Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
With generic AC97 ASoC glue driver (codec/ac97.c), we get following warning when
the device is registered (slightly stripped the backtrace):
kobject (c5a863e8): tried to init an initialized object, something is seriously
wrong.
[<c00254fc>] (unwind_backtrace+0x0/0xec)
[<c014fad0>] (kobject_init+0x38/0x70)
[<c0171e94>] (device_initialize+0x20/0x70)
[<c017267c>] (device_register+0xc/0x18)
[<bf20db70>] (snd_soc_instantiate_cards+0x924/0xacc [snd_soc_core])
[<bf20e0d0>] (snd_soc_register_platform+0x16c/0x198 [snd_soc_core])
[<c0175304>] (platform_drv_probe+0x18/0x1c)
[<c0174454>] (driver_probe_device+0xb0/0x16c)
[<c017456c>] (__driver_attach+0x5c/0x7c)
[<c0173cec>] (bus_for_each_dev+0x48/0x78)
[<c0173600>] (bus_add_driver+0x98/0x214)
[<c0174834>] (driver_register+0xa4/0x130)
[<c001f410>] (do_one_initcall+0xd0/0x1a4)
[<c0062ddc>] (sys_init_module+0x12b0/0x1454)
This happens because the generic AC97 glue driver creates its codec->ac97 via
calling snd_ac97_mixer(). snd_ac97_mixer() provides own version of
snd_device.register which handles the device registration when
snd_card_register() is called.
To avoid registering the AC97 device twice, we add a new flag to the
snd_soc_codec: ac97_created which tells whether the AC97 device was created by
SoC subsystem.
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi>
Also clean up the error print a bit.
rtd->dev.init_name is set twice in soc_probe_dai_link. I removed the first
assignement from dai_link->stream_name since then there won't be sysfs name
changes and usually dai_link->name seems to fit anyway better for a sysfs
directory name.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Helps with diagnostics.
List registered platforms in debugfs to improve debugability of machine
drivers.
Allow the user to inspect the list of registered DAIs at runtime to
improve diagnostics for machine driver setup.
Help with diagnostics for machine driver setup by listing all the
registered CODECs in debugfs.
I think this is a typo, debugfs_pop_time should not be executable.
Acked-by: Liam Girdwood <lrg@slimloogic.co.uk>
Otherwise we generate worrying (but benign) warnings for amps.
Output size_t type as a "%Zu" to avoid warnings.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Fairly simple conflicts, the most serious ones are the i.MX ones which I
suspect now need another rename.
arch/arm/mach-mx2/clock_imx27.c
arch/arm/mach-mx2/devices.c
arch/arm/mach-omap2/board-rx51-peripherals.c
arch/arm/mach-omap2/board-zoom2.c
sound/soc/fsl/mpc5200_dma.c
sound/soc/fsl/mpc5200_dma.h
sound/soc/fsl/mpc8610_hpcd.c
sound/soc/pxa/spitz.c
Since the core now includes deduplication in the name of CODEC
devices there's no need to add extra for the debugfs directory name.
Since the debugfs directory is current per CODEC we should only init
it when the CODEC is initialised, otherwise we end up with errors
being generated when an attempt is made to add duplicate debugfs
entries.
Since most of this stuff is actually for the card we should refactor
but this can come later.
This patch extends the ASoC API to allow sound cards to have more than one
CODEC and more than one platform DMA controller. This is achieved by dividing
some current ASoC structures that contain both driver data and device data into
structures that only either contain device data or driver data. i.e.
struct snd_soc_codec ---> struct snd_soc_codec (device data)
+-> struct snd_soc_codec_driver (driver data)
struct snd_soc_platform ---> struct snd_soc_platform (device data)
+-> struct snd_soc_platform_driver (driver data)
struct snd_soc_dai ---> struct snd_soc_dai (device data)
+-> struct snd_soc_dai_driver (driver data)
struct snd_soc_device ---> deleted
This now allows ASoC to be more tightly aligned with the Linux driver model and
also means that every ASoC codec, platform and (platform) DAI is a kernel
device. ASoC component private data is now stored as device private data.
The ASoC sound card struct snd_soc_card has also been updated to store lists
of it's components rather than a pointer to a codec and platform. The PCM
runtime struct soc_pcm_runtime now has pointers to all its components.
This patch adds DAPM support for ASoC multi-component and removes struct
snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec
or runtime PCM level basis rather than using snd_soc_socdev.
Other notable multi-component changes:-
* Stream operations now de-reference less structures.
* close_delayed work() now runs on a DAI basis rather than looping all DAIs
in a card.
* PM suspend()/resume() operations can now handle N CODECs and Platforms
per sound card.
* Added soc_bind_dai_link() to bind the component devices to the sound card.
* Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove
DAI link components.
* sysfs entries can now be registered per component per card.
