path: root/sound/soc/txx9
2012-12-10ASoC: txx9: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-21dmaengine/dma_slave: introduce inline wrappersAlexandre Bounine
Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic() interfaces to hide new parameter from current users of affected interfaces. Convert current users to use new wrappers instead of direct calls. Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269]. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-01-17Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
* 'next' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits) ARM: mach-shmobile: specify CHCLR registers on SH7372 dma: shdma: fix runtime PM: clear channel buffers on reset dma/imx-sdma: save irq flags when use spin_lock in sdma_tx_submit dmaengine/ste_dma40: clear LNK on channel startup dmaengine: intel_mid_dma: remove legacy pm interface ASoC: mxs: correct 'direction' of device_prep_dma_cyclic dmaengine: intel_mid_dma: error path fix dmaengine: intel_mid_dma: locking and freeing fixes mtd: gpmi-nand: move to dma_transfer_direction mtd: fix compile error for gpmi-nand mmc: mxs-mmc: fix the dma_transfer_direction migration dmaengine: add DMA_TRANS_NONE to dma_transfer_direction dma: mxs-dma: Don't use CLKGATE bits in CTRL0 to disable DMA channels dma: mxs-dma: make mxs_dma_prep_slave_sg() multi user safe dma: mxs-dma: Always leave mxs_dma_init() with the clock disabled. dma: mxs-dma: fix a typo in comment DMA: PL330: Remove pm_runtime_xxx calls from pl330 probe/remove video i.MX IPU: Fix display connections i.MX IPU DMA: Fix wrong burstsize settings dmaengine/ste_dma40: allow fixed physical channel ... Fix up conflicts in drivers/dma/{Kconfig,mxs-dma.c,pl330.c} The conflicts looked pretty trivial, but I'll ask people to verify them.
2011-12-23ASoC: txx9: Add .owner to struct snd_soc_cardAxel Lin
Add missing .owner of struct snd_soc_card. This prevents the module from being removed from underneath its users. Reported-by: Lothar Waßmann <LW@KARO-electronics.de> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-25ASoC: Convert txx9 directory to module_platform_driverAxel Lin
Factor out some boilerplate code. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-17Merge branch 'dma_slave_direction' into next_test_dirnVinod Koul
resolved conflicts: drivers/media/video/mx3_camera.c
2011-10-31sound-soc: move to dma_transfer_directionVinod Koul
fixup usage of dma direction by introducing dma_transfer_direction, this patch moves asoc drivers to use new enum Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-27Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-10-03ASoC: txx9: Add __exit_p at necessary placeAxel Lin
We have __exit annotation for txx9aclc_generic_remove(), thus add __devexit_p to wrap it. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-22sound: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-29ASoC: Fix txx9aclc.c buildRalf Baechle
552d1ef6b5a98d7b95959d5b139071e3c90cebf1 [ASoC: core - Optimise and refactor pcm_new() to pass only rtd] breaks compilation of txx9aclc.c: CC [M] sound/soc/txx9/txx9aclc.o /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c: In function 'txx9aclc_pcm_new': /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c:318:3: error: 'card' undeclared (first use in this function) /home/ralf/src/linux/linux-mips/sound/soc/txx9/txx9aclc.c:318:3: note: each undeclared identifier is reported only once for each function it appears in make[5]: *** [sound/soc/txx9/txx9aclc.o] Error 1 Fixed by providing a definition for card. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-07ASoC: core - Optimise and refactor pcm_new() to pass only rtdLiam Girdwood
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI. Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains card, pcm and DAI along with other members too that are useful too. Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: DMAENGINE: extend the control command to include an arg async_tx: trim dma_async_tx_descriptor in 'no channel switch' case DMAENGINE: DMA40 fix for allocation of logical channel 0 DMAENGINE: DMA40 support paused channel status dmaengine: mpc512x: Use resource_size DMA ENGINE: Do not reset 'private' of channel ioat: Remove duplicated devm_kzalloc() calls for ioatdma_device ioat3: disable cacheline-unaligned transfers for raid operations ioat2,3: convert to producer/consumer locking ioat: convert to circ_buf DMAENGINE: Support for ST-Ericssons DMA40 block v3 async_tx: use of kzalloc/kfree requires the include of slab.h dmaengine: provide helper for setting txstate DMAENGINE: generic channel status v2 DMAENGINE: generic slave control v2 dma: timb-dma: Update comment and fix compiler warning dma: Add timb-dma DMAENGINE: COH 901 318 fix bytesleft DMAENGINE: COH 901 318 rename confusing vars
2010-05-17Merge branch 'ioat' into dmaengineDan Williams
2010-05-17DMAENGINE: extend the control command to include an argLinus Walleij
This adds an argument to the DMAengine control function, so that we can later provide control commands that need some external data passed in through an argument akin to the ioctl() operation prototype. [dan.j.williams@intel.com: fix up some missed conversions] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-04-30MIPS: TXx9: Add missing MODULE_ALIAS definitions for TXx9 platform devicesGeert Uytterhoeven
This enables autoloading of the TXx9 sound driver on RBTX4927. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> To: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Linux MIPS Mailing List <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1101/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-26DMAENGINE: generic slave control v2Linus Walleij
Convert the device_terminate_all() operation on the DMA engine to a generic device_control() operation which can now optionally support also pausing and resuming DMA on a certain channel. Implemented for the COH 901 318 DMAC as an example. [dan.j.williams@intel.com: update for timberdale] Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Li Yang <leoli@freescale.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Magnus Damm <damm@opensource.se> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Joe Perches <joe@perches.com> Cc: Roland Dreier <rdreier@cisco.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2009-06-25ASoC: txx9aclc: dynamically allocate dmaengine devnameAtsushi Nemoto
Use kasprintf to allocate temporary devname string instead of a fixed size string. This fixes "FIXME" introduced on removal of BUS_ID_SIZE. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2009-06-17ASoC: Kill BUS_ID_SIZETakashi Iwai
Remove the use of BUS_ID_SIZE from txx9aclc.c, as BUS_ID_SIZE will be removed soon later. Also, use snprintf() instead of sprintf() as a safer operation. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-19ASoC: Add TXx9 AC link controller driver (v3)Atsushi Nemoto
This patch adds support for the integrated ACLC of the TXx9 family. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
