path: root/sound/soc/omap
2010-08-02ASoC: omap-mcbsp: Remove period size constraint in THRESHOLD modePeter Ujfalusi
The use of sDMA packet mode in THRESHOLD mode removes the restriction on the period size. With the extended THRESHOLD mode user space can ask for any period size it wishes, and the driver will configure the sDMA and McBSP FIFO accordingly. Replace the hw_rule for the period size with static constraint, which will make sure that the period size will be always even (to avoid prime period size, which could be possible in mono stream) Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-02ASoC: omap-mcbsp: Support for sDMA packet modePeter Ujfalusi
Utilize the sDMA controller's packet syncronization mode, when the McBSP FIFO is in use (by extending the THRESHOLD mode). When the sDMA is configured for packet mode, the sDMA frame size does not need to match with the McBSP threshold configuration. Uppon DMA request the sDMA will transfer packet size number of words, and still trigger interrupt on frame boundary. The patch extends the original THRESHOLD mode by doing the following: if (period_words <= max_threshold) Current THRESHOLD mode configuration Otherwise (period_words > max_threshold) McBSP threshold = sDMA packet size sDMA frame size = period size With the extended THRESHOLD mode we can remove the constraint for the maximum period size, since if the period size is bigger than the maximum allowed threshold, than the driver will switch to packet mode, and picks the best (biggest) threshold value, which can divide evenly the period size. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-02ASoC: omap-mcbsp: Code cleanup in omap_mcbsp_dai_hw_paramsPeter Ujfalusi
To make the code a bit more readable, change the indexed references to the omap_mcbsp_dai_dma_params elements with pointer. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-02ASoC: omap-mcbsp: Restructure the code within omap_mcbsp_dai_hw_paramsPeter Ujfalusi
In preparation for the extended threshold mode (sDMA packet mode support), the code need to be restructured. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-06-23ASoC: RX-51: Add basic jack detectionJarkko Nikula
This patch adds GPIO jack detection to Nokia N900/RX-51. At the moment only SND_JACK_VIDEOOUT type is reported. More types could be reported after getting more audio features supported and necessary drivers integrated for implementing automated accessory detection. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-06-23ASoC: RX-51: Add Jack Function kcontrolJarkko Nikula
Nokia RX-51/N900 has multifunction 4-pole audio-video jack that can be used as headphone, headset or audio-video connector. This patch implements the control 'Jack Function' which is used to select the desired function. At the moment only TV-out without audio is supported. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-06-21ASoC: pandora: fix CLKX polarityGrazvydas Ignotas
After mass production started it was found that several boards exhibit noise problems during sound playback. After some investigation it was determined that CLKX polarity is set incorrectly, and even if most boards can tolerate the wrong setting, there are some that don't. Fix polarity setup in the board file. As the clock settings for input and output now match, merge in and out functions and structures to simplify code. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-06-03ASoC: omap-mcbsp: Place correct constraints for streamsPeter Ujfalusi
OMAP McBSP FIFO is word structured: McBSP2 has 1024 + 256 = 1280 word long buffer, McBSP1,3,4,5 has 128 word long buffer This means, that the size of the FIFO depends on the McBSP word size configuration. For example on McBSP3: 16bit samples: size is 128 * 2 = 256 bytes 32bit samples: size is 128 * 4 = 512 bytes It is simpler to place constraint for buffer and period based on channels. McBSP3 as example again (16 or 32 bit samples): 1 channel (mono): size is 128 frames (128 words) 2 channels (stereo): size is 128 / 2 = 64 frames (2 * 64 words) 4 channels: size is 128 / 4 = 32 frames (4 * 32 words) Use the second method to place hw_rule on buffer size, and in threshold mode to period size. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolsfonmicro.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-06-03ASoC: omap-mcbsp: Save, and use wlen for threshold configurationPeter Ujfalusi
Save the word length configuration of McBSP, and use that information to calculate, and configure the threshold in McBSP. Previously the calculation was only correct when the stream had 16bit audio. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolsfonmicro.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-05-19ASoC: sdp4430 - add sdp4430 pcm ops to DAI.Liam Girdwood
