commit feb00b736af64875560f371fe7f58b0b7f239046 upstream.
There is no reason to force readwrite access on TLV controls. It can be
either read, write or both. This is further evidenced in code where it
performs following checks:
if ((k->access & SNDRV_CTL_ELEM_ACCESS_TLV_READ) && !sbe->get)
return -EINVAL;
if ((k->access & SNDRV_CTL_ELEM_ACCESS_TLV_WRITE) && !sbe->put)
return -EINVAL;
Fixes: 1a3232d2f61d ("ASoC: topology: Add support for TLV bytes controls")
Signed-off-by: Amadeusz Sławiński <amadeuszx.slawinski@linux.intel.com>
Reviewed-by: Cezary Rojewski <cezary.rojewski@intel.com>
Reviewed-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Link: https://lore.kernel.org/r/20220112170030.569712-3-amadeuszx.slawinski@linux.intel.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 7e567b5ae06315ef2d70666b149962e2bb4b97af ]
snd_ctl_remove() has to be called with card->controls_rwsem held (when
called after the card instantiation). This patch add the missing
rwsem calls around it.
Fixes: 8a9782346dcc ("ASoC: topology: Add topology core")
Link: https://lore.kernel.org/r/20211116071812.18109-1-tiwai@suse.de
commit 543466ef3571069b8eb13a8ff7c7cfc8d8a75c43 upstream.
The allocation uses sizeof(u32) when it should use sizeof(unsigned long)
so it leads to memory corruption later in the function when the data is
initialized.
Fixes: 5aebe7c7f9c2 ("ASoC: topology: fix endianness issues")
Link: https://lore.kernel.org/r/YAf+8QZoOv+ct526@mwanda
commit 8edac489e7c3fce44208373bb3e7b5835a672c66 upstream.
we need to free all allocated tlvs, not just the one allocated in
the loop before releasing kcontrols - other the tlvs references will
leak.
Fixes: 9f90af3a995298 ('ASoC: topology: Consolidate and fix asoc_tplg_dapm_widget_*_create flow')
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Reviewed-by: Ranjani Sridharan <ranjani.sridharan@linux.intel.com>
Reviewed-by: Kai Vehmanen <kai.vehmanen@linux.intel.com>
Link: https://lore.kernel.org/r/20200707203749.113883-3-pierre-louis.bossart@linux.intel.com
commit 6f0307df83f2aa6bdf656c2219c89ce96502d20e upstream.
When errors happens while loading graph components, the kernel oopses
while trying to remove all topology components. This can be
root-caused to a list pointing to memory that was already freed on
error.
remove_route() is already called on errors and will perform the
required cleanups so there's no need to free the route memory in
soc_tplg_dapm_graph_elems_load() if the route was added to the
list. We do however want to free the routes allocated but not added to
the list.
Fixes: 7df04ea7a31ea ('ASoC: topology: modify dapm route loading routine and add dapm route unloading')
Link: https://lore.kernel.org/r/20200707203749.113883-2-pierre-louis.bossart@linux.intel.com
[ Upstream commit 26d87881590fd55ccdd8f829498d7b3033f81990 ]
As done in already existing cases, we should use le32_to_cpu macro while
accessing hdr->magic. Found with sparse.
Link: https://lore.kernel.org/r/20200415162435.31859-2-amadeuszx.slawinski@linux.intel.com
[ Upstream commit dd8e871d4e560eeb8d22af82dde91457ad835a63 ]
Function soc_tplg_dai_config can fail, check for and handle possible
failure.
Link: https://lore.kernel.org/r/20200327204729.397-7-amadeuszx.slawinski@linux.intel.com
[ Upstream commit b3677fc3d68dd942c92de52f0bd9dd8b472a40e6 ]
Function pcm_new_ver can fail, so we should check it's return value and
handle possible error.
Link: https://lore.kernel.org/r/20200327204729.397-6-amadeuszx.slawinski@linux.intel.com
[ Upstream commit 6856e887eae3efc0fe56899cb3f969fe063171c5 ]
Function soc_tplg_add_route can propagate error code from callback, we
should check its return value and handle fail in correct way.
