path: root/sound/soc/soc-dapm.c
2011-03-09Merge branch 'for-2.6.38' into for-2.6.39Mark Brown
Conflicts: sound/soc/codecs/wm8978.c sound/soc/soc-dapm.c
2011-03-09ASoC: Fix double addition of prefixes due to widget prefixingMark Brown
We're not only prefixing all controls, we're also prefixing the widget names in the runtime data. This causes us to add the prefix twice - once when using the widget name to generate the control name and once when adding the control. Really we shouldn't be prefixing the widget names at all, the matching code should be handing this as we always know which DAPM context a widget came from and always display the widget name in terms of a DAPM context. However, we're quite close to the merge window and that's relatively invasive. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reported-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-03-09ASoC: Use the correct DAPM context when cleaning up final widget setMark Brown
Now we've got multi-component we need to make sure that the DAPM context (and hence register I/O context) we use to apply the pending updates at the end of a DAPM sequence is the one we were processing rather than the one that was used to initate the state change. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-08ASoC: Fix prefixing of DAPM controls by factoring prefix into snd_soc_cnew()Mark Brown
Currently will ignore prefixes when creating DAPM controls. Since currently all control creation goes through snd_soc_cnew() we can fix this by factoring the prefixing into that function. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-03-03ASoC: Check for a CODEC before dereferencing in DAPMMark Brown
A CODEC pointer is optional (and is checked for in most contexts within DAPM) - add checks to the few places where it was missed. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-03ASoC: Get the card directly from the DAPM contextMark Brown
Rather than indirecting through the CODEC we can look the card up directly from the card pointer in the DAPM context. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-25ASoC: soc-dapm: Include quotes around contents in debugfs entriesDimitris Papastamos
Sometimes the name of the control switch of a dapm route contains spaces which makes it impossible to distinguish it from the source widget. Add quotes around the names of the widgets to makes these parsable. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-02-22ASoC: Run bias level changes for all DAPM contexts in parallelMark Brown
As bias level changes can be quite time consuming and the bias changes for multiple devices aren't strongly tied to each other (if anything it can be advantageous to bring different devices up together) we can improve the state transition time for multi-component systems by running the bias level changes for all the devices in parallel. This is very simple to achieve using the kernel async functionality so use that to schedule the work. This should have no practical effect for the overwhelming majority of systems which have a single DAPM context - we'll bounce into another thread to do the bias level change but otherwise everything will happen in exactly the same order as it did before. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-22ASoC: Remove card from snd_soc_dapm_set_bias_level()Mark Brown
We can get the card from the DAPM context so don't bother passing it as an argument. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-18ASoC: Remove export of snd_soc_dapm_stream_event()Mark Brown
The only thing that should ever be calling this is soc-core and that is built as part of the same module so doesn't need the export. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-13Merge branch 'for-2.6.38' into for-2.6.39Mark Brown
2011-02-13ASoC: Ensure supplies are maintained for force enabled widgetsMark Brown
If a widget has been force enabled then not only do we need to keep the widget itself enabled, we also need to keep any supplies the widget requires enabled. The user could force all the individual widgets on but this requires too much knowledge of device internals. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-09Merge branch 'for-2.6.38' into for-2.6.39Mark Brown
2011-02-09ASoC: Sync initial widget state with hardwareMark Brown
ASoC generally uses the register defaults for everything, but in some cases the hardware will default to enabling some of the DAPM widgets (clocks for example). Ensure that DAPM knows about the actual widget state at initialisation by reading the enable bits after instantiating the widgets so they don't get left enabled needlessly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-28Merge branch 'for-2.6.38' into for-2.6.39Mark Brown
2011-01-28ASoC: Fix mask/val_mask confusion snd_soc_dapm_put_volsw()Stephen Warren
snd_soc_dapm_put_volsw() has variables for both the unshifted and shifted mask for updates commit 97404f (ASoC: Do DAPM control updates in the middle of DAPM sequences) got confused between the two of these. Since there's no need to keep a copy of the unshifted mask fix this and simplify the code by using only one mask variable. [Completely rewrote the changelog to describe the issue -- broonie.] Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-01-27ASoC: Add subsequence information to seq_notify callbacksMark Brown
