This reverts commit 0c0e09e21a9e7bc6ca54e06ef3d497255ca26383 (ASoC: Mark MPC5200 AC97 as BROKEN until PowerPC merge issues are resolved) Tested against 2.6.31-rc1. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-30ASoC: Fix typo in MPC5200 PSC AC97 driver KconfigGrant Likely
ALSA SoC drivers should be specify SND_SOC_AC97_BUS instead, not AC97_BUS. Without SND_SOC_AC97_BUS defined, an AC97 device will not get correctly registered on the AC97 bus, which prevents thinks like the WM9712 touchscreen driver from getting probed. Tested against 2.6.31-rc1. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-27ASoC: Modify mpc5200 AC97 driver to use V9 of spin_event_timeout()Jon Smirl
The function signature for spin_event_timeout() has changed in version V9. Adjust the mpc5200 AC97 driver to use the new function. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-27ASoC: Switch FSL SSI DAI over to symmetric_ratesMark Brown
The effect of symmetric_constraints should provide a standard way to enforce the use of the same sample rate for both directions. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Timur Tabi <timur@freescale.com>
2009-05-26ASoC: Mark MPC5200 AC97 as BROKEN until PowerPC merge issues are resolvedMark Brown
These drivers use spin_event_timeout() which is only present in the PowerPC tree at present and which is undergoing some API revisions so temporarily mark them as BROKEN until these issues are sorted out. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-26ASoC: Fabric bindings for STAC9766 on the EfikaJon Smirl
Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-26ASoC: Support for AC97 on Phytec pmc030 base board.Jon Smirl
A wm9712 AC97 codec is used. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-26ASoC: AC97 driver for mpc5200Jon Smirl
I've implemented retries for when the AC97 hardware doesn't reset on first try. About 10% of the time both the Efika and pcm030 AC97 codecs don't reset on first try and need to be poked multiple times. Failure is indicated by not having the link clock start ticking. Every once in a while even five pokes won't get the link started and I have to power cycle. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-26ASoC: Main rewite of the mpc5200 audio DMA codeJon Smirl
Rewrite the mpc5200 audio DMA code to support both I2S and AC97. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-24ASoC: Rename the PSC functions to DMAJon Smirl
Rename the functions in the mpc5200 DMA file from i2s based names to dma ones to reflect the file they are in. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-24ASoC: Basic split of mpc5200 DMA code out of mpc5200_psc_i2sJon Smirl
Basic split of mpc5200 DMA code out from i2s into a standalone file. Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-17sound: use dev_set_drvdataJulia Lawall
Eliminate direct accesses to the driver_data field. cf 82ab13b26f15f49be45f15ccc96bfa0b81dfd015 The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct device *dev; expression E; type T; @@ - dev->driver_data = (T)E + dev_set_drvdata(dev, E) @@ struct device *dev; type T; @@ - (T)dev->driver_data + dev_get_drvdata(dev) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-04ASoC: Remove BROKEN from mpc5200 kconfigTakashi Iwai
The regression was fixed by commit 3e5b50165fd0be080044586f43fcdd460ed27610, so no need to mark this driver as BROKEN. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-04Merge branch 'fix/pcm-jiffies-check' into fix/asocTakashi Iwai
2009-04-28ALSA: Add missing SNDRV_PCM_INFO_BATCH flag to some driversTakashi Iwai
Added SNDRV_PCM_INFO_BATCH flag to PCM info field of some drivers that really don't give the precise pointer value. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-27ASoC: Set the MPC5200 i2s driver to BROKEN status.Jon Smirl
2009-04-06ASoC: fsl_dma: Pass the proper device for dma mapping routinesAnton Vorontsov
The driver should pass a device that specifies internal DMA ops, but substream->pcm is just a logical device, and thus doesn't have arch- specific dma callbacks, therefore following bug appears: Freescale Synchronous Serial Interface (SSI) ASoC Driver ------------[ cut here ]------------ kernel BUG at arch/powerpc/include/asm/dma-mapping.h:237! Oops: Exception in kernel mode, sig: 5 [#1] ... NIP [c02259c4] snd_malloc_dev_pages+0x58/0xac LR [c0225c74] snd_dma_alloc_pages+0xf8/0x108 Call Trace: [df02bde0] [df02be2c] 0xdf02be2c (unreliable) [df02bdf0] [c0225c74] snd_dma_alloc_pages+0xf8/0x108 [df02be10] [c023a100] fsl_dma_new+0x68/0x124 [df02be20] [c02342ac] soc_new_pcm+0x1bc/0x234 [df02bea0] [c02343dc] snd_soc_new_pcms+0xb8/0x148 [df02bed0] [c023824c] cs4270_probe+0x34/0x124 [df02bef0] [c0232fe8] snd_soc_instantiate_card+0x1a4/0x2f4 [df02bf20] [c0233164] snd_soc_instantiate_cards+0x2c/0x68 [df02bf30] [c0234704] snd_soc_register_platform+0x60/0x80 [df02bf50] [c03d5664] fsl_soc_platform_init+0x18/0x28 ... This patch fixes the issue by using card's device instead. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-02ASoC: trim SSI sysfs statistics in Freescale MPC8610 sound driversTimur Tabi
Optimize the display of SSI statistics in the Freescale MPC8610 sound driver to display the status count only of the interrupts that were actually enabled. Previously, it would display the counts of all SISR status bits, even those that were not enabled. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-02ASoC: remove trigger delay in Freescale MPC8610 sound driverTimur Tabi
Remove the delay from the trigger function in the Freescale MPC8610 sound driver when capture is started. This delay was used to ensure that the DMA controller was active when ALSA call the .pointer function to request a DMA transfer status. A better approach is for the .pointer function to detect that DMA has not started, and return zero instead. This change eliminates the need for the delay. Also add some related code to check for a DMA programming error, and report XRUN if it occurs. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-11ASoC: Merge dai_ops factor outMark Brown
Merge Eric Maio's patch to merge snd_soc_dai_ops out of line. Fixed merge issues and updated drivers, plus an issue with the ops for the two s3c2443 AC97 DAIs having been merged. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-07ASoC: Improve pause/unpause performance in Freescale 8610 driversTimur Tabi
Add support for true pause and unpause. Without this, mplayer will drop some audio (less than one second, but still noticeable) when pausing playback. Remove support for PM suspend and resume from the trigger function, since the driver doesn't support PM anyway. Optimize the delay after starting capture. Instead of delaying 1ms, the driver now polls the hardware. The new delay is shorter by over 90% yet still effective. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