Link: https://lore.kernel.org/r/20200327204729.397-5-amadeuszx.slawinski@linux.intel.com
[ Upstream commit 2ae548f30d7f6973388fc3769bb3c2f6fd13652b ]
Functions soc_tplg_denum_create, soc_tplg_dmixer_create,
soc_tplg_dbytes_create can fail, so their return values should be
checked and error should be propagated.
Link: https://lore.kernel.org/r/20200327204729.397-4-amadeuszx.slawinski@linux.intel.com
[ Upstream commit 482db55ae87f3749db05810a38b1d618dfd4407c ]
Function soc_tplg_create_tlv can fail, so we should check if it succeded
or not and proceed appropriately.
Link: https://lore.kernel.org/r/20200327204729.397-3-amadeuszx.slawinski@linux.intel.com
commit abca9e4a04fbe9c6df4d48ca7517e1611812af25 upstream.
Current topology doesn't add prefix of component to new kcontrol.
Signed-off-by: Gyeongtaek Lee <gt82.lee@samsung.com>
Link: https://lore.kernel.org/r/009b01d60804$ae25c2d0$0a714870$@samsung.com
commit 242c46c023610dbc0213fc8fb6b71eb836bc5d95 upstream.
In case of ABI version mismatch, _manifest needs to be freed as
it is just a copy of the original topology manifest. However, if
a driver manifest handler is defined, that would get executed and
the cleanup is never reached. Fix that by getting the return status
of manifest() instead of returning directly.
Fixes: 583958fa2e52 ("ASoC: topology: Make manifest backward compatible from ABI v4")
Signed-off-by: Dragos Tarcatu <dragos_tarcatu@mentor.com>
Link: https://lore.kernel.org/r/20200207185325.22320-3-dragos_tarcatu@mentor.com
commit 2b2d5c4db732c027a14987cfccf767dac1b45170 upstream.
If soc_tplg_link_config() fails, _link needs to be freed in case of
topology ABI version mismatch. However the current code is returning
directly and ends up leaking memory in this case.
This patch fixes that.
Fixes: 593d9e52f9bb ("ASoC: topology: Add support to configure existing physical DAI links")
Link: https://lore.kernel.org/r/20200207185325.22320-2-dragos_tarcatu@mentor.com
[ Upstream commit 72bbeda0222bcd382ee33b3aff71346074410c21 ]
Sparse complains about a series of easy warnings, fix.
Link: https://lore.kernel.org/r/20200102195952.9465-3-pierre-louis.bossart@linux.intel.com
[ Upstream commit 8ce1cbd6ce0b1bda0c980c64fee4c1e1378355f1 ]
The code which checks the return value for snd_soc_add_dai_link() call
in soc_tplg_fe_link_create() moved the snd_soc_add_dai_link() call before
link->dobj members initialization.
While it does not affect the latest kernels, the old soc-core.c code
in the stable kernels is affected. The snd_soc_add_dai_link() function uses
the link->dobj.type member to check, if the link structure is valid.
Reorder the link->dobj initialization to make things work again.
It's harmless for the recent code (and the structure should be properly
initialized before other calls anyway).
The problem is in stable linux-5.4.y since version 5.4.11 when the
upstream commit 76d270364932 was applied.
Fixes: 76d270364932 ("ASoC: topology: Check return value for snd_soc_add_dai_link()")
Cc: Dragos Tarcatu <dragos_tarcatu@mentor.com>
Cc: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Cc: Ranjani Sridharan <ranjani.sridharan@linux.intel.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: <stable@vger.kernel.org>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Link: https://lore.kernel.org/r/20200122190752.3081016-1-perex@perex.cz
[ Upstream commit dd836ddf4e4e1c7f1eb2ae44783ccd70872ef24e ]
remove_link() is currently calling snd_soc_remove_dai_link() after
it has already freed the memory for the link name. But this is later
read from snd_soc_get_pcm_runtime() causing a KASAN use-after-free
warning. Reorder the cleanups to fix this issue.