Allows drivers to distinguish which subsequence is being notified when they get called back. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-19ASoC: Provide per widget type callback when executing DAPM sequencesMark Brown
Many modern devices have features such as DC servos which take time to start. Currently these are handled by per-widget events but this makes it difficult to paralleise operations on multiple widgets, meaning delays can end up being needlessly serialised. By providing a callback to drivers when all widgets of a given type have been handled during a DAPM sequence the core allows drivers to start operations separately and wait for them to complete much more simply. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-19ASoC: Add support for sequencing withinMark Brown
With larger devices there may be many widgets of the same type in series in an audio path. Allow drivers to specify an additional level of ordering within each widget type by adding a subsequence number to widgets and then splitting operations on widgets so that widgets of the same type but different sequence numbers are processed separately. A typical example would be a supply widget which requires that another widget be enabled to provide power or clocking. SND_SOC_DAPM_PGA_S() and SND_SOC_DAPM_SUPPLY_S() macros are provided allowing this to be used with PGAs and supplies as these are the most commonly affected widgets. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-19ASoC: Explicitly say if we're powering up or downMark Brown
Rather than passing the sequence to use for DAPM widgets around by reference explicitly say if we're powering up or down until the point where we need the sequence itself. This should make no practical difference in itself but supports future refactoring. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-22ASoC: don't pass the string as the format arguemtn for dev_info()Takashi Iwai
2010-12-17ASoC: soc-dapm: Introduce the new snd_soc_dapm_virt_mux typeDimitris Papastamos
This new type is a virtual version of snd_soc_dapm_mux. It is used when a backing register value is not necessary for deciding which input path to connect. A simple virtual enumeration control e.g. SOC_DAPM_ENUM_VIRT() can be exposed to userspace which will be used to choose which path to connect. The snd_soc_dapm_virt_mux type ensures that during the initial path setup, the first (which is also the default) input path will be connected. Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-17ASoC: Do DAPM control updates in the middle of DAPM sequencesMark Brown
Attempt to minimise audible effects from mixer and mux updates by implementing the actual register changes between powering down widgets that have become unused and powering up widgets that are newly used. This means that we're making the change with the minimum set of widgets powered, that the input path is connected when we're powering up widgets (so things like DC offset correction can run with their signal active) and that we bring things down to cold before switching away. Since hardware tends to be designed for the power on/off case more than for dynamic reconfiguration this should minimise pops and clicks during reconfiguration while active. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-12-15ASoC: Extend DAPM to handle power changes on cross-device pathsJarkko Nikula
Power change event like stream start/stop or kcontrol change in a cross-device path originates from one device but codec bias and widget power changes must be populated to another devices on that path as well. This patch modifies the dapm_power_widgets so that all the widgets on a sound card are checked for a power change, not just those that are specific to originating device. Also bias management is extended to check all the devices. Only exception in bias management are widgetless codecs whose bias state is changed only if power change is originating from that context. DAPM context test is added to dapm_seq_run to take care of if power sequence extends to an another device which requires separate register writes. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-15ASoC: Move widgets from DAPM context to snd_soc_cardJarkko Nikula
Decoupling widgets from DAPM context is required when extending the ASoC core to cross-device paths. Even the list of widgets are now kept in struct snd_soc_card, the widget listing in sysfs and debugs remain sorted per device. This patch makes possible to build cross-device paths but does not extend yet the DAPM to handle codec bias and widget power changes of an another device. Cross-device paths are registered by listing the widgets from device A in a map for device B. In case of conflicting widget names between the devices, a uniform name prefix is needed to separate them. See commit ead9b91 "ASoC: Add optional name_prefix for kcontrol, widget and route names" for help. An example below shows a path that connects MONO out of A into Line In of B: static const struct snd_soc_dapm_route mapA[] = { {"MONO", NULL, "DAC"}, }; static const struct snd_soc_dapm_route mapB[] = { {"Line In", NULL, "MONO"}, }; Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-15ASoC: Move DAPM paths from DAPM context to snd_soc_cardJarkko Nikula
