path: root/sound/soc/omap
2011-10-02ASoC: omap_mcpdm_remove cannot be __devexitArnd Bergmann
omap_mcpdm_remove is used from asoc_mcpdm_probe, which is an initcall, and must not be discarded when HOTPLUG is disabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-23ASoC: omap-mcbsp: Do not attempt to change DAI sysclk if stream is activeJarkko Nikula
Attempt to change McBSP CLKS source while another stream is active is not safe after commit d135865 ("OMAP: McBSP: implement functional clock switching via clock framework") in 2.6.37. CLKS parent clock switching using clock framework have to idle the McBSP before switching and then activate it again. This short break can cause a DMA transaction error to already running stream which halts and recovers only by closing and restarting the stream. This goes more fatal after commit e2fa61d ("OMAP3: l3: Introduce l3-interconnect error handling driver") in 2.6.39 where l3 driver detects a severe timeout error and does BUG_ON(). Fix this by not changing any configuration in omap_mcbsp_dai_set_dai_sysclk if the McBSP is already active. This test should have been here just from the beginning anyway. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-08-19ASoC: omap: Fix build errors in ams-deltaJarkko Nikula
Fix "error: too few arguments to function 'ams_delta_set_bias_level'" build errors in ams-delta.c that were introduced after commit d4c6005 ("ASoC: Add context parameter to card DAPM callbacks") by adding dapm context to ams_delta_set_bias_level calls. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-12ASoC: omap: Update e-mail address of Jarkko NikulaJarkko Nikula
My gmail account got disabled and I'm not going to reopen it. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-26Merge branch 'next/devel2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits) OMAP: Add debugfs node to show the summary of all clocks OMAP2+: hwmod: Follow the recommended PRCM module enable sequence OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming OMAP2+: PM: idle clkdms only if already in idle OMAP2+: clockdomain: add clkdm_in_hwsup() OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition() OMAP4: hwmod: Introduce the module control in hwmod control OMAP4: cm: Add two new APIs for modulemode control OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure OMAP4: hwmod data: Add PRM context register offset OMAP4: prm: Remove deprecated functions OMAP4: prm: Replace warm reset API with the offset based version OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros OMAP: hwmod: Wait the idle status to be disabled OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros OMAP2+: hwmod: Init clkdm field at boot time OMAP4: hwmod data: Add clock domain attribute OMAP4: clock data: Add missing divider selection for auxclks ...
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-07ASoC: twl6040: Move PLL selection to codec driverPeter Ujfalusi
It is better if the selection between the Low power, and High performance PLL is handled within the codec driver, not in machine driver(s) to avoid duplicated code, and also to have consistent tracking of the selected PLL, and the resulting differences in supported sample rates. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-05Merge branch 'for-3.1' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
2011-07-04ASoC: twl6040: Convert into TWL6040 MFD childMisael Lopez Cruz
Convert TWL6040 CODEC driver into a TWL6040 MFD child, it implies that MFD-level operations like register accesses, clock setting and power management are done through MFD APIs, not directly by CODEC driver anymore. To avoid conflicts with the other MFD child, vibrator registers are skipped in CODEC driver. Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-07-04MFD: twl4030-codec -> twl4030-audio: Rename the driverPeter Ujfalusi
Rename the driver, and header file from twl4030-codec to twl4030-audio. To avoid breakage change depending drivers at the same time. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> CC: Misael Lopez Cruz <misael.lopez@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com>
2011-06-24treewide: Fix recieve/receive typosJoe Perches
Just spelling fixes. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-07ASoC: core - Optimise and refactor pcm_new() to pass only rtdLiam Girdwood
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI. Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains card, pcm and DAI along with other members too that are useful too. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-06-06ASoC: Add context parameter to card DAPM callbacksMark Brown
The card callback will get called for each DAPM context in the card so it can be useful for it to know which device is currently undergoing a transition. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-06-03ASoC: OMAP: Update Makefile and Kconfig for HDMI audioRicardo Neri
Update Makefile and Kconfig to build HDMI audio support for OMAP4 SDP and Panda boards. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-06-03ASoC: OMAP4: Add HDMI Audio machine driver for OMAP4 boardsRicardo Neri
Add machine driver for HDMI audio on OMAP4 boards. This driver is in charge of putting together the HDMI audio codec and the CPU DAI and register the HDMI sound card with ALSA. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-06-03ASoC: OMAP: Add CPU DAI driver for HDMIRicardo Neri
Addition of the HDMI CPU DAI driver for OMAP4. This driver is in charge of configuring DMA settings for HDMI. Also, it finds the HDMI video device and determines if audio playback can proceed. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-05-26Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (33 commits) OMAP3: PM: Boot message is not an error, and not helpful, remove it OMAP3: cpuidle: change the power domains modes determination logic OMAP3: cpuidle: code rework for improved readability OMAP3: cpuidle: re-organize the C-states data OMAP3: clean-up mach specific cpuidle data structures OMAP3 cpuidle: remove useless SDP specific timings usb: otg: OMAP4430: Powerdown the internal PHY when USB is disabled usb: otg: OMAP4430: Fixing the omap4430_phy_init function usb: musb: am35x: fix compile error when building am35x usb: musb: OMAP4430: Power down the PHY during board init omap: drop board-igep0030.c omap: igep0020: add support for IGEP3 omap: igep0020: minor refactoring omap: igep0020: name refactoring for future merge with IGEP3 omap: Remove support for omap2evm arm: omap2plus: GPIO cleanup omap: musb: introduce default board config omap: move detection of NAND CS to common-board-devices omap: use common initialization for PMIC i2c bus omap: consolidate touch screen initialization among different boards ...