Reviewed-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Link: https://lore.kernel.org/r/20191204210447.11701-4-pierre-louis.bossart@linux.intel.com
[ Upstream commit a3039aef52d9ffeb67e9211899cd3e8a2953a01f ]
The return value of soc_tplg_pcm_create() is currently not checked
in soc_tplg_pcm_elems_load(). If an error is to occur there, the
topology ignores it and continues loading.
Fix that by checking the status and rejecting the topology on error.
Link: https://lore.kernel.org/r/20191210003939.15752-3-pierre-louis.bossart@linux.intel.com
[ Upstream commit 76d2703649321c296df7ec0dafd50add96215de4 ]
snd_soc_add_dai_link() might fail. This situation occurs for
instance in a very specific use case where a PCM device and a
Back End DAI link are given identical names in the topology.
When this happens, soc_new_pcm_runtime() fails and then
snd_soc_add_dai_link() returns -ENOMEM when called from
soc_tplg_fe_link_create(). Because of that, the link will not
get added into the card list, so any attempt to remove it later
ends up in a panic.
Fix that by checking the return status and free the memory in case
of an error.
Link: https://lore.kernel.org/r/20191210003939.15752-2-pierre-louis.bossart@linux.intel.com
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v5.4
A collection of fixes that have arrived since the merge window. There
are a small number of core fixes here but they are smaller ones around
error handling.
The "template.id" variable is an enum and in this context GCC will
treat it as an unsigned int so it can never be less than zero.
Link: https://lore.kernel.org/r/20190925110624.GR3264@mwanda
We use snd_soc_dapm_new_control_unlocked for topology and have local
declaration, instead declare it properly in header like already declared
snd_soc_dapm_new_control.
Signed-off-by: Amadeusz Sławiński <amadeuszx.slawinski@intel.com>
Link: https://lore.kernel.org/r/20190827141712.21015-4-amadeuszx.slawinski@linux.intel.com
commit 52abe6cc1866a ("ASoC: topology: fix oops/use-after-free case
with dai driver") fixups remove_dai() error, but it is using
list_for_each_entry() for component->dai_list.
We already have for_each_component_dais() macro for it.
Let's use exising method.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Link: https://lore.kernel.org/r/87tvaczazd.wl-kuninori.morimoto.gx@renesas.com
Currently when a kstrdup fails the error exit paths don't free
the allocations for sm, se and sbe. This can be fixed by assigning
kc[i].private_value to these before doing the ksrtdup so that the error
exit path will be able to free these objects.
Addresses-Coverity: ("Resource leak")
Fixes: 9f90af3a9952 ("ASoC: topology: Consolidate and fix asoc_tplg_dapm_widget_*_create flow")
There are a few soc_tplg_dapm_widget_*_create functions with similar
content, but slightly different flow, unify their flow and make sure
that we go to error handler and free memory in case of failure.
Acked-by: Ranjani Sridharan <ranjani.sridharan@linux.intel.com>
Provide helper functions and use them to free dtexts and dvalues in
topology. This is followup cleanup after related changes in this area as
suggested in:
https://mailman.alsa-project.org/pipermail/alsa-devel/2019-January/144761.html
The topology code can create a FE DAI link but did not allocate the
memory for a platform component - whose name can be overridden at a
later time.
Fixes: 23b946ce2808b ("ASoC: soc-topology: use modern dai_link style")
ASoC is now supporting modern style dai_link
(= snd_soc_dai_link_component) for CPU/Codec/Platform.
This patch switches to use it.
The control values and texts of the enum kcontrol associated
with a widget need to be freed when the widget is removed.
However, both struct snd_soc_dapm_widget and struct soc_enum
contain a dobj member, which resulted in a confusion.
The existing code generates a null pointer dereference by
attempting to free the values and texts from the dobj which
belongs to the widget instead of the dobj belonging to the
enum kcontrol.
