My gmail account got disabled and I'm not going to reopen it.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Acked-by: Liam Girdwood <lrg@ti.com>
After multi-component conversion these machine drivers don't actually need
anything from sound/soc/codecs/tlv320aic3x.h so don't include it.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
There is no need to include soc-dapm.h since soc.h includes it.
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is
required when developing ASoC further. Such as for other ASoC components to
have DAPM widgets or when extending DAPM to handle cross-device paths.
This patch decouples DAPM related variables from struct snd_soc_codec and
moves them to new struct snd_soc_dapm_context that is used to encapsulate
DAPM context of a device. ASoC core and API of DAPM functions are modified
to use DAPM context instead of codec.
This patch does not change current functionality and a large part of changes
come because of structure and internal API changes.
Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some
minor core changes, codecs and machine driver conversions from
Jarkko Nikula <jhnikula@gmail.com>.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Ryan Mallon <ryan@bluewatersys.com>
Cc: Timur Tabi <timur@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jassi Brar <jassi.brar@samsung.com>
Cc: Daniel Gloeckner <dg@emlix.com>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
Fixup the device changes by modifying the files that we just removed the
explicit device creation from with i2c_register_board_info() until this
can be moved into the relevant board files.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
The tlv320aic3x driver managed its own i2c device, instead of an extant
one created by the board support code. Change the code to make it so that
the driver binds to an extant (in this case i2c) device.
Add explict tlv320aic33 as well as tlv320aic3x to the supported device
table and remove the old driver bindings from the users of this code.
My email address is going to expire soon so update it. Adding also
Peter Ujfalusi <peter.ujfalusi@nokia.com> as a second contact to OMAP core
drivers since I won't have anymore access to non-public OMAP documentation
in the future and Peter is working with these drivers as well.
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Add functions "Headset" and "Mic" to the control "Jack Function" for
activating and de-activating codec input pin LINE1L which is connected to
the mic pin of 4-pole Nokia AV connecter.
Note there is no mic bias voltage management here since bias is coming from
Nokia ASIC and driver for it is not in mainline.
The drivers are basically duplicating the same code over and over.
As snd_soc_cnew is going to be made static some time after the next
merge window, we might as well convert them now.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
The snd_soc_codec was moved into socdev->card, but this change wasn't
applied in some places. Fixed now.
As part of the deprecation of snd_soc_device push the registration of
the platform down into the card structure.
Prepare for upcoming McBSP DAI update adding support for mono links by
restricting number of channels to 2 in N810. This is due tlv320aic3x which
claims channels_min = 1 and playing pure mono audio over I2S would cause
it to be played only from left channel if both cpu and codec DAI's claim to
support mono.
One of the issues with the ASoC v1 API which has been addressed in the
ASoC v2 work that Liam Girdwood has done is that the ALSA card provided
by ASoC is distributed around the ASoC structures. For example, machine
wide data such as the struct snd_card are maintained as part of the
CODEC data structure, preventing the use of multiple codecs. This has
been addressed by refactoring the data structures so that all the data
for the ALSA card is contained in a single structure snd_soc_card which
replaces the existing snd_soc_machine and snd_soc_device.
Begin the process of backporting this by renaming struct snd_soc_machine
to struct snd_soc_card, better reflecting its function and bringing it
closer to standard ALSA terminology.
Convert the tlv320aic3x codec driver to the new (standard) device
driver binding model.
Cc: Vladimir Barinov <vbarinov@ru.mvista.com>
Tested-by: Jarkko Nikula <jarkko.nikula@nokia.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
at exit
Thanks to Felipe Balbi <felipe.balbi@nokia.com> by noticing that if clk_get
to sys_clkout2_src fails, then n810_snd_device is never released.
Add also sys_clkout2_src release into error path, error code return and
release the clocks at exit.
This just leaves include/asm-arm/plat-* to deal with.
This patch adds a missing " that was recently introduced (removed)
in the DAI struct merge patch series.
Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
This patch adds several functions for DAI control and config
and replaces the current method of calling function pointers within
the DAI struct within the machine drivers.
This patch merges struct snd_soc_codec_dai and struct
snd_soc_cpu_dai into struct snd_soc_dai for the Omap platform.
Refactored snd_soc_dapm_set_endpoint() to snd_soc_dapm_enable_pin() and
snd_soc_dapm_disable_pin().
Renamed snd_soc_dapm_sync_endpoints() to snd_soc_dapm_sync().
Renamed snd_soc_dapm_get_endpoint_status() to
snd_soc_dapm_get_pin_status().
Use gpiolib since it is now available for OMAPs. Change also references to
HW version RX44 to product name N810.
Cc: Jarkko Nikula <jarkko.nikula@nokia.com>
Fix this typo and avoid similar errors by using ARRAY_SIZE macro.
Add common OMAP ASoC drivers and machine driver for Nokia N810. Currently
supported features are:
- Covers OMAPs from 1510 to 2420
- Common DMA driver
- DAI link driver using McBSP port in I2S mode
- Basic machine driver for Nokia N810
