path: root/sound/soc/soc-io.c
2014-08-19ASoC: Automatically initialize regmap for all componentsLars-Peter Clausen
So far regmap is only automatically initialized for CODECs. Now that we have the infrastructure in place to let components have DAPM widgets and controls that want to use the generic regmap based IO also make sure to automatically initialize regmap for all components. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-22ASoC: Remove ASoC level IO tracingLars-Peter Clausen
The ASoC framework is in the process of migrating all IO operations to regmap. regmap has its own more sophisticated tracing infrastructure for IO operations, which means that the ASoC level IO tracing becomes redundant, hence this patch removes them. There are still a handful of ASoC drivers left that do not use regmap yet, but hopefully the removal of the ASoC IO tracing will be an additional incentive to switch to regmap. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-22ASoC: Remove snd_soc_update_bits_locked()Lars-Peter Clausen
There are no users of snd_soc_update_bits_locked() left and it is identical to snd_soc_update_bits(). So it can be removed. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-22ASoC: Move IO abstraction to the component levelLars-Peter Clausen
We currently have two very similar IO abstractions in ASoC, one for CODECs, the other for platforms. Moving this to the component level will allow us to unify those two. It will also enable us to move the standard kcontrol helpers as well as DAPM support to the component level. The new component level abstraction layer is primarily build around regmap. There is a per component pointer for the regmap instance for the underlying device. There are four new function snd_soc_component_read(), snd_soc_component_write(), snd_soc_component_update_bits() and snd_soc_component_update_bits_async(). They have the same signature as their regmap counter-part and will internally forward the call one-to-one to regmap. If the component it not using regmap it will fallback to using the custom IO callbacks. This is done to be able to support drivers that haven't been converted to regmap yet, but it is expected that this will eventually be removed in the future once all component drivers have been converted to regmap. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-22Merge branches 'topic/sta350', 'topic/core', 'topic/dapm' and 'topic/cache' ↵Mark Brown
of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into asoc-component
2014-04-21ASoC: Change return type of snd_soc_write() to intLars-Peter Clausen
The CODEC's write callback can return a negative error code, make sure to pass that on correctly. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-14Merge branch 'topic/component' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into asoc-core Conflicts: sound/soc/soc-core.c
2014-04-14ASoC: Move IO functions to soc-io.cLars-Peter Clausen
soc-core.c is getting quite crowded. Move all IO related functions that are still in soc-core.c to soc-io.c Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-14ASoC: core: Move the default regmap I/O setting to snd_soc_register_codec()Xiubo Li
Add the default regmap I/O setting to snd_soc_register_codec() while the CODEC is initialising, which will be called by CODEC driver device probe(), and then we can make XXX_set_cache_io() go away entirely from each CODEC ASoC probe. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-19ASoC: io: Remove support for ASoC cache in conjunction with regmapMark Brown
Since all regmap CODECs should be (and are) using the more advance regmap cache infrastructure remove the code which supports that and just proxy I/O straight through to regmap. Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-11ASoC: io: New signature for snd_soc_codec_set_cache_io()Xiubo Li
Now that all users have been converted to regmap and the config.reg_bits and config.val_bits can be setted by each user through regmap core API. So these two params are redundant here. Since the only control type that left is SND_SOC_REGMAP, so remove it. Drop the control params and add struct regmap *regmap to simplify the code. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-28ASoC: io: Clean up snd_soc_codec_set_cache_io()Xiubo Li
Now that all users have been converted to regmap and the config.reg_bits and config.val_bits can be setted by each user through regmap core API. So these two params are redundant here. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-23ASoC: io: Remove SND_SOC_I2CMark Brown
Now that all users have been converted to regmap we can eliminate the ASoC level wrapper for I2C I/O reducing the amount of duplicated functionality. Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-16ASoC: io: Remove SPI supportMark Brown
All ASoC CODEC drivers that use SPI have now been converted to use regmap so we can delete SND_SOC_SPI, preventing any new users being added. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-27ASoC: soc-io: Use IS_ENABLED() macroFabio Estevam
Using the IS_ENABLED() macro can make the code shorter and simpler. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17ASoC: Remove snd_soc_bulk_write_raw()Lars-Peter Clausen