The suggested fix is to use the correct dobj member (se->dobj)
of the enum kcontrol.
Signed-off-by: Ranjani Sridharan <ranjani.sridharan@linux.intel.com>
Use an explicit define to avoid Sparse issues coming from the use of
cpu_to_be32
Use le16/32/64_to_cpu() as needed to make Sparse happy.
This aligns all kcontrol tplg pointer increments to be consistent
in the respective create methods and ensures that the position is
pointing to the next widget rather the current invalid widget.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Some strings are allocated by kstrdup, but not freed when error
happened.
Signed-off-by: Bard liao <yung-chuan.liao@linux.intel.com>
Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
The stream_name is allocated by kstrdup. We have to free it when the
dai is removed or return from error.
Component driver may want to use tlv data. Create tlv before
soc_tplg_init_kcontrol so component driver can use the tlv data
in the control_load ops.
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into asoc-5.1 for refcount fix
Topology resources are no longer needed if any element failed to load.
soc_tplg_link_config() will find the physical dai link and call
soc_tplg_dai_link_load() to load the BE dai link. Currently remove_link()
is only used to remove the FE dai link which is created by the topology.
The BE dai link cannot however be unloaded in snd_soc_tplg_component
_remove(), which is problematic if anything needs to be released or
reinitialized.
This patch aligns the definitions of dynamic types with the existing
UAPI and adds a new remove_backend_link() routine to unload the the BE
dai link when snd_soc_tplg_component_remove() is invoked.
rmmod/modprobe tests expose a kernel oops when accessing the dai
driver pointer. This comes from the topology design which operates in
multiple passes. Each object removal happens at a specific iteration,
and the code checks for the iteration (order) number after the memory
containing the order was freed.
Fix this be clearing a reference to the dai driver and check its
validity to avoid dereferences.
Signed-off-by: Guennadi Liakhovetski <guennadi.liakhovetski@intel.com>
struct snd_soc_dapm_route has been modified to be a dynamic
object so that it can be used to save driver specific
data while parsing topology and clean up
driver-specific data during driver unloading.
This patch makes the following changes to accomplish the above:
1. Set the dobj member of snd_soc_dapm_route during the
SOC_TPLG_PASS_GRAPH pass of topology parsing.
2. Add the remove_route() routine that will be called while
removing all dynamic objects from the component driver.
template.sname and template.name are only freed when an error occur.
They should be freed in the success return case, too.
dtexts is two dimensional array, so we also need to free it after
freeing its fields.
Currently when we unload and reload machine driver few times we end with
corrupted list and try to cleanup no longer existing objects. Fix this
by removing dobj from the list.
We already have passed dobj, there is no reason to access it through
containing structs.
As a preparatory patch for the upcoming -Wimplicit-fallthrough
compiler checks, replace with the standard "fall through" annotation.
gcc can't understand the mixed texts, unfortunately.
Currently DAPM has a lot of similar code to handle errors from
snd_soc_dapm_new_control_unlocked, and much of this code does
not really accurately reflect what the function returns.
Firstly, most places will check for a return value of
-EPROBE_DEFER and silence any error messages in that case. The
one notable exception here being dapm_kcontrol_data_alloc
which does currently print any error messages in the case
of snd_soc_dapm_new_control_unlocked returning NULL or an
error. Additionally the error prints being silenced in these
case are redundant as snd_soc_dapm_new_control_unlocked can
only return -EPROBE_DEFER or NULL when failing.
Secondly, most places will treat a return value of NULL as
an -ENOMEM. This is not correct either since any error except
EPROBE_DEFER will cause a return value of NULL from
snd_soc_dapm_new_control_unlocked.
Centralise this handling and the error messages within
snd_soc_dapm_new_control_unlocked and update the callers
to simply check IS_ERR and return. Note that this update is
slightly simpler in the case of dapm_kcontrol_data_alloc where
that is fairly close to the handling that was already in place.
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