* snd_soc_new_pcms() functionailty rolled into dai_link_probe().
* snd_soc_register_codec() now does all the codec list and mutex init.
This patch changes the probe() and remove() of the CODEC drivers as follows:-
o Make CODEC driver a platform driver
o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core.
o Removed all static codec pointers (drivers now support > 1 codec dev)
o snd_soc_register_pcms() now done by core.
o snd_soc_register_dai() folded into snd_soc_register_codec().
CS4270 portions:
Acked-by: Timur Tabi <timur@freescale.com>
Some TLV320aic23 and Cirrus platform fixes.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
TI CODEC and OMAP fixes
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
Samsung platform and misc fixes :-
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Reviewed-by: Jassi Brar <jassi.brar@samsung.com>
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
MPC8610 and PPC fixes.
i.MX fixes and some core fixes.
J4740 platform fixes:-
CC: Tony Lindgren <tony@atomide.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
CC: Sascha Hauer <s.hauer@pengutronix.de>
CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
CC: Kuninori Morimoto <morimoto.kuninori@renesas.com>
CC: Daniel Gloeckner <dg@emlix.com>
CC: Manuel Lauss <mano@roarinelk.homelinux.net>
CC: Mike Frysinger <vapier.adi@gmail.com>
CC: Arnaud Patard <apatard@mandriva.com>
CC: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits)
ALSA: hda - Add pin-fix for HP dc5750
ALSA: als4000: Fix potentially invalid DMA mode setup
ALSA: als4000: enable burst mode
ALSA: hda - Fix initial capsrc selection in patch_alc269()
ASoC: TWL4030: Capture route runtime DAPM ordering fix
ALSA: hda - Add PC-beep whitelist for an Intel board
ALSA: hda - More relax for pending period handling
ALSA: hda - Define AC_FMT_* constants
ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs
ALSA: hda - Add support for HDMI HBR passthrough
ALSA: hda - Set Stream Type in Stream Format according to AES0
ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed
ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF
ASoC: wm9081: fix resource reclaim in wm9081_register error path
ASoC: wm8978: fix a memory leak if a wm8978_register fail
ASoC: wm8974: fix a memory leak if another WM8974 is registered
ASoC: wm8961: fix resource reclaim in wm8961_register error path
ASoC: wm8955: fix resource reclaim in wm8955_register error path
ASoC: wm8940: fix a memory leak if wm8940_register return error
ASoC: wm8904: fix resource reclaim in wm8904_register error path
When a device is powered down volatile registers can't be read so
attempts to display codec_reg will show error values, and obviously
it is also possible for there to be hardware errors too. Check for
errors from reads and display them more clearly when formatting
codec_reg.
When SX_TLV widgets are read, if the gain is set to a value below 0dB,
the mixer control is erroniously read as being at maximum volume.
The value read out of the CODEC register is never sign-extended, and
when the minimum value is subtracted (read; added, since the minimum is
negative) the result is a number greater than the maximum allowed value
for the control, and hence it saturates.
Solution: Mask the result so that it "wraps around", emulating
sign-extension.
Signed-off-by: Stuart Longland <redhatter@gentoo.org>
sound/soc/codecs/ad1938.c
This patch is adding a new control which has the following capabilities:
- tlv
- variable data size (for instance, 7 ou 8 bit)
- double mixer
- data range centered around 0
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
Acked-by: Liam Girdwood <lrg@opensource.wolfsonmicro.com>
If the register for the volume needs invert, than the inversion
need to be done from the chip maximum, and not from the platform
dependent limit.
Introduce soc_mixer_control.platform_max value, which initially
equals to chip maximum.
The snd_soc_limit_volume function only modify the platform_max,
all volsw_info call returns this as well.
The .max value holds the chip default (maximum), and it is used
for the inversion, if it is needed.
Additional check in the volsw_info call has been added to check
the validity of the platform_max in case, when custom macros
used by codec drivers are not initializing it correctly.
As well as allowing DAPM pins to be marked as ignoring suspend allow DAI
links to be similarly marked. This is primarily intended for digital
links between CODECs and non-CPU devices such as basebands in mobile
phones and will suppress all suspend calls for the DAI link. It is
likely that this will need to be revisited if used with devices which
are part of the SoC CPU.
Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Some devices can usefully run audio while the Linux system is suspended.
One of the most common examples is smartphone systems, which are normally
designed to allow audio to be run between the baseband and the CODEC
without passing through the CPU and so can suspend the CPU when on a
voice call for additional power savings.
Support such systems by providing an API snd_soc_dapm_ignore_suspend().
This can be used to mark DAPM endpoints as not being sensitive to
system suspend. When the system is being suspended paths between
endpoints which are marked as ignoring suspend will be kept active.
Both source and sink must be marked, and there must already be an
active path between the two endpoints prior to suspend.
