Replace GPL v2.0 license statements with SPDX license identifier.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Make these const as they are only stored in the ops field of a
snd_soc_dai_link structure, which is const.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
Set the dai_fmt field in the dai_link struct instead of manually calling
snd_soc_dai_fmt(). This makes the code cleaner and shorter.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the samsung include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: Liam Girdwood <lrg@ti.com>
Cc: linux-samsung-soc@vger.kernel.org
Currently ASoC can only add kcontrols using codec and platform component device
handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for
SoC card machine drivers too. This allows the kcontrol to have a direct handle to
the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily
get it's private data.
This change makes snd_soc_add_controls() static and wraps it in the folowing
calls (card and dai are new) :-
snd_soc_add_card_controls()
snd_soc_add_codec_controls()
snd_soc_add_dai_controls()
snd_soc_add_platform_controls()
This patch also does a lot of small mechanical changes in individual codec drivers
to replace snd_soc_add_controls() with snd_soc_add_codec_controls().
It also updates the McBSP DAI driver to use snd_soc_add_dai_controls().
Finally, it updates the existing machine drivers that register controls to either :-
1) Use snd_soc_add_card_controls() where no direct codec control is required.
2) Use snd_soc_add_codec_controls() where there is direct codec control.
In the case of 1) above we also update the machine drivers to get the correct
component data pointers from the kcontrol (rather than getting the machine pointer
via the codec pointer).
Signed-off-by: Liam Girdwood <lrg@ti.com>
Lots of sound drivers were getting module.h via the implicit presence
of it in <linux/device.h> but we are going to clean that up. So
fix up those users now.
It is exported via resume callback of struct dev_pm_ops rather than referenced
directly and so should be staticised.
This patch remove including unnecessary/duplicated headers which relative
with Samsung SoCs.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
Acked-by: Jassi Brar <jassi.brar@samsung.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Finally, move the 's3c24xx' directory to 'samsung'
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
