path: root/sound/soc/kirkwood
2013-01-22ASoC: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-10ASoC: kirkwood: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-dma: remove channel restrictionsRussell King
This is part of a patch found in Rabeeh Khoury's git tree for the cubox. With SPDIF passthrough, we are not restricted to just two channels of audio; we can support however many channels the non-audio stream can itself support. In any case, kirkwood-dma is not involved in the format selection. So yet rid of this restriction. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-i2s: add support for external clock ratesRussell King
This is part of a patch found in Rabeeh Khoury's git tree for the cubox, and cleaned up by me. Some platforms provide an external clock which can be used to allow other sample rates to be selected. Provide support for this. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-dma: remove restriction on sample ratesRussell King
This is part of a patch found in Rabeeh Khoury's git tree for the cubox. The kirkwood DMA hardware for ASoC does not impose any restrictions on the sample rates available, so it's silly to impose an artificial set in the DMA code. The restrictions come from the availble clocks to the I2S module, which are already handled in the I2S part of the driver. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-i2s: better handling of play/record control registersRussell King
2012-11-21ASoC: kirkwood-i2s: use devm_* APIsRussell King
Simplify the cleanup paths in the driver by using the devm_* APIs, ensuring that all error paths are correctly checked. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-i2s: more pause-mode fixesRussell King
Don't even momentarily set the pause status when starting the channel; if we do, we should check the busy bit to ensure that we comply with the spec. In any case, it isn't necessary; we will not active on a START event so there is no need to pause the DMA. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-i2s: fix DMA underrunsRussell King
Stress testing the driver with multiple start/stop events causes kirkwood-dma to report underrun errors (which used to cause the kernel to lock up solidly). This is because kirkwood-i2s is not respecting the restrictions imposed on clearing the 'pause' bit. Follow what the spec says; the busy bit must be read as being clear twice before the pause bit can be released. This solves the underruns. However, it has been noticed that the busy bit occasionally does not clear itself, hence the waiting is bounded to 5ms maximum to avoid a new reason for the kernel to lockup. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-i2s: fix DCO lock detectionRussell King
This is part of a patch found in Rabeeh Khoury's git tree for the cubox, which is further attributed to Sebastian Hesselbrath. Rather than masking the KIRKWOOD_DCO_SPCR_STATUS register contents against the registers virtual address, let's actually use the bit definition for the locked status, as required in the documentation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-dma: don't ignore other irq causes on errorRussell King
Ignoring the real cause of the interrupt is not a good idea; this behaviour has been observed to bring Dove platforms to silently lockup. Instead, on error fall through to the normal interrupt processing. This is especially important on Dove platforms as errors are handled separately, and allows us to clear down the real cause of the interrupt. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-21ASoC: kirkwood-dma: fix use of virt_to_phys()Russell King
This is part of a patch found in Rabeeh Khoury's git tree for the cubox. You can not use virt_to_phys() on the address returned from dma_alloc_coherent(); it may not be part of the kernel direct-mapped memory. Fix this to use the DMA address instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-09-19ARM: orion: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the orion include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Dan Williams <djbw@fb.com> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de>
2012-07-25ARM: Orion: fix driver probe error handling with respect to clkSimon Baatz
The clk patches added code to get and enable clocks in the respective driver probe functions. If the probe function failed for some reason after enabling the clock, the clock was not disabled again in many cases. Signed-off-by: Simon Baatz <gmbnomis@gmail.com> Signed-off-by: Andrew Lumm <andrew@lunn.ch>
2012-05-08ARM: Orion: Audio: Add clk/clkdev supportAndrew Lunn
Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Jamie Lentin <jm@lentin.co.uk> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2012-02-07ASoC: Convert kirkwood-openrd to use snd_soc_register_card()Axel Lin
Use snd_soc_register_card() instead of creating a "soc-audio" platform device. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-07ASoC: Convert kirkwood-t5325 to use snd_soc_register_card()Axel Lin
2012-01-20ASoC: replace 0xffffffff with DMA_BIT_MASK macroJoachim Eastwood
Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-01-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits) ASoC: twl6040 - Add method to query optimum PDM_DL1 gain ALSA: hda - Fix the lost power-setup of seconary pins after PM resume ALSA: usb-audio: add Yamaha MOX6/MOX8 support ALSA: virtuoso: add S/PDIF input support for all Xonars ALSA: ice1724 - Support for ooAoo SQ210a ALSA: ice1724 - Allow card info based on model only ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations ALSA: hdspm - Provide unique driver id based on card serial ASoC: Dynamically allocate the rtd device for a non-empty release() ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs ALSA: hda - Use auto-parser for HP laptops with cx20459 codec ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info() ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref() ALSA: hda/cirrus - support for iMac12,2 model ASoC: cx20442: add bias control over a platform provided regulator ALSA: usb-audio - Avoid flood of frame-active debug messages ALSA: snd-usb-us122l: Delete calls to preempt_disable mfd: Put WM8994 into cache only mode when suspending ... Fix up trivial conflicts in: - arch/arm/mach-s3c64xx/mach-crag6410.c: renamed speyside_wm8962 to tobermory, added littlemill right next to it - drivers/base/regmap/{regcache.c,regmap.c}: duplicate diff that had already come in with other changes in the regmap tree
2012-01-07ASoC: check for substream not channels_min in pcm enginesJoachim Eastwood
This is a follow up on 53dea36c70c1857 which fixes the other affected pcm engines. Description from 53dea36c70c1857: Don't rely on the codec's channels_min information to decide wheter or not allocate a substream's DMA buffer. Rather check if the substream itself was allocated previously. Without this patch I was seeing null-pointer dereferenc in atmel-pcm. Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-28ASoC: Convert kirkwood-t5325 to table based DAPM initAxel Lin
2011-12-28ASoC: Use dai_fmt in kirkwood-t5325 machine driverAxel Lin
2011-12-28ASoC: Use dai_fmt in kirkwood-openrd machine driverAxel Lin
2011-12-28ASoC: Fix build error in sound/soc/kirkwood/kirkwood-i2s.cAxel Lin
Since commit db33f4de "ARM: Orion: Remove address map info from all platform data structures", the dram is removed from struct kirkwood_asoc_platform_data. This patch fixes below build error: CC sound/soc/kirkwood/kirkwood-i2s.o sound/soc/kirkwood/kirkwood-i2s.c: In function 'kirkwood_i2s_dev_probe': sound/soc/kirkwood/kirkwood-i2s.c:444: error: 'struct kirkwood_asoc_platform_data' has no member named 'dram' sound/soc/kirkwood/kirkwood-i2s.c:450: error: 'struct kirkwood_asoc_platform_data' has no member named 'dram' make[3]: *** [sound/soc/kirkwood/kirkwood-i2s.o] Error 1 make[2]: *** [sound/soc/kirkwood] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-23ASoC: kirkwood: Add .owner to struct snd_soc_cardAxel Lin
Add missing .owner of struct snd_soc_card. This prevents the module from being removed from underneath its users. Reported-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-13ARM: Orion: Get address map from plat-orion instead of via platform_dataAndrew Lunn
Use an getter function in plat-orion/addr-map.c to get the address map structure, rather than pass it to drivers in the platform_data structures. When the drivers are built for none orion platforms, a dummy function is provided instead which returns NULL. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Michael Walle <michael@walle.cc> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2011-12-03Merge branch 'for-3.2' into for-3.3Mark Brown
2011-12-03ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 ↵Axel Lin
depend on I2C SND_KIRKWOOD_SOC_T5325 selects SND_SOC_ALC5623, but SND_SOC_ALC5623 needs CONFIG_I2C. So we need to make SND_KIRKWOOD_SOC_T5325 depend on I2C, otherwise I got below build error if CONFIG_I2C is not selected. CC sound/soc/codecs/alc5623.o sound/soc/codecs/alc5623.c: In function 'alc5623_i2c_probe': sound/soc/codecs/alc5623.c:1002: error: implicit declaration of function 'i2c_smbus_read_word_data' sound/soc/codecs/alc5623.c:1009: error: implicit declaration of function 'i2c_smbus_read_byte_data' sound/soc/codecs/alc5623.c: In function 'alc5623_modinit': sound/soc/codecs/alc5623.c:1096: error: implicit declaration of function 'i2c_add_driver' sound/soc/codecs/alc5623.c: In function 'alc5623_modexit': sound/soc/codecs/alc5623.c:1108: error: implicit declaration of function 'i2c_del_driver' make[3]: *** [sound/soc/codecs/alc5623.o] Error 1 make[2]: *** [sound/soc/codecs] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Also fix the same issue for SND_KIRKWOOD_SOC_OPENRD. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-24ASoC: Convert kirkwood directory to module_platform_driverAxel Lin
Factor out some boilerplate code. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23ASoC: Constify snd_soc_dai_ops structsLars-Peter Clausen
