commit 8b27418f300cafbdbbb8cfa9c29d398ed34d6723 upstream.
If the "clock-frequency" DT property is not found, req_rate is used
uninitialized, and the "audio_clkout" clock will be created with an
arbitrary clock rate.
This uninitialized kernel stack data may leak to userspace through
/sys/kernel/debug/clk/clk_summary, cfr. the value in the "rate" column:
clock enable_cnt prepare_cnt rate accuracy phase
audio_clkout 0 0 4001836240 0 0
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Thong Ho <thong.ho.px@rvc.renesas.com>
Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com>
rsnd_ssi_use_busif() and rsnd_ssi_is_pin_sharing() are the function
which returns current SSI status. But these requests duplicated parameter.
This patch removes duplicated parameter.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
2a46db4a3("ASoC: rsnd: add AUDIO_CLKOUT support") added AUDIO_CLKOUT
support for ADG. But single AUDIO_CLKOUT needs clkout_name[CLKOUT],
not clkout_name[i]. Kernel will have NULL pointer access without this
patch.
Renesas sound has AUDIO_CLKOUT (in Gen1/Gen2) AUDIO_CLKOUT1/2/3 (in Gen3)
This patch support these patches as clock provider.
undefined clock is not error. Accept such case. And this is prepare
for clock out support in the same time.
It didn't have "\n", and indicated different data
Current ADG clock calculation needs ADG and SSI settings.
Thus, SSI side clock request function depends on ADG settings.
After reconsideration, we can close this method inside ADG.
This function uses new method. And it becomes preparation for
AUDIO_CLKOUT support.
ADG is special IP since it doesn't have MSTP. And now, ADG has common
mod base register access. We can now setup ADG initial setting when
probe timing. It is needed if sound card is based on AUIDO_CLK which
is used as Master clock.
Renesas sound has SSI/SRC/DVC/MIX/ADG modules, and these have original
register mapping. Thus this driver is using regmap field, and each module
is using it based on each module ID.
Sometimes, each module needs other module to controlling. but current each
function is using just "mod" as parameter name. This is confusable.
For example, if SSI0 and SRC2 are connected, and if SRC module function
has bug of module access, and if it needs to control connected SSI,
SRC function will access to SSI2 (It should access to SSI0, but it uses
SRC's ID 2). This is easy to happen in current driver style.
To avoid this kind of confusable trouble, this patch adds module confirm
macro for debug purpose.
Renesas sound has ADG IP, but it is special device.
(It is clock generater, and it doesn't need MSTP)
Thus, ADG didn't use mod base common method on rsnd driver.
But it can be confusable point. Let's use common method
sh_clk header is not needed, and it will create confusion.
Let's remove it.
This patch removes useless debug message. especially some kind of
"probed" message will be printed from core.c if it has #define DEBUG
Current rsnd driver's many functions requests struct rsnd_dai (= rdai),
but, 1) we can get rdai from rsnd_io_to_rsnd(), 2) almost all rdai
is not used. Let's remove these rdai.
Current rsnd driver can use rsnd_io_to_rdai()
we can get play/capture direction via io now.
Let's replace rsnd_dai_is_play() to rsnd_io_is_play()
master clock rate is useful information for debug.
This patch adds DVC (Digital Volume Controller)
support which is member of CMD unit.
Signed-off-by: Mark Brown <broonie@linaro.org>
All platform which used old style was
switched to new style.
R-Car sound can remove old style clock support,
use device dependent clock now.
Support for loading the Renesas R-Car sound driver via DeviceTree.
Now, rsnd_xxx_remove() do nothing.
remove these
rsnd_adg_ssi_ws_timing_gen2() returns SSI WS timing,
and it used "mod" as parameter.
but, this "mod" is sometimes not ssi mod.
Get SSI mod from rsnd_dai_stream
priv has rcar_snd_info pointer.
having priv and info in same time is verbose.
DIV_EN register enable bit is required when you use Gen2 SRC
Current for_each_rsnd_xxx macro will read out-of-array's
memory after last loop operation.
It was not good C language operation, and the binary which was
compiled by (at least) gcc 4.8.1 is broken
This patch tidyup these issues
Current R-Car sound driver is using device
independent audio clock, but it is not good
design for DT support.
This patch adds device dependent clock support.
But, there are some platform which is using
independent audio clock.
It is still supported at this point,
but it will be removed soon.
Renesas sound Gen2 has SRC (= Sampling Rate Converter)
which needs 2 DMAC.
The data path image when you use SRC on Gen2 is
[mem] -> Audio-DMAC -> SRC -> Audio-DMAC-peri-peri -> SSIU -> SSI
This patch support SRC and DMAEnine.
It is tested on R-Car H2 Lager board
SRC clock and timing setting register
exist in SRU and ADG on Gen1.
But, these are merged into ADG on Gen2.
Current driver is supporting Gen1 SRC only
at this point, but, above settings are
set as different function.
This patch merges these as preparation of Gen2 support.
This patch adds SRC support to Renesas sound driver.
SRC converts sampling rate between codec <-> cpu.
It needs special codec chip,
or very simple DA/AD converter to use it.
This patch was tested via ak4554 codec,
and supports Gen1 only at this point.
This driver is assuming that
RBGA is used as source clock of 44.1kHz category, and
RBGB is used as source clock of 48kHz category.
This patch clarifies the variable name.
This patch adds rsnd_adg_set_ssi_clk() to access to
AUDIO_CLK_SEL0/1/2, and removes last user of
rsnd_write/read/bset which is very low level function.
adg.c only used rsnd_priv_read/write/bset()
which is the only user of NULL mod.
but, it can be removed.
${LINUX}/sound/soc/sh driver can be compiled from
SuperH and ARM.
but, ${LINUX}/sound/soc/sh/rcar driver included
SH-ARM specific header.
This patch removes it
Renesas R-Car series sound circuit consists of SSI and its peripheral.
But this peripheral circuit is different between
R-Car Generation1 (E1/M1/H1) and Generation2 (E2/M2/H2)
(Actually, there are many difference in Generation1 chips)
This patch adds ADG feature which controls sound clock