2011-05-13omap: Remove support for omap2evmTony Lindgren
The board support has never been merged for it as noticed by Russell King <linux@arm.linux.org.uk>. So let's remove the related dead code. Cc: linux-fbdev@vger.kernel.org Cc: alsa-devel@alsa-project.org Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-13ASoC: omap-mcbsp: Remove restrictive checks for cpu typeSanjeev Premi
Current checks for cpu type were too restrictive leading to failures for other silicons in same family. The problem was found while testing audio playback on AM37x and AM35x processors. But should exist on OMAP36xx as well. Signed-off-by: Sanjeev Premi <premi@ti.com> cc: Mark Brown <broonie@opensource.wolfsonmicro.com> cc: Liam Girdwood <lrg@ti.com> cc: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-05-13ASoC: omap-pcm: Period wakeup disabling on OMAP2+Peter Ujfalusi
Allow disabling ALSA period wakeup interrupts. This can only be done on OMAP2+ (2/3/4), since there we can chain the DMA. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Liam Girdwood <lrg@ti.com>
2011-05-11ASoC: RX51: Update e-mail addressPeter Ujfalusi
2011-05-11ASoC: omap-pcm: Update e-mail addressPeter Ujfalusi
2011-05-11ASoC: omap-mcbsp: Update e-mail addressPeter Ujfalusi
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits) ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl ALSA: aloop - Fix possible IRQ lock inversion ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail() ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination ALSA: firewire - msleep needs delay.h ALSA: firewire-lib, firewire-speakers: handle packet queueing errors ALSA: firewire-lib: allocate DMA buffer separately ALSA: firewire-lib: use no-info SYT for packets without SYT sample ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver ALSA: hda - Remove an unused variable in patch_realtek.c ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs ALSA: hda - Move default input-src selection to init part ALSA: hda - Initialize special cases for input src in init phase ALSA: ctxfi - Clear input settings before initialization ALSA: ctxfi - Fix SPDIF status retrieval ALSA: ctxfi - Fix incorrect SPDIF status bit mask ALSA: ctxfi - Fix microphone boost codes/comments ALSA: atiixp - Fix wrong time-out checks during ac-link reset ALSA: intel8x0m: append 'm' to "r_intel8x0" ...
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-09ASoC: AM3517: Update codec name after multi-component updateAbhilash K V
The i2c client device name (".2-001a" in this case, including the separator period) for the AIC23 codec on the TI AM3517-EVM was appended to the codec_name member of am3517evm_dai to resolve the names mismatch happening in soc_bind_dai_link(), due to which the card was not getting registered. Signed-off-by: Abhilash K V <abhilash.kv@ti.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-09ASoC: omap: rx51: Enable McBSP2 sidetoneJarkko Nikula
McBSP sidetone is needed in telephony applications. McBSP sidetone is a configurable FIR filter that forms a loopback from McBSP input to output. This patch enables the McBSP2 sidetone ALSA controls so that it can be used on Nokia RX-51/N900. Sidetone feature can be tested with following commands: (set up codec input and output paths) # Enable and configure sidetone amixer -D hw:0 set 'McBSP2 Sidetone' on amixer set -D hw:0 'McBSP2 Sidetone Channel 0' 32767 echo 32767 >/sys/devices/platform/omap-mcbsp.2/st_taps # Do not loop audio via CPU arecord -f dat >/dev/null |aplay /dev/zero Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-24ASoC: McBSP: get hw params from McBSP driverKishon Vijay Abraham I
Removed the use of macros to obtain base address and DMA channel number. Instead use the McBSP driver API's that passes base address and DMA channel number to the client driver. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-22ASoC: omap: rx51: Add FM transmitter supportJarkko Nikula
Si4713 FM transmitter on Nokia RX-51/N900 is connected to same Line out signals of TLV320AIC34 than TPA6130 headphone amplifier. This patch adds route to transmitter and "FM Transmitter" control to keep route active when needed. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-16Merge branches 'devel-cleanup', 'devel-board', 'devel-early-init' and ↵Tony Lindgren
'devel-ti816x' into omap-for-linus
2011-02-15ASoC: omap: rx51: Report headset insertion instead of video out cableJarkko Nikula
It is more usefull to report headset instead of video out cable in response to jack insertion as this is more usual use-case and because now the headset feature is supported. Automatic accessory detection is not possible at the moment so most sensible static accessory type have to be used. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-15ASoC: omap: rx51: Add headset supportJarkko Nikula