Fix build warning about unused ops and add ops to the sdp4430 DAI link. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-19ASoC: SDP4430: Add support for Earphone speakerJorge Eduardo Candelaria
Enable earphone speaker in sdp4430 machine driver. Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Signed-off-by: Margarita Olaya Cabrera <magi.olaya@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-19ASoC: SDP4430: Add sdp4430 machine driverMisael Lopez Cruz
Add ASoC support for TI SDP4430. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Margarita Olaya Cabrera <magi.olaya@ti.com> Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-14OMAP: McBSP: Add 32-bit mode supportSergey Lapin
This patchs should allow to use 32-bit samples on e.g. TLV320AIC3x codec, or others. Signed-off-by: Sergey Lapin <slapin@ossfans.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-06ASoC: omap: Add basic audio support for Nokia RX-51/N900Jarkko Nikula
This patch adds support for integrated stereo speakers and digital microphone found on Nokia RX-51 hardware. This is a cut down version based on Maemo kernel sources and earlier patchset by Eduardo Valentin et al. http://mailman.alsa-project.org/pipermail/alsa-devel/2009-October/022033.html Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Eduardo Valentin <eduardo.valentin@nokia.com> Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Eduardo Valentin <eduardo.valentin@nokia.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-04-28ASoC: zoom2 - update DAPM pinsLiam Girdwood
Remove bogus twl4030 pins Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-04-28ASoC: pandora - update DAPM pinsLiam Girdwood
Remove bogus TWL4030 pins. Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-04-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: mixart: range checking proc file ALSA: hda - Fix a wrong array range check in patch_realtek.c ALSA: ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_stream ALSA: hda - Enable amplifiers on Acer Inspire 6530G ASoC: Only do WM8994 bias off transition from standby ASoC: Don't use DCS_DATAPATH_BUSY for WM hubs devices ASoC: Don't do runtime wm_hubs DC servo updates if using offset correction ASoC: Support second DC servo readback method for wm_hubs ASoC: Avoid wraparound in wm_hubs DC servo correction ALSA: echoaudio - Eliminate use after free ALSA: i2c: cleanup: change parameter to pointer ALSA: hda - Add MSI blacklist for Aopen MZ915-M ASoC: OMAP: Fix capture pointer handling for OMAP1510 to work correctly with recent ALSA PCM code ALSA: hda - Update document about MSI and interrupts ALSA: hda: Fix 0 dB offset for Lenovo Thinkpad models using AD1981 ALSA: hda - Add missing printk argument in previous patch ASoC: Fix passing platform_data to ac97 bus users and fix a leak ALSA: hda - Fix ADC/MUX assignment of ALC269 codec ALSA: hda - Fix invalid bit values passed to snd_hda_codec_amp_stereo() ASoC: wm8994: playback => capture
2010-04-05Merge branch 'for-2.6.34' into for-2.6.35Mark Brown
Conflicts due to context changes next to the backported DMA data change: include/sound/soc.h
2010-04-05ALSA: ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_streamDaniel Mack
This fixes a memory corruption when ASoC devices are used in full-duplex mode. Specifically for pxa-ssp code, where this pointer is dynamically allocated for each direction and destroyed upon each stream start. All other platforms are fixed blindly, I couldn't even compile-test them. Sorry for any breakage I may have caused. [Note that this is a backported version for 2.6.34. Upstream commit is fd23b7dee] Signed-off-by: Daniel Mack <daniel@caiaq.de> Reported-by: Sven Neumann <s.neumann@raumfeld.com> Reported-by: Michael Hirsch <m.hirsch@raumfeld.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-04-02ASoC: OMAP: Fix capture pointer handling for OMAP1510 to work correctly with ↵Janusz Krzysztofik
