Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Allow client drivers to set the data_type (16, 32) and the
sync_mode (element, packet, etc) of the audio dma transferences.
McBSP dai driver configures it for a data type of 16 bits and
element sync mode.
Signed-off-by: Misael Lopez Cruz <x0052729@ti.com>
Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch changes the way DMA is done in omap-pcm.c
in order to reduce power consumption. There is no need
to have so much SW control in order to have DMA in idle
state during audio streaming. Configuring McBSP threshold value
and DMA to FRAME_SYNC are sufficient.
Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com>
My email address is going to expire soon so update it. Adding also
Peter Ujfalusi <peter.ujfalusi@nokia.com> as a second contact to OMAP core
drivers since I won't have anymore access to non-public OMAP documentation
in the future and Peter is working with these drivers as well.
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Add common OMAP ASoC drivers and machine driver for Nokia N810. Currently
supported features are:
- Covers OMAPs from 1510 to 2420
- Common DMA driver
- DAI link driver using McBSP port in I2S mode
- Basic machine driver for Nokia N810
