It is currently completely normal to execute these machine drivers code on
different boards if the kernel includes support for multiple boards so no
error message should be printed if the machine_is_xxx does not match with
the machine driver.
Therefore remove these pr_err and pr_debug prints in those cases.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Remove bogus twl4030 pins
Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Move the remaining headers under plat-omap/include/mach
to plat-omap/include/plat. Also search and replace the
files using these headers to include using the right path.
This was done with:
#!/bin/bash
mach_dir_old="arch/arm/plat-omap/include/mach"
plat_dir_new="arch/arm/plat-omap/include/plat"
headers=$(cd $mach_dir_old && ls *.h)
omap_dirs="arch/arm/*omap*/ \
drivers/video/omap \
sound/soc/omap"
other_files="drivers/leds/leds-ams-delta.c \
drivers/mfd/menelaus.c \
drivers/mfd/twl4030-core.c \
drivers/mtd/nand/ams-delta.c"
for header in $headers; do
old="#include <mach\/$header"
new="#include <plat\/$header"
for dir in $omap_dirs; do
find $dir -type f -name \*.[chS] | \
xargs sed -i "s/$old/$new/"
done
find drivers/ -type f -name \*omap*.[chS] | \
for file in $other_files; do
sed -i "s/$old/$new/" $file
done
done
for header in $(ls $mach_dir_old/*.h); do
git mv $header $plat_dir_new/
done
Add support for EXTMUTE in Zoom2 machine driver. This is necessary
to further reduce pop noise problem. Signal EXTMUTE is connected to
signal GPIO 153 in Zoom2 board.
In addition, change ramp delay value to 3 (218/161/109 ms). With
previous ramp delay value, pop noise was louder. With a longer value
the beep tone can be observed.
Signed-off-by: Jorge Eduardo Candelaria <x0107209@ti.com>
Voice interface of twl4030 codec supports: CBM_CFM and
CBS_CFS. It doesn't support CBS_CFM.
Signed-off-by: Misael Lopez Cruz <x0052729@ti.com>
Acked-By: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Add support for Zoom2 board. Zoom2 machine driver
connects both codec DAIs (audio and voice) to omap3
McBSP ports in the following way:
HiFi <-> McBSP2
Voice <-> McBSP3
The zoom2 driver has the following DAPM widgets:
* Ext Mic: MAINMIC, SUBMIC (with bias)
* Ext Spk: HFL, HFR
* Headset Stereophone: HSOL, HSOR
* Headset Mic: HSMIC (with bias)
* Aux In: AUXL, AUXR
