A fix merged in 3.1-rc2 introduced a small regression, this should get it
to build again.
Acked-by: Liam Girdwood <lrg@ti.com>
Adjust the goto to jump to the error handling code that includes kfree.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier x;
expression E1!=0,E2,E3,E4;
statement S;
iterator I;
if (...) { ... when != kfree(x)
when != x = E3
when != E3 = x
* return ...;
... when != x = E2
when != I(...,x,...) S
if (...) { ... when != x = E4
kfree(x); ... return ...; }
// </smpl>
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI.
Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains
card, pcm and DAI along with other members too that are useful too.
Signed-off-by: Liam Girdwood <lrg@ti.com>
There is no need to include soc-dapm.h since soc.h includes it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
OpenRD Ultimate & Client are similar machines so enable OpenRD client sound
support on Ultimate too
Tested-by: Robas Teodor <teodor.robas@gmail.com>
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
This patch is adding support for hp t5325 thin clients.
There's a alc5623 codec connected to the i2s interface.
Like other coworkers, I'm about leave Mandriva/Edge-It so I'm changing
my mail address to use my personal one.
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
Allow snd-soc-kirkwood autoloading by adding an alias.
multicomponent support added/changed some device name but added some typos,
breaking existing OpenRD Client support.
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The controller has mute/unmute capability and some bootloader may mute
them at boot. If it's not handled, all things will seem to be working
but no sound will come out of the speaker/headphone.
Kirkwood controller needs to be informed if the audio stream is mono
or not. Failing to do so will result in playing at the wrong speed.
This patch to remove the 'break;', when the 'switch' jumps to
the 'default' branch, the 'return -EINVAL' will be return with
a error number, so the 'break;' code never be run, it is unuseful
and should be removed here.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
This patch is adding support for openrd client platforms. It's using
the cs42l51 codec and has one mic and one speaker plugs.
This patch enables support for the i2s controller available on kirkwood
platforms