This patch adds support for headset microphone in Nokia RX-51/N900. The mic signal from audio jack is routed to codec A LINE1L via two switches and the mic bias is coming from codec B part. First switch is the tv-out switch that is already supported and the second switch selects between voltage detection circuit and codecs. As there is no use for voltage detection at the moment the second switch is connected statically to codecs in rx51_soc_init. Headset can be active when control "Jack Function" is set to "Headset". Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-15ASoC: omap: rx51: Use gpio_request_one to configure tvout_sel gpioJarkko Nikula
Just slight cleanup to be sync with upcoming change. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-01Merge branch 'for-2.6.39' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into for-2.6.39
2011-02-01ASoC: Amstrad Delta: fix const related build errorJanusz Krzysztofik
The Amstrad Delta ASoC driver used to override the digital_mute() callback, expected to be not provided by the on-board CX20442 CODEC driver, with its own implementation. While this is still posssible when substituting the whole empty snd_soc_dai_driver.ops member (the CX20442 case), replacing snd_soc_dai_ops.digital_mute only is no longer correct after the snd_soc_dai_driver.ops member has been constified, and results in build error. Drop this actually not used code path in hope the CX20442 driver never provides its own snd_soc_dai_ops structure. Created and tested against linux-2.6.38-rc2 Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-02-01ASoC: omap: rx51: Add earphone supportJarkko Nikula
Earphone in Nokia RX-51/N900 is connected to left HP output of B part of the TLV320AIC34 dual codec. In RX-51 the codec A is used as a traditional codec and the codec B as an auxiliary device. Audio from codec A goes via the codec B to earphone: MONO_LOUT of A -> LINE2R of B (B interconnects) -> HPLOUT of B -> Earphone. Take earphone into use by utilizing the recent ASoC auxiliary and cross-device support. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-27omap: Start using CONFIG_SOC_OMAPTony Lindgren
We want to have just CONFIG_ARCH_OMAP2, 3 and 4. The rest are nowadays just subcategories of these. Search and replace the following: ARCH_OMAP2420 SOC_OMAP2420 ARCH_OMAP2430 SOC_OMAP2430 ARCH_OMAP3430 SOC_OMAP3430 No functional changes. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Sourav Poddar <sourav.poddar@ti.com>
2011-01-27ASoC: omap: rx51: Add stereo output support to audio jackJarkko Nikula
Audio jack in Nokia RX-51/N900 is driven by TPA6130 headphone amplifier. This patch adds support for it and stereo output can be active when "Jack Function" == "TV-OUT" || "Headphone". As the TPA6130 can output very high volume levels the output is limited with snd_soc_limit_volume. Limiting value is found from Maemo kernel sources. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12Merge branch 'for-2.6.38' of ↵Takashi Iwai
2011-01-05ASoC: Remove needless inclusion of tlv320aic3x.h from machine driversJarkko Nikula
After multi-component conversion these machine drivers don't actually need anything from sound/soc/codecs/tlv320aic3x.h so don't include it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-23ASoC: mcbsp: Add McBSP support for OMAP4Jorge Eduardo Candelaria
This patch adds McBSP support for the OMAP4 CPU Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Signed-off-by: Margarita Olaya Cabrera <magi.olaya@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-17Merge branch 'for-2.6.38' of ↵Takashi Iwai
2010-12-14ASoC: sdp4430: Add Jack supportJorge Eduardo Candelaria
Use jack framework to enable detection for the headset microphone and stereo output in the sdp4430. Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Signed-off-by: David Anders <x0132446@ti.com> Signed-off-by: Margarita Olaya Cabrera <magi.olaya@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-09ASoC: sdp4430: Enable FM stereo pinsJorge Eduardo Candelaria
Add FM stereo pins to the machine driver and add them as a dapm widget. Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Signed-off-by: Margarita Olaya Cabrera <magi.olaya@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-03Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-12-02ASoC: omap: N810: Don't select CONFIG_OMAP_MUX but make it as dependencyJarkko Nikula
Not all omap boards use kernel based pin multiplexing so CONFIG_SND_OMAP_SOC_N810 should not select it by default as it can make harm to other boards in multi-board kernels. Therefore put CONFIG_OMAP_MUX as a dependency to N810 ASoC machine driver. Thanks to Tony Lindgren <tony@atomide.com> for noticing. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-25Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-25ASoC: Fix resource reclaim for osk5912Axel Lin
In current implementation, there are resources leak in the error path. This patch properly reclaims the allocated resources in the error path. Also adds a missing clk_put in osk_soc_exit. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-24Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