recent ALSA PCM code With recent (2.6.34) chnages in PCM handling, capture stopped working on my OMAP1510 based Amstrad Delta videophone. Using 2.6.34-rc2, I was able to correct the problem in 3 different ways: 1. reverting commit 7b3a177b0d4f92b3431b8dca777313a07533a710, 2. enabling additional jiffies check with echo 4 >/proc/asound/card0/pcm0c0/xrun_debug 3. applying the patch below. Since I wasn't able to reproduce the problem on my i686 PC, I guess the problem is probably machine specific. The patch reuses the method for software emulation of missing hardware pointer, already implemented for playback on OMAP1510. It's possible that event if a hardware pointer is available for capture on this machine, its behaviour may be not compatible with what upper layer expects. If you think the problem may be more general and should be solved differently, on a higher level, I can try to work more on it if you give me a hint. If the patch gets accepted, I suggest it goes as a fix in the current release cycle. Created and tested against linux-2.6.34-rc2. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-19ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_streamDaniel Mack
This fixes a memory corruption when ASoC devices are used in full-duplex mode. Specifically for pxa-ssp code, where this pointer is dynamically allocated for each direction and destroyed upon each stream start. All other platforms are fixed blindly, I couldn't even compile-test them. Sorry for any breakage I may have caused. Reported-by: Sven Neumann <s.neumann@raumfeld.com> Reported-by: Michael Hirsch <m.hirsch@raumfeld.com> Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-19ASoC: omap-mcbsp: Add support for Left Justified formatPeter Ujfalusi
Basic support for Left Justified coding for OMAP McBSP. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-19ASoC: McPDM: Use tabs for indentationJorge Eduardo Candelaria
Indentation in initial support for McPDM driver was converted to spaces. Use tabs to comply with open source coding-style. Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-12ASoC: OMAP3: Report delay caused by the internal FIFOPeter Ujfalusi
Use the new delay calback function to report the delay through ALSA for application caused by the internal FIFO. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-03-01Merge with mainline to remove plat-omap/Kconfig conflictTony Lindgren
Conflicts: arch/arm/plat-omap/Kconfig
2010-02-23ASoC: OMAP-McBSP: ASoC interface for McBSP sidetoneIlkka Koskinen
Add ASoC interface for OMAP McBSP2 and McBSP3 sidetones. Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-23ASoC: OMAP4: Add McPDM platform driverMisael Lopez Cruz
McPDM platform driver is configured to use sDMA in order to transfer to/from memory. Support for interfacing with ABE will be added later. McPDM dai currently supports up to 4 downlink channels and 2 uplink channels simultaneously, as well as 88.2 and 96 KHz, and a sample size of 32 bits. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Margarita Olaya <x0080101@ti.com> Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-23ASoC: OMAP4: Add support for McPDMCandelaria Villareal, Jorge
McPDM is the interface between Phoenix audio codec and the OMAP4430 processor. It enables data to be transfered to/from Phoenix at sample rates of 88.4 or 96 KHz. Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Signed-off-by: Margarita Olaya <x0080101@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-23ASoC: OMAP: data_type and sync_mode configurable in audio dmaMisael Lopez Cruz
Allow client drivers to set the data_type (16, 32) and the sync_mode (element, packet, etc) of the audio dma transferences. McBSP dai driver configures it for a data type of 16 bits and element sync mode. Signed-off-by: Misael Lopez Cruz <x0052729@ti.com> Signed-off-by: Jorge Eduardo Candelaria <jorge.candelaria@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-15omap3: Replace ARCH_OMAP34XX with ARCH_OMAP3Tony Lindgren
Replace ARCH_OMAP34XX with ARCH_OMAP3 Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-15omap2: Convert ARCH_OMAP24XX to ARCH_OMAP2Tony Lindgren
Convert ARCH_OMAP24XX to ARCH_OMAP2 Signed-off-by: Tony Lindgren <tony@atomide.com>
2010-02-11Add ASoC support for Devkit8000Thomas Weber
This patch expands the omap3beagle sound soc for the beagle board clone DevKit8000. Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-05ASoC: pandora: Add DAC regulator supportGrazvydas Ignotas
Pandora's external DAC is connected to VSIM TWL4030 supply, so let's start switching it too to save more power. Also DAC got it's own DAPM handler. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-05ASoC: pandora: Add APLL supply to fix audio outputGrazvydas Ignotas
Pandora's external DAC is using 256*Fs output from the TWL4030 codec, and TWL4030 needs to have APLL enabled for it's 256*Fs output to function. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-01-29ASoC: AM3517: ASoC driver not getting compiledAnuj Aggarwal
