Currently the condition for these WARN_ONs is reversed and they are placed
before the actual check whether we are going to write to that register. So if
the codec implements the register_writable callback we'll get a warning for each
writable register when syncing the register cache.
While we are at it change the check to use snd_soc_codec_writable_register
instead of open-coding it.
Acked-by: Liam Girdwood <lrg@ti.com>
For clarity and to help ongoing refactoring in this area create a new file
to contain the physical I/O functions, separating them out from the cache
operations.
We've got a whole bunch of functions which just call straight through to
do_hw_read(). Simplify this situation by removing them and using hw_read()
directly.
Currently the rbtree code will write out the entire register map when
doing a cache sync which is wasteful and will slow things down. Check
to see if the value we're about to write is the default and don't bother
restoring it if it is, either the value will have been retained or the
device will have been reset and holds the value already.
We should really store the defaults in the nodes but this resolves the
immediate issue.
Run the data through cpu_to_be16() so it's at least clear what we're up to.
Make it clear what we're doing.
Whenever we are doing a read or a write through the rbtree code, we'll
cache a pointer to the rbnode. To avoid looking up the register
everytime we do a read or a write, we first check if it can be found in
the cached register block, otherwise we traverse the rbtree and finally
cache the rbnode for future use.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
This patch prepares the ground for the actual rbtree optimization patch
which will save a pointer to the last accessed rbnode that was used
in either the read() or write() functions.
Each rbnode manages a variable length block of registers. There can be no
two nodes with overlapping blocks. Each block has a base register and a
currently top register, all the other registers, if any, lie in between these
two and in ascending order.
The reasoning behind the construction of this rbtree is simple. In the
snd_soc_rbtree_cache_init() function, we iterate over the register defaults
provided by the driver. For each register value that is non-zero we
insert it in the rbtree. In order to determine in which rbnode we need
to add the register, we first look if there is another register already
added that is adjacent to the one we are about to add. If that is the case
we append it in that rbnode block, otherwise we create a new rbnode
with a single register in its block and add it to the tree.
In the next patch, where a cached rbnode is used by both the write() and the
read() functions, we also check if the register we are about to add is in the
cached rbnode (the least recently accessed one) and if so we append it in that
rbnode block.
There is an unfortunate difference in return values between spi_write()
and i2c_master_send() so we need an adaptor function to translate.
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
do_spi_write() is just an open coded copy of do_spi_write() so we can
delete it and just call spi_write() directly. Indeed, as a result of
recent refactoring all the SPI write functions are just very long
wrappers around spi_write() which don't add anything except for some
pointless copies so we can just use spi_write() as the hw_write
operation directly. It should be as type safe to do this as it is to do
the same thing with I2C and it saves us a bunch of code.
snd_soc_4_12_spi_write() contains a byte swap. Since this code was written
for an Analog CODEC on a Blackfin reference board it appears that this is
done because while Blackfin is little endian the CODEC is big endian (as
are most CODECs).
Push this up into the generic 4x12 write function and use cpu_to_be16() to
do the byte swap so things are more regular and things work on both CPU
endiannesses.
Currently we'll force all registers to fit in 8 bits before passing
down to the I/O function. Looks like a cut'n'paste bug.
snd_soc_hw_bulk_write_raw()
If we specifically want to write a block of data to the hw bypassing the
cache, then allow this to happen inside snd_soc_hw_bulk_write_raw().
`type` parameter is not longer used in `snd_soc_codec_set_cache_io`,
so remove this line.
Signed-off-by: Lu Guanqun <guanqun.lu@intel.com>
Lines should be less than 80 columns.
We don't need to log every I2C transfer, and certainly not at error level.
This patch fixes to avoid compile error when ASoC codec doesn't use I2C
nor SPI on snd_soc_hw_bulk_write_raw().
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
When syncing the cache, if the driver has given us a writable_register()
callback, use it to check if we are syncing a non-writable register
and if so warn the user.
By using struct snd_soc_reg_access for the read/write/vol attributes
of the registers, we provide callbacks that automatically determine whether
a given register is readable/writable or volatile.
