path: root/sound/soc/omap/sdp3430.c
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-10ASoC: omap: Remove needless prints from machine driversJarkko Nikula
It is currently completely normal to execute these machine drivers code on different boards if the kernel includes support for multiple boards so no error message should be printed if the machine_is_xxx does not match with the machine driver. Therefore remove these pr_err and pr_debug prints in those cases. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-12-16mfd: twl: fix twl4030 rename for remaining driver, board filesBalaji T K
Recent drivers/mfd/twl4030* renames to twl broke compile for various boards as the series was missing a patch to change the board-*.c files. This patch renames include twl4030.h to include twl.h and also renames twl4030_i2c_ routines. Signed-off-by: Balaji T K <balajitk@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Felipe Balbi <felipe.balbi@nokia.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-08-25ASoC: SDP3430: Fix TWL GPIO6 pin mux requestCandelaria Villareal, Jorge
Fix the write to PMBR1 register through I2C. Also, the constant which holds the value to write is now called TWL4030_GPIO6_PWM0_MUTE. This name is based on TRM to avoid confusion. Signed-off-by: Jorge Eduardo Candelaria <x0107209@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-07-17ASoC: SDP3430: Add support for EXTMUTE using TWL GPIO6Candelaria Villareal, Jorge
Board sdp3430 has hardware support for EXTMUTE using TWL4030 GPIO6 line, controlled by register INTBR_PMBR1. Machine driver takes care of enabling gpio line through i2c and codec driver manipulates the line during headset ramp up/down sequence. Signed-off-by: Jorge Eduardo Candelaria <x0107209@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-22ASoC: TWL4030: Fix voice interface clock mastersLopez Cruz, Misael
Voice interface of twl4030 codec supports: CBM_CFM and CBS_CFS. It doesn't support CBS_CFM. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Acked-By: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-22ASoC: SDP4030: Use the twl4030_setup_data for headset pop-removalPeter Ujfalusi
With this patch the initial headset pop-removal related values are configured for the twl4030 codec (ramp delay and sysclk). Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-05-19ASoC: SDP3430: Connect twl4030 voice DAI to McBSP3Lopez Cruz, Misael
Connect twl4030 voice DAI to McBSP3 in sdp3430 machine driver. Voice DAI init function enables corresponding interface by writting directly to VOICE_IF codec register. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Acked-by: Peter Ujflausi <peter.ujfalusi@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-04-20ASoC: TWL4030: Add support Voice DAIJoonyoung Shim
Add Voice DAI to support the PCM voice interface of the twl4030 codec. The PCM voice interface can be used with 8-kHz(voice narrowband) or 16-kHz(voice wideband) sampling rates, and 16bits, and mono RX and mono TX or stereo TX. The PCM voice interface has two modes - PCM mode1 : This uses the normal FS polarity and the rising edge of the clock signal. - PCM mode2 : This uses the FS polarity inverted and the falling edge of the clock signal. If the system master clock is not 26MHz or the twl4030 codec mode is not option2, the voice PCM interface is not available. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-19ASoC: Declare Headset as Mic and Headphone widgets for SDP3430Lopez Cruz, Misael
Headset was declared previously as a Headphone widget connecting HSMIC and HSOL/HSOR pins of TWL4030 codec in SDP430 machine driver. The capture path becomes invalid as the Headphone widget is not a valid input endpoint. Instead of that, the Headset is declared as separate Microphone and Headphone widgets. Current patch modifies audio map: - Headset Mic: HSMIC with bias - Headset Stereophone: HSOL, HSOR Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-13ASoC: Move headset jack registration to device initialization for SDP3430Lopez Cruz, Misael
Move headset jack registration to the codec/machine specific initialization. Having the jack registration in machine init causes that the jack device gets initialized but not registered since the sound card is registered before the jack. Moving jack registration to device initialization will register the jack device along with all other devices associated to the card when the card is registed. As a consequence of jack device registered properly, the jack is detected as an input device. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-06ASoC: Add headset jack detection for SDP3430 machine driverLopez Cruz, Misael
Add headset jack detection for SDP3430 boards using SoC jack reporting interface. Headset detection on SDP3430 board is achieved through TWL4030 GPIO_2 pin. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-03-06ASoC: Add DAPM machine widgets to SDP3430 driverLopez Cruz, Misael
Add DAPM machine domain widgets to SDP3430 machine driver. Interconnection: * Ext Mic: MAINMIC, SUBMIC * Ext Spk: HFL, HFR * Headset Jack: HSMIC, HSOL, HSOR Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-02-10ASoC: Update SDP3430 machine driver for snd_soc_cardLopez Cruz, Misael
This patch replaces "snd_soc_machine" structure by "snd_soc_card" in SP3430 driver. This change is needed in SDP3430 driver to reflect changes introduced by "ASoC: Rename snd_soc_card to snd_soc_machine" patch (875065491fba8eb13219f16c36e79a6fb4e15c68). Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Acked-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-12-02ASoC: Push platform registration down into the cardMark Brown
As part of the deprecation of snd_soc_device push the registration of the platform down into the card structure. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-11-25ASoC: Add support for TI SDP3430Misael Lopez Cruz
This patch add ASoC support for TI SDP3430. It's based on Gumstix Overo SoC code by Steve Sakoman. Signed-off-by: Misael Lopez Cruz <mesak82@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
