Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Now that we can specify feature of a particular controller, we can
avoid multiple copies of same code by defining the CDCLKCON bit
feature in controller specific code and detecting that flag in the
code common to all controllers.
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
Acked-by: Ben Dooks <ben-linux@fluff.org>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Now that we have two callbacks s3c2412_i2s_get_clock & s3c64xx_i2s_get_clock
doing exactly the same thing, we can define one generic s3c_i2sv2_get_clock
and discard other two copies. Also, switch the users to make calls to the
newly defined and generic s3c_i2sv2_get_clock
Until now, s3c2412_get_iisclk would return NULL since iis_clk was never
initialized.
Return appropriate pointer as per the selection made for source clock.
The IMS field of s3c2412/13 is essentially the same as that of s3c64xx.
That is, the IISMOD[11] bit decides Master/Slave mode and IISMOD[10] bit
selects source clock for signal generation.
For that reason, remove improper defines for IISMOD[11:10] field mask
and define two 1bit fields that can be set independent of each other.
As a consequence, corresponding fields for PLAT_S3C64XX too get to use
these new defines.
The header for I2Sv2
linux/arch/arm/plat-s3c/include/plat/regs-s3c2412-iis.h
contains only controller specific definitions and nothing
SoC specific. So, it could be moved to sound/soc/s3c24xx/
This fixes a memory corruption when ASoC devices are used in
full-duplex mode. Specifically for pxa-ssp code, where this pointer
is dynamically allocated for each direction and destroyed upon each
stream start.
All other platforms are fixed blindly, I couldn't even compile-test
them. Sorry for any breakage I may have caused.
Reported-by: Sven Neumann <s.neumann@raumfeld.com>
Reported-by: Michael Hirsch <m.hirsch@raumfeld.com>
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
Towards having build for multiple SoCs segregate hw_params callback
for s3c2412 and s3c64xx.
Since, all new SoCs have s3c64xx like register map, we keep that as
default implementation if no SoC specific callback is already defined.
Making room for namespace for the PCM Controller driver
the platform driver(s3c24xx-pcm) has been renamed to SoC
agnostic name 's3c-dma'.
The s3c24xx_pcm prefix for the soc_platform is inappropriate when
some Samsung SoCs have PCM controllers which will eventually have
drivers and hence namespace ambiguities.
To resolve naming ambiguities in future the following have been
renamed in order
1) s3c24xx_pcm_dma_params -> s3c_dma_params
2) s3c24xx_pcm_preallocate_dma_buffer -> s3c_preallocate_dma_buffer
3) s3c24xx_pcm_dmamask -> s3c_dma_mask
4) s3c24xx_pcm_XXX -> s3c_dma_XXX
Remove the <plat/audio.h> include from arch/arm/plat-s3c/include/plat/audio.h
as it provides nothing to the current kernel and is not in any future plans
for the system.
Signed-off-by: Ben Dooks <ben@simtec.co.uk>
Signed-off-by: Simtec Linux Team <linux@simtec.co.uk>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (417 commits)
MAINTAINERS: EB110ATX is not ebsa110
MAINTAINERS: update Eric Miao's email address and status
fb: add support of LCD display controller on pxa168/910 (base layer)
[ARM] 5552/1: ep93xx get_uart_rate(): use EP93XX_SYSCON_PWRCNT and EP93XX_SYSCON_PWRCN
[ARM] pxa/sharpsl_pm: zaurus needs generic pxa suspend/resume routines
[ARM] 5544/1: Trust PrimeCell resource sizes
[ARM] pxa/sharpsl_pm: cleanup of gpio-related code.
[ARM] pxa/sharpsl_pm: drop set_irq_type calls
[ARM] pxa/sharpsl_pm: merge pxa-specific code into generic one
[ARM] pxa/sharpsl_pm: merge the two sharpsl_pm.c since it's now pxa specific
[ARM] sa1100: remove unused collie_pm.c
[ARM] pxa: fix the conflicting non-static declarations of global_gpios[]
[ARM] 5550/1: Add default configure file for w90p910 platform
[ARM] 5549/1: Add clock api for w90p910 platform.