These functions fail with -EINVAL if the corresponding callbacks
are not implemented. Change them to return -ENOSYS as it is more
appropriate for unimplemented callbacks.
The handling of all snd_soc_x_y_spi_write() functions is similar.
Create a separate function and update all callers to use it.
The handling of all snd_soc_x_y_read() functions is similar.
Factor it out into a separate function and update all callers.
The handling of all snd_soc_x_y_write() functions is similar.
Factor it out into a separate function and update all functions
to use it.
As it has become more common to have to write firmware or similar
large chunks of data to the hardware, add a function to perform
raw bulk writes that bypass the cache. This only handles volatile
registers as we should avoid getting out of sync with the actual
cache.
The handling of all snd_soc_x_y_read_i2c() functions is similar.
Make a generic I2C read function and update all callers to use it.
The patch c358e640a66 "ASoC: soc-cache: Add trace event for
snd_soc_cache_sync()" introduced a dereference of "codec->cache_ops"
before we had checked it for NULL.
I pulled the check forward, and then pulled everything in an indent
level.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch makes it easy to see when the syncing process begins and
ends. You can also enable the snd_soc_reg_write tracepoint to see
which registers are being synced.
Incorporate the use of the cache_bypass functionality in the
syncing functions. The snd_soc_flat_cache_sync() need not be
hooked as there is no performance benefit from using the
cache_bypass option.
This is primarily needed to avoid writing back to the cache
whenever we are syncing the cache with the hardware. This gives a
performance benefit especially for large register maps.
For common scenarios, device drivers can provide a table of all the
registers that are at least either readable/writable/volatile. The idea
is that if a register lookup fails, all of its read/write/vol members
will be zero and will be treated as default. This also reduces the
size of the register access array.
Simplify the use of reg_size, by calculating it once and storing it in
the codec structure for later reference. The value of reg_size is
reg_cache_size * reg_word_size.
With the addition of the cache fallback functionality, it is necessary
to ensure that if the register defaults cache was marked as __devinitconst
and the LZO compression is not compiled in the kernel, the fallback to
flat compression will still use a copy of the defaults cache.
Use Takashi's clean up code to make the cache manipulation code more
readable.
The size of the lzo syncing bitmap was incorrectly set to the size
of the cache times the word size, however, the correct size is the
size of the cache.
Make LZO cache compression optional as it pulls in the kernel wide LZO
implementation and rbtree compression is generally more efficient for
typical register maps, especially in terms of CPU performance.
This makes it easier to make cache types build time configurable as we
don't have a hard dependency on a given cache being built in.
Remove redundant parentheses/spaces in the use of the sizeof
operator.
Added an optional name member to snd_soc_cache_ops to enable more
sensible diagnostic messages during cache init, exit and sync.
Remove redundant newline in source code.
Allow the CODEC driver structure to be marked const by making all
the APIs that use it do so.
Make sure to use codec->reg_def_copy instead of codec_drv->reg_cache_default
wherever necessary. This change is necessary because in the next patch we
move the cache initialization code outside snd_soc_register_codec() and by that
time any data marked as __devinitconst such as the original reg_cache_default
array might have already been freed by the kernel.
We need to keep a copy of the compress_type supplied by the codec driver
so that we can override it if necessary with whatever the machine driver
has provided us with. The reason for not modifying the codec->driver
struct directly is that ideally we'd like to keep it const.
Adjust the code in soc-cache and soc-core to make use of the compress_type
member in the snd_soc_codec struct.
We shouldn't be assigning to the driver structure (which really ought
to be const, further patch to follow) though there's unlikely to be any
actual problem except in the unlikely case that two devices with the
same driver but different bus types appear in the same system.
The bitmap_zero() nbits argument was improperly set to reg_size
but the underlying buffer was bmp_size long. This caused the memset
to zero past the end of the allocated buffer and into the kernel heap
causing strange kernel crashes sometimes by overwriting critical
kernel structures.