Commit 761c9d45 (ASoC: Fix build of OMAP sound drivers) changes CONFIG_MACH_OMAP3517EVM -> CONFIG_SND_OMAP_SOC_OMAP3517EVM in the Makefile. Whereas the config option defined in Kconfig is SND_OMAP_SOC_AM3517EVM. Because of this, ASoC driver for AM3517 was not getting compiled. Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-16mfd: twl: fix twl4030 rename for remaining driver, board filesBalaji T K
Recent drivers/mfd/twl4030* renames to twl broke compile for various boards as the series was missing a patch to change the board-*.c files. This patch renames include twl4030.h to include twl.h and also renames twl4030_i2c_ routines. Signed-off-by: Balaji T K <balajitk@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Felipe Balbi <felipe.balbi@nokia.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Overwrite pin config on intel DG45ID board. intelhdmi - dont power off HDA link ALSA: hrtimer - Fix lock-up ALSA: intelhdmi - add channel mapping for typical configurations ALSA: intelhdmi - channel mapping applies to Pin ALSA: intelhdmi - accept DisplayPort pin ALSA: hda - show HBR(High Bit Rate) pin cap in procfs ALSA: hda - Fix LED GPIO setup for HP laptops with IDT codecs ASoC: Fix build of OMAP sound drivers ALSA: opti93x: fix irq releasing if the irq cannot be allocated
2009-12-10ASoC: Fix build of OMAP sound driversOlof Johansson
There are build errors when building for some of the omap2/3 boards without enabling sound: sound/built-in.o:(.data+0x43bc): undefined reference to `soc_codec_dev_tlv320aic23' sound/built-in.o:(.data+0x43cc): undefined reference to `tlv320aic23_dai' Confused me quite a bit since the drivers that had references to the codec weren't enabled. Turns out the Makefile was using the wrong config option to enable them. Patch below. Reported-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-12-08Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (149 commits) arm: omap: Add omap3_defconfig AM35xx: Defconfig for AM3517 EVM board AM35xx: Add support for AM3517 EVM board omap: 3630sdp: defconfig creation omap: 3630sdp: introduce 3630 sdp board support omap3: Add defconfig for IGEP v2 board omap3: Add minimal IGEP v2 support omap3: Add CompuLab CM-T35 defconfig omap3: Add CompuLab CM-T35 board support omap3: rx51: Add wl1251 wlan driver support omap3: rx51: Add SDRAM init omap1: Add default kernel configuration for Herald omap1: Add board support and LCD for HTC Herald omap: zoom2: update defconfig for LL_DEBUG_NONE omap: zoom3: defconfig creation omap3: zoom: Introduce zoom3 board support omap3: zoom: Drop i2c-1 speed to 2400 omap3: zoom: rename zoom2 name to generic zoom omap3: zoom: split board file for software reuse omap3evm: MIgrate to smsc911x ethernet driver ... Fix trivial conflict (two unrelated config options added next to each other) in arch/arm/mach-omap2/Makefile
2009-11-22Merge 7xx-iosplit-plat-merge with omap-fixesTony Lindgren
Merge branch '7xx-iosplit-plat-merge' into omap-for-linus
2009-11-19ASoC: Add support for IGEP v2Enric Balletbò i Serra
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-18Merge branch 'for-2.6.32' into for-2.6.33Mark Brown
2009-11-18ASoC: OMAP3 Pandora: update for TWL4030 codec changesGrazvydas Ignotas
A while ago TWL4030 had it's playback stream name changed, but pandora needs it for it's playback path. Update to correct stream name so that playback works again. Also mark VIBRA output as not connected. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-18ASoC: Modifying the license string GPLv2 for OMAP3 EVMAnuj Aggarwal
Correcting the license string from GPLv2 -> GPL v2. Found the problem while building OMAP3 ASoC driver as module. Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-16ASoC: OMAP: enable Overo driver for CM-T35Mike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-10Merge branch '7xx-iosplit-plat' with omap-fixesTony Lindgren
2009-11-10ASoC: omap-mcbsp - add support for upto 16 channels.Graeme Gregory
This patch increases the number of supported audio channels from 4 to 16 and has been sponsored by Shotspotter Inc. It also fixes a FSYNC rate calculation bug when McBSP is FSYNC master. Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-09ASoC: Pandora: Pass SRG input clock frequency to the OMAP McBSP DAIJarkko Nikula
Upcoming change to omap-mcbsp.c require that machine drivers using OMAP as a DAI master to pass sample rate generator input clock frequency to the omap-mcbsp.c DAI driver. Pandora is using 256*Fs output from the TWL4030 codec as an input clock to the McBSP sample rate generator. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Tested-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
