path: root/sound/soc/soc-utils.c
2009-11-25ASoC: Add BCLK calculation utility for TDM mode tooMark Brown
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-11-12ASoC: Add bit clock rate calculator utility functionsMark Brown
Many devices need to calculate the bit clock rate desired to work out the clock configuration required for the device. Provide utility functions to do this using both hw_params structures and raw numbers. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