No users of snd_soc_bulk_write_raw() are left and new drivers are going to use regmap directly for this, so the function can be removed. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15PTR_RET is now PTR_ERR_OR_ZERO(): Replace most.Rusty Russell
Sweep of the simple cases. Cc: netdev@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-arm-kernel@lists.infradead.org Cc: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-03-26ASoC: core: Use PTR_RET functionAlexandru Gheorghiu
Used PTR_RET function instead of IS_ERR and PTR_ERR. Patch found using coccinelle. Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-23ASoC: io: Don't dereference regmap if we failed to get oneMark Brown
Avoids a crash in invalid configurations. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2012-06-03ASoC: io: Use dev_get_regmap() if driver doesn't provide a regmapMark Brown
Less error prone and one less line of code in drivers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2012-02-21ASoC: io: Retrieve val_bytes from the regmap APIMark Brown
Allow us to build infrastructure which needs to know the size of a value without requiring regmap based drivers to supply this information to both ASoC and regmap by asking regmap for the value. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2012-01-21ASoC: Use regmap update bits operation for drivers using regmapMark Brown
If a driver is using regmap directly ensure that we're coherent with non-ASoC register updates by using the regmap API directly to do our read/modify/write cycles. This will bypass the ASoC cache but drivers using regmap directly should not be using the ASoC cache. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-31sound: Add export.h for THIS_MODULE/EXPORT_SYMBOL where neededPaul Gortmaker
These aren't modules, but they do make use of these macros, so they will need export.h to get that definition. Previously, they got it via the implicit module.h inclusion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-09ASoC: Squash error codes from regmap down to -1 on readMark Brown
The ASoC code always uses -1 as the error code due to reporting errors in band with the value. Ensure we don't confuse anything by making sure we don't pass actual error codes back into the rest of the code on read. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-14ASoC: Support !CONFIG_REGMAP buildsMark Brown
Since we changed regmap to be selected and register per bus rather than via the core only we can't rely on it being enabled by the ASoC core. Support compiling it out. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reported-by: Axel Lin <axel.lin@gmail.com>
2011-08-12ASoC: soc-io: Fix CONFIG_REGMAP_I2C/SPI guards to support regmap modulesStephen Warren
When CONFIG_REGMAP_I2C/SPI are m, CONFIG_REGMAP_I2C_MODULE is set in the pre-processor instead of CONFIG_REGMAP_I2C. This removes SND_SOC_I2C as a valid option for snd_soc_codec_set_cache_io()'s control parameter, and causes any ASoC regmap-using codec built as a module to fail to initialize. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-11ASoC: soc-io: Add CONFIG_REGMAP_I2C/CONFIG_REGMAP_SPI guards for ↵Axel Lin
regmap_init_i2c/regmap_init_spi In the case of "make da8xx_omapl_defconfig;make", the SPI support is disabled. Thus calling regmap_init_spi in soc-io.c has below build error. ERROR: "regmap_init_spi" [sound/soc/snd-soc-core.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 This patch fixes the build error by adding CONFIG_REGMAP_I2C/CONFIG_REGMAP_SPI guards for regmap_init_i2c/regmap_init_spi. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-08-08ASoC: Add regmap as a control typeMark Brown
Allow drivers to set up their own regmap API structures. This is mainly useful with MFDs where the core driver will have set up regmap at the minute, though it may make sense to push the existing regmap setup out of the core into the drivers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-08-08ASoC: Use new register map API for ASoC generic physical I/OMark Brown
Remove all the ASoC specific physical I/O code and replace it with calls into the regmap API. The bulk write code can only be used safely if all regmap calls are locked with the CODEC lock, we need to add bulk support to the regmap API or replace the code with an open coded loop (though currently it has no users...). Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-06-13Merge branch 'for-3.0' into for-3.1Mark Brown
Trival fixup for move of I/O code into separate file. Conflicts: sound/soc/soc-cache.c
2011-06-13ASoC: Don't use codec->control_data in bulk writeMark Brown
In order to facilitate merging with the register map I/O replace the use of control_data for the bulk writes with direct lookup of the client data from the device. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
2011-06-13ASoC: Move register I/O code into a separate fileMark Brown
For clarity and to help ongoing refactoring in this area create a new file to contain the physical I/O functions, separating them out from the cache operations. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@ti.com>