Decoupling DAPM paths from DAPM context is a first prerequisite when extending ASoC core to cross-device paths. This patch is almost a nullop and does not allow to construct cross-device setup but the path clean-up part in dapm_free_widgets is prepared to remove cross-device paths between a device being removed and others. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-14ASoC: dapm: Add output driver widgetOlaya, Margarita
In some cases it was not possible to follow the appropiate power ON/OFF sequence like in cases where the PGA needs to be enabled before the driver and disabled before the PGA for pop reduction. Add a widget to support output driver (speaker, haptic, vibra, etc) drivers where power ON/OFF ordering is important. Signed-off-by: Margarita Olaya Cabrera <magi.olaya@ti.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-13ASoC: Fix build error caused by merging a fix for 2.6.37 into 2.6.38Jarkko Nikula
Fix "ASoC: Fix bias power down of non-DAPM codec" for 3.6.37 will cause a build error when merging into ASoC for-2.6.38. Fix the issue by doing a change that commit ce6120c "ASoC: Decouple DAPM from CODECs" would do. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-13Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-12-13ASoC: Fix bias power down of non-DAPM codecJarkko Nikula
Currently bias of non-DAPM codec will be powered down (standby/off) whenever there is a stream stop. This is wrong in simultaneous playback/capture since the bias is put down immediately after stopping the first stream. Fix this by using the codec->active count when figuring out the needed bias level after stream stop. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-12-06ASoC: Add post-CODEC bias level callback for machine driverMark Brown
Currently the machine driver can only do bias level configuration before the CODEC bias level is brought up. This means that the machine cannot do any configuration which depends on the CODEC bias level being maintained. Provide a post-CODEC callback which allows the machine driver to do things like enable the FLL on a CODEC which is brought down to BIAS_OFF when idle. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-22ASoC: Do not include soc-dapm.hJarkko Nikula
There is no need to include soc-dapm.h since soc.h includes it. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-16ASoC: Use DAPM context rather than CODEC when constructing sequencesMark Brown
DAPM widgets may be associated with non-CODEC devices so compare based on the DAPM context rather than the CODEC pointer. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-15ASoC: Add optional name_prefix for codec kcontrol, widget and route namesJarkko Nikula
There is a need to prefix codec kcontrol, widget and internal route names in an ASoC machine that has multiple codecs with conflicting names. The name collision would occur when codec drivers try to registering kcontrols with the same name or when building audio paths. This patch introduces optional prefix_map into struct snd_soc_card. With it machine drivers can specify a unique name prefix to each codec that have conflicting names with anothers. Prefix to codec is matched with codec name. Following example illustrates a machine that has two same codec instances. Name collision from kcontrol registration is avoided by specifying a name prefix "foo" for the second codec. As the codec widget names are prefixed then second audio map for that codec shows a prefixed widget name. static const struct snd_soc_dapm_route map0[] = { {"Spk", NULL, "MONO"}, }; static const struct snd_soc_dapm_route map1[] = { {"Vibra", NULL, "foo MONO"}, }; static struct snd_soc_prefix_map codec_prefix[] = { { .dev_name = "codec.2", .name_prefix = "foo", }, }; static struct snd_soc_card card = { ... .prefix_map = codec_prefix, .num_prefixes = ARRAY_SIZE(codec_prefix), }; Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-15Merge branch 'for-2.6.37' into for-2.6.38Mark Brown
2010-11-15ASoC: Fix dapm_seq_compare() for multi-componentMark Brown
Ensure that we keep all widget powerups in DAPM sequence by making the CODEC the last thing we compare on rather than the first thing. Also fix the fact that we're currently comparing the widget pointers rather than the CODEC pointers when we do the substraction so we won't get stable results. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-11ASoC: Add DAPM trace eventsMark Brown