When paths are active over suspend the bias management will hold the
device bias in the ON state. This is used to avoid suspending the
CODEC while it is still in use.
Instead of using stream events to handle power down during suspend
integrate the handling with the normal widget path checking by
replacing all cases where we report a connected endpoint in a path
with a function snd_soc_dapm_suspend_check() which looks at the ALSA
power state for the card and reports false if we are in a D3 state.
Since the core moves us into D3 prior to initating the suspend all
power checks during suspend will cause the widgets to be powered
down. In order to ensure that widgets are powered up on resume set
the card to D2 at the start of resume handling (ALSA API calls
require D0 so we are still protected against userspace access).
Add support for the core to limit the maximum volume on an
existing control.
The function will modify the soc_mixer_control.max value
of the given control.
The new value must be lower than the original one (chip maximum)
If there is a need for limiting a gain on a given control,
than machine drivers can do the following in their
snd_soc_dai_link.init function:
snd_soc_limit_volume(codec, "TPA6140A2 Headphone Playback Volume", 21);
This will modify the original 31 (chip maximum) to 21, so user
space will not be able to set the gain higher than this.
ALSA: mixart: range checking proc file
ALSA: hda - Fix a wrong array range check in patch_realtek.c
ALSA: ASoC: move dma_data from snd_soc_dai to snd_soc_pcm_stream
ALSA: hda - Enable amplifiers on Acer Inspire 6530G
ASoC: Only do WM8994 bias off transition from standby
ASoC: Don't use DCS_DATAPATH_BUSY for WM hubs devices
ASoC: Don't do runtime wm_hubs DC servo updates if using offset correction
ASoC: Support second DC servo readback method for wm_hubs
ASoC: Avoid wraparound in wm_hubs DC servo correction
ALSA: echoaudio - Eliminate use after free
ALSA: i2c: cleanup: change parameter to pointer
ALSA: hda - Add MSI blacklist for Aopen MZ915-M
ASoC: OMAP: Fix capture pointer handling for OMAP1510 to work correctly with recent ALSA PCM code
ALSA: hda - Update document about MSI and interrupts
ALSA: hda: Fix 0 dB offset for Lenovo Thinkpad models using AD1981
ALSA: hda - Add missing printk argument in previous patch
ASoC: Fix passing platform_data to ac97 bus users and fix a leak
ALSA: hda - Fix ADC/MUX assignment of ALC269 codec
ALSA: hda - Fix invalid bit values passed to snd_hda_codec_amp_stereo()
ASoC: wm8994: playback => capture
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
[The issue is an attempt to write the pdata without the AC97 device
allocated when using ac97.c - also added a comment in soc-core.c for the
special case for ac97. -- broonie]
Signed-off-by: Graham Gower <graham.gower@gmail.com>
If instantiation of a card failed, we still have to remove it from the
card list on unregistration. This fixes an Oops on Migo-R, triggering,
when after a failed firmware load attempt the driver modules are removed
and re-inserted again.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
For ASoC, if either CPU or CODEC driver has set the flag, the MACHINE driver
should be given a chance to figure out if the dai, that set the flag, can
accomodate a rate that it does not explicitly specify but is specified
by the dai at the other end of the link.
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
The codec_dai needs to be shutdown should the machine startup fails.
This patch adds another bailout tag for that case and rename the tag
for configuration failures.
The delay callback can be used by the core to query the delay
on the dai caused by FIFO or delay in the platform side.
In case if both CPU and CODEC dai has FIFO the delay reported
by each will be added to form the full delay on the chain.
If none of the dai has FIFO, than the delay will be kept as
zero.
Create a soc level wrapper for pcm_pointer callback.
This will facilitate the soc level handling of different
HW buffers in the audio path.
My editor removes the tailing spaces, which causes problems when
changing the soc-core.c
Removing the space.
If we are to have a snd_soc_dai i.e, cpu_dai and codec_dai, shared among two
or more dai_links we need to log the number of active users of the dai.
For that, we change semantics of the snd_soc_dai.active flag from indicator
to reference counter.
Check the card->codec on soc_resume to detect if the soc
device is properly initialized.
If the card->codec is NULL, than do not continue the resume
operation, since the device is not initialized properly.
In order for having snd_soc_dais shared among two or more dai_links,
remove the relatively global runtime field from the struct snd_soc_dai
Passing pointer to relevant dai_link provides easier reach to the
ASoC tree in suspend/resume of snd_soc_platform. It also provides
direct access to the dai at the other end of the dai_link.
Fixes a warning.
Provide a sysfs file allowing userspace to inspect and change the
pmdown_time setting at runtime.
Make the pmdown_time a per-card setting rather than a global one,
initialised before the card initialisation runs. This allows cards
to override the default setting if it makes sense to do so (for
example, due to an unavoidable pop).
