[ Upstream commit ff2be865633e6fa523cd2db3b73197d795dec991 ]
FW mailbox offset was not set before use and HDR size was not validated.
Fix this.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Link: https://lore.kernel.org/r/20190927200538.660-12-pierre-louis.bossart@linux.intel.com
Signed-off-by: Mark Brown <broonie@kernel.org>
The definitions for DSP oops structures were not aligned
correctly to current FW ABI version 3.6.0, leading to
invalid data being printed out to debug logs. Fix the structs
and update related platform code accordingly.
Signed-off-by: Kai Vehmanen <kai.vehmanen@linux.intel.com>
We use shim registers only to notify the other
side that a message was sent. The actual information
for the message is transmitted via mailbox.
cmd information inside shim register is not used by
the DSP, so we remove it to avoid confusion.
Signed-off-by: Daniel Baluta <daniel.baluta@gmail.com>
Currently on all supported platforms the IPC IRQ thread first signals
the sender when an IPC response is received from the DSP, then unmasks
the IPC interrupt. Those actions are performed without holding any
locks, so the thread can be interrupted between them. IPC timeouts
have been observed in such scenarios: if the sender is woken up and it
proceeds with sending the next message without unmasking the IPC
interrupt, it can miss the next response. This patch takes a spin-lock
to prevent the IRQ thread from being preempted at that point. It also
makes sure, that the next IPC transmission by the host cannot take
place before the IRQ thread has finished updating all the required IPC
registers.
Fixes: 53e0c72d98b ("ASoC: SOF: Add support for IPC IO between DSP and Host")
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Guennadi Liakhovetski <guennadi.liakhovetski@linux.intel.com>
Add support for the audio DSP hardware found on Intel Baytrail,
Cherrytrail and Braswell based devices.
Signed-off-by: Rander Wang <rander.wang@linux.intel.com>
Signed-off-by: Pan Xiuli <xiuli.pan@linux.intel.com>