[ARM] 5548/1: Add gpio api for w90p910 platform
[ARM] 5551/1: Add multi-function pin api for w90p910 platform.
[ARM] Make ARM_VIC_NR depend on ARM_VIC
[ARM] 5546/1: ARM PL022 SSP/SPI driver v3
ARM: OMAP4: SMP: Update defconfig for OMAP4430
ARM: OMAP4: SMP: Enable SMP support for OMAP4430
Move all the gpio functions out of <mach/hardware.h> as
this file is for defining the generic IO base addresses
for the kernel IO calls.
Make a new header <mach/gpio-fns.h> to take this and
include it via the chain from <linux/gpio.h> which is
what most of these files should be using (and will be
changed as soon as possible).
Note, this does make minor changes to some drivers but
should not mess up any pending merges.
CC: Richard Purdie <rpurdie@rpsys.net>
CC: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Fix accidental change of <mach/regs-gpio.h> to
<plat/regs-gpio.h> in s3c2412-i2s.c
Merge Eric Maio's patch to merge snd_soc_dai_ops out of line. Fixed
merge issues and updated drivers, plus an issue with the ops for the two
s3c2443 AC97 DAIs having been merged.
The recent set of S3C64xx patches re-added a lot of uses of DBG() that
had previously been removed - revert this so the standard pr_debug()
macro is used.
The S3C2412 I2S (IIS) interface is replicated on further Samsung SoC
parts in a broadly compatible way, so split the common code out into
a core called s3c-i2s-v2.[ch] so that the newer SoCs such as the
S3C6410 can make use of it.
As such, all the original s3c2412 functions are currently being left
with their original names, and will be renamed later in the series.
The <mach/audio.h> file needs to be common to both ARCH_S3C2410 and
ARCH_S3C64XX as they share common driver code, so move it to <plat/audio.h>.
Move the IIS headers to their correct place.
Considering the fact that most cpu_dai or codec_dai are using a same
'snd_soc_dai_ops' for several similar interfaces, 'ops' would be better
made a pointer instead, to make sharing easier and code a bit cleaner.
The patch below is rather preliminary since the asoc tree is being
actively developed, and this touches almost every piece of code,
(and possibly many others in development need to be changed as
well). Building of all codecs are OK, yet to every SoC, I didn't test
that.
Signed-off-by: Eric Miao <eric.miao@marvell.com>
The module init entries should be __init instead of __devinit.
Register all platform DAIs with the core. In line with current behaviour
this is done at module probe time rather than when the devices are probed
(since currently that only happens as the entire ASoC card is registered
except for those drivers that currently implement some kind of hotplug).
Since the core currently ignores DAI registration this has no practical
effect.
None of the DAIs use it except s3c2412-i2s which only uses it for
dev_() printouts.
DAI type information is only ever used within ASoC in order to special
case AC97 and for diagnostic purposes. Since modern CPUs and codecs
support multi function DAIs which can be configured for several modes
it is more trouble than it's worth to maintain anything other than a
flag identifying AC97 DAIs so remove the type field and replace it with
an ac97_control flag.
Liam Girdwood's ASoC v2 work avoids having two different ops structures
for DAIs by merging the members of struct snd_soc_ops into struct
snd_soc_dai_ops, allowing per DAI configuration for everything.
Backport this change.
This paves the way for future work allowing any combination of DAIs to
be connected rather than having fixed purpose CODEC and CPU DAIs and
only allowing CODEC<->CPU interconnections.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
This patch merges struct snd_soc_codec_dai and struct
snd_soc_cpu_dai into struct snd_soc_dai for the S3C24xx platform.
Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
This allows per-DAI initialisation to be done by the CPU DAI drivers.
Support for suspend/resume for the S3C2412 ASoC IIS
core driver.
S3C2412 SoC IIS support for ALSA/ASoC