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure") introduced the possibility to have constant DAI ops structures, yet this is barley used in both existing drivers and also new drivers being submitted, although none of them modifies its DAI ops structure. The later is not surprising since existing drivers are often used as templates for new drivers. So this patch just constifies all existing snd_soc_dai_ops structs to eliminate the issue altogether. The patch was generated with the following coccinelle semantic patch: // <smpl> @@ identifier ops; @@ -struct snd_soc_dai_ops ops = +const struct snd_soc_dai_ops ops = { ... }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-08ASoC: Remove redundant snd_soc_dapm_sync() calls from machine driversMark Brown
The core will sync DAPM as part of the card initialization, there is no need for machine drivers to do so during their setup. OMAP drivers are omitted as I know Peter already has patches for them. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-02ASoC: kirkwood-i2s: Add __devexit_p at necessary placeAxel Lin
According to the comments in include/linux/init.h: "Pointers to __devexit functions must use __devexit_p(function_name), the wrapper will insert either the function_name or NULL, depending on the config options." We have __devexit annotation for kirkwood_i2s_dev_remove(), thus add __devexit_p at necessary place. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-12ASoC: Fix trivial build regression in Kirkwood I2SArnd Bergmann
A fix merged in 3.1-rc2 introduced a small regression, this should get it to build again. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-22sound/soc/kirkwood/kirkwood-i2s.c: add missing kfreeJulia Lawall
Adjust the goto to jump to the error handling code that includes kfree. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; expression E1!=0,E2,E3,E4; statement S; iterator I; @@ ( if (...) { ... when != kfree(x) when != x = E3 when != E3 = x * return ...; } ... when != x = E2 when != I(...,x,...) S if (...) { ... when != x = E4 kfree(x); ... return ...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-07ASoC: core - Optimise and refactor pcm_new() to pass only rtdLiam Girdwood
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI. Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains card, pcm and DAI along with other members too that are useful too. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-15ASoC: Add support for OpenRD UltimateArnaud Patard (Rtp)
OpenRD Ultimate & Client are similar machines so enable OpenRD client sound support on Ultimate too Tested-by: Robas Teodor <teodor.robas@gmail.com> Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-21ASoC: kirkwood: Add audio support to hp t5325 thin clientsArnaud Patard (Rtp)
This patch is adding support for hp t5325 thin clients. There's a alc5623 codec connected to the i2s interface. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-15ASoC: Change my mail addressArnaud Patard (Rtp)
Like other coworkers, I'm about leave Mandriva/Edge-It so I'm changing my mail address to use my personal one. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Arnaud Patard <apatard@mandriva.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-09-02ASoC: kirkwood: add alias to pcm moduleArnaud Patard (Rtp)
Allow snd-soc-kirkwood autoloading by adding an alias. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-31ASoC: OpenRD Client : Fix naming breakage due to multicomponent supportArnaud Patard (Rtp)
multicomponent support added/changed some device name but added some typos, breaking existing OpenRD Client support. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-13ASoC: kirkwood-i2s: Handle mute/unmute playback/recordarnaud.patard@rtp-net.org
The controller has mute/unmute capability and some bootloader may mute them at boot. If it's not handled, all things will seem to be working but no sound will come out of the speaker/headphone. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-07-13ASoC: Fix kirkwood i2s mono playbackarnaud.patard@rtp-net.org
Kirkwood controller needs to be informed if the audio stream is mono or not. Failing to do so will result in playing at the wrong speed. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-06-07ASoC: patch for the useless 'break' removal in kirkwoodWan ZongShun
This patch to remove the 'break;', when the 'switch' jumps to the 'default' branch, the 'return -EINVAL' will be return with a error number, so the 'break;' code never be run, it is unuseful and should be removed here. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-31ASoC: kirkwood: Add audio support to openrd client platformsapatard@mandriva.com
This patch is adding support for openrd client platforms. It's using the cs42l51 codec and has one mic and one speaker plugs. Signed-off-by: Arnaud Patard <apatard@mandriva.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-31ASoC: kirkwood: Add i2s supportapatard@mandriva.com
This patch enables support for the i2s controller available on kirkwood platforms Signed-off-by: Arnaud Patard <apatard@mandriva.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
