[ Upstream commit cf2c0e1ce9544df42170fb921f12da82dc0cc8d6 ]
The RX and TX counters registers offset have been swapped, fix that.
Fixes: fa7c0d13cb26 ("ASoC: sunxi: Add Allwinner A10 Digital Audio driver")
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
Link: https://lore.kernel.org/r/8b26477560ad5fd8f69e037b167c5e61de5c26a3.1566242458.git-series.maxime.ripard@bootlin.com
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 96e53c41e1f81c9e9d1ce38d3f28b95668b71dcf upstream.
The dapm components are now handled by the ALSA SoC SPDIF DIT driver
so can be removed.
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[ Upstream commit 2ad6f30de7087515a0bc2a718fca6681a57739a0 ]
Some SoCs have a reset line that must be asserted/deasserted.
This patch adds a quirk to handle the new compatible
"allwinner,sun6i-a31-i2s" which will deassert the reset
line on probe function and assert it on remove's one.
This new compatible is useful in case of A33 codec driver, for example.
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
In the current probe function the GPIO is acquired after the codec's
bus clock is enabled. However if it fails to acquire the GPIO due to
a deferred probe, it does not disable the bus clock before bailing out.
This would result in the clock being enabled multiple times.
Move the code that enables the bus clock after the part that gets the
GPIO, maintaining a separation between resource acquisition and device
enablement in the probe function.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
When sun4i_codec_create_card fails, we do not assign a proper error
code to the return value. The return value would be 0 from the previous
function call, or we would have bailed out sooner. This would confuse
the driver core into thinking the device probe succeeded, when in fact
it didn't, leaving various devres based resources lingering.
Make the create_card function pass back a meaningful error code, and
assign it to the return value.
Fixes: 45fb6b6f2aa3 ("ASoC: sunxi: add support for the on-chip codec on
early Allwinner SoCs")
Rename "sun4i_codec_widgets" to "sun4i_codec_controls" for
consistency with the struct field name.
Signed-off-by: Danny Milosavljevic <dannym@scratchpost.org>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into asoc-sunxi
The A20 has a few extra registers that the A10 doesn't have.
Therefore, use different regmaps for A10 as compared to A20.
Some of the registers defined in the driver are only usable on the
A20. Rename these registers.
Depend on ARCH_SUNXI or COMPILE_TEST as it doesn't make sense to enable
these if the appropriate SoC they're embedded in isn't enabled.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
The A31 SoC uses the same SPDIF block as found in earlier SoCs, but its
reset is controlled via a separate reset controller.
The DMA also complains when the maxburst is set to 4 so it's been adjusted
to 8 which suites both the older and newer SoCs.
codec driver and component driver has duplicated callback functions,
and codec side functions are just copied to component side when
register timing. This was quick-hack, but no longer needed.
This patch moves these functions from codec driver to component driver.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
There is a error message within devm_ioremap_resource
already, so remove the dev_err call to avoid redundant
error message.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
sound/soc/sunxi/sun4i-i2s.c:624:2-3: Unneeded semicolon
Remove unneeded semicolon.
Generated by: scripts/coccinelle/misc/semicolon.cocci
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
The Allwinner A10 and later come with a hardware block that used for the
PCM and I2S interfaces.
Add a driver for it in ASoC.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Tested-by: Chen-Yu Tsai <wens@csie.org>
The sun4i, sun5i and sun7i SoC families have an SPDIF
block which is capable of playback and capture.
This patch enables the playback of this block for
the sun4i families.
An external amp (if any) is connected to the external outputs of the SoC
of course, rather then directly to the internal amp.
Add support for PA gpio pin for controlling an external amplifier as used
on some Allwinner boards.
Rename the codec dapm widgets and routes with a _codec prefix. This is
a preparation patch for adding card dapm widgets and routes.
Commit 1fb34b48361e ('ASoC: sun4i: Implement MIC1 capture') added back some
code that disregards the clk_set_rate error code and always returns
-EINVAL. Fix that and return the code in order to have more clue about
what's going on.
The comment is misleading on how we should support external power amps, and
the variable is not used and generates a warning.
One of the input path used in the Allwinner codec is the MIC1. Add support
for it.
The power amplifier for the headphone output is called "the PA" and "the
headphone amplifier" in Allwinner's documentation for the A10 and A20.
sun4i-codec calls it "PA" in some places and "Pre-Amplifier" (which
isn't really accurate) in others, leading to user-visible controls with
different names referring to the same device.
When this driver implements audio input, it'll also need to expose
controls for the line and mic input preamps, so just referring to "the
Pre-Amplifier" will be ambiguous.
Change it to use "Power Amplifier" consistently for the power
amplifier's controls.
Signed-off-by: Adam Sampson <ats@offog.org>
Most of the boards have their headphone jack directly connected to the
matching pins of the SoCs. Since most of the time we will have the same
routing path, it makes no sense to put that in the DTS, since it will only
be some useless duplication there.
It also fixes the following warning messages that were seen so far, on
boards where we were using the bindings in the documentation example.
sun4i-codec 1c22c00.codec: ASoC: no sink widget found for Headphone Jack
sun4i-codec 1c22c00.codec: ASoC: Failed to add route HP Left -> direct -> Headphone Jack
sun4i-codec 1c22c00.codec: ASoC: Failed to add route HP Right -> direct -> Headphone Jack
Reported-by: Priit Laes <plaes@plaes.org>
The SND_PCM_RATE_KNOT covers all the rate settings, even though some that
we don't support, while we also list all the rate we support. Simply remove
it.
The current code, disregarding the clk_set_rate error code, was always
returning -EINVAL. Fix that and return the code in order to have more clue
about what's going on.
sound/soc/sunxi/sun4i-codec.c:708:3-8: No need to set .owner here. The core will do it.
Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: Emilio López <emilio@elopez.com.ar>
The sun4i, sun5i and sun7i SoC families have a built-in codec, capable
of both audio capture and playback.
While this is called a codec by Allwinner, it really is an in-SoC
combination of a codec and a DAI, with its own DAC/ADC and amplifiers
in a single memory-mapped controller.
The capture part has been left out for now, and will be added eventually.
Signed-off-by: Emilio López <emilio@elopez.com.ar>