Trace events for DAPM allow us to monitor the performance and behaviour of DAPM with logging which can be built into the kernel permanantly, is more suited to automated analysis and display and less likely to suffer interference from other logging activity. Currently trace events are generated for: - Start and stop of DAPM processing - Start and stop of bias level changes - Power decisions for widgets - Widget event execution start and stop giving some view as to what is happening and where latencies occur. Actual changes in widget power can be seen via the register write trace in soc-core. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-11ASoC: Factor out boiler plate for DAPM event generationMark Brown
Make the DAPM sequence execution look a bit nicer by factoring out the code to invoke an event into a single function since it's all the same pretty much. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-11-10ASoC: Convert pop_dbg to use dev_infoJarkko Nikula
Prints from pop_dbg are enabled when dapm_pop_time != 0. Convert it to use dev_info so that parent device of DAPM context is printed. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-10ASoC: Update DAPM debug and error printsJarkko Nikula
Switch printk and pr_ prints to dev_ variants. It is helpful to see parent device of DAPM context especially when there are multiple DAPM contexts (codecs currently). This is mostly simple conversion. Exceptions are in snd_soc_dapm_set_pin that prints also pin state, uniform "dapm: unknown pin" error prints from snd_soc_dapm_set_pin, snd_soc_dapm_force_enable_pin and snd_soc_dapm_ignore_suspend, and pop_dbg which is converted by an another patch. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Move pop time from DAPM context to sound cardJarkko Nikula
Based on discussion the dapm_pop_time in debugsfs should be per card rather than per device. Single pop time value for entire card is cleaner when the DAPM sequencing is extended to cross-device paths. debugfs/asoc/{card->name}/{codec dir}/dapm_pop_time -> debugfs/asoc/{card->name}/dapm_pop_time Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-11-06ASoC: Decouple DAPM from CODECsLiam Girdwood
Decoupling Dynamic Audio Power Management (DAPM) from codec devices is required when developing ASoC further. Such as for other ASoC components to have DAPM widgets or when extending DAPM to handle cross-device paths. This patch decouples DAPM related variables from struct snd_soc_codec and moves them to new struct snd_soc_dapm_context that is used to encapsulate DAPM context of a device. ASoC core and API of DAPM functions are modified to use DAPM context instead of codec. This patch does not change current functionality and a large part of changes come because of structure and internal API changes. Core implementation is from Liam Girdwood <lrg@slimlogic.co.uk> with some minor core changes, codecs and machine driver conversions from Jarkko Nikula <jhnikula@gmail.com>. Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Manuel Lauss <manuel.lauss@googlemail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Cliff Cai <cliff.cai@analog.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Timur Tabi <timur@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Arnaud Patard (Rtp) <arnaud.patard@rtp-net.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Jassi Brar <jassi.brar@samsung.com> Cc: Daniel Gloeckner <dg@emlix.com> Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-05-10ASoC: Support leaving paths enabled over system suspendMark Brown
Some devices can usefully run audio while the Linux system is suspended. One of the most common examples is smartphone systems, which are normally designed to allow audio to be run between the baseband and the CODEC without passing through the CPU and so can suspend the CPU when on a voice call for additional power savings. Support such systems by providing an API snd_soc_dapm_ignore_suspend(). This can be used to mark DAPM endpoints as not being sensitive to system suspend. When the system is being suspended paths between endpoints which are marked as ignoring suspend will be kept active. Both source and sink must be marked, and there must already be an active path between the two endpoints prior to suspend. When paths are active over suspend the bias management will hold the device bias in the ON state. This is used to avoid suspending the CODEC while it is still in use. Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-10ASoC: Refactor DAPM suspend handlingMark Brown
Instead of using stream events to handle power down during suspend integrate the handling with the normal widget path checking by replacing all cases where we report a connected endpoint in a path with a function snd_soc_dapm_suspend_check() which looks at the ALSA power state for the card and reports false if we are in a D3 state. Since the core moves us into D3 prior to initating the suspend all power checks during suspend will cause the widgets to be powered down. In order to ensure that widgets are powered up on resume set the card to D2 at the start of resume handling (ALSA API calls require D0 so we are still protected against userspace access). Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-10ASoC: Remove unused DAPM suspend flagMark Brown
We now manage suspend within the main power analysis rather than by flipping the state of widgets. Tested-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
