path: root/sound/soc
2008-04-24[ALSA] soc - Report errors from snd_soc_dapm_set_endpoint()Mark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] ASoC: Add support for 12 MHz MCLK in TLV320AIC3XJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Davinci ASoC supportVladimir Barinov
Add ASoC support for the TI Davinci SoC and the Davicni-EVM reference board. It includes: - ASoC Davinci DMA driver - ASoC Davinci I2S (Davinci McBSP module based) driver - ASoC Davinci-EVM reference board Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] ASoC: WM9713 driverLiam Girdwood
This patch adds an ASoC driver for the WM9713 AC97 codec. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add SUPERH depends to sound/soc/sh/KconfigKristoffer Ericson
Currently you will see an empty "SoC Audio support for SuperH" menu when building for other archs (example pxa). This patch adds "depends on SUPERH" to remove that empty menu. Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] soc - Mono voice playback volume for WM8753Mike Montour
Voice playback volume is in register bits 0:2, not 4:6. From: Mike Montour <mail@mmontour.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Werner Almesberger <werner@openmoko.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-19Merge branches 'arm', 'at91', 'ep93xx', 'iop', 'ks8695', 'misc', 'mxc', ↵Russell King
'ns9x', 'orion', 'pxa', 'sa1100', 's3c' and 'sparsemem' into devel
2008-04-19[ARM] 4977/2: soc - pxa2xx-ac97 - Add missing clk_enable()Mark Brown
Add missing clk_enable() Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] pxa: separate GPIOs and their mode definitions to pxa2xx-gpio.heric miao
two reasons: 1. GPIO namings and their mode definitions are conceptually not part of the PXA register definitions 2. this is actually a temporary move in the transition of PXA2xx to use MFP-alike APIs (as what PXA3xx is now doing), so that legacy code will still work and new code can be added in step by step Signed-off-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4834/3: Convert ASoC pxa2xx-ac97 driver to use the clock APIMark Brown
Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: eric miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-10[ARM] 4912/2: [AT91] Endrelia audio driver must use GPIO interfaceAndrew Victor
The SoC audio driver for the Endrelia ETI_B1 board should not access the PIO controller directly, but must rather use the AT91 GPIO interface. (This is updated version of patch with removed trailing whitespace) Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-23ASoC/TLV320AIC3X: Stop I2C driver ID abuseJean Delvare
Please stop using random I2C driver IDs. Also removed a pointless initialization to 0 of a static struct member. Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-29[ALSA] ASoC: Fix WM9712 mixer_event DAPM widget function typeJarkko Nikula
Add kcontrol argument to function since the API was changed by the commit 9af6d9562414568ecadf96aaef5b88e7e8b19821. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-29[ALSA] ASoC: Fix DAPM widget function types in pxa machine driversJarkko Nikula
Add kcontrol argument to functions since the API was changed by the commit 9af6d9562414568ecadf96aaef5b88e7e8b19821. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-02-29[ALSA] ASoC: Fix TLV320AIC3X PLL divider table for 64 kHz rateJarkko Nikula
2008-02-22[ALSA] soc - duplicate strcasecmp test for "rj-master" in mpc8610_hpcd_probe()Roel Kluin
In linus' git tree I found this problem. Is it also in the alsa tree? please confirm it's the right fix. The patch was not yet tested. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[ALSA] Fix lockdep warning in ASoC machine probeMark Brown
Don't take the codec mutex during machine probe until we have registered with ALSA, fixing a lockdep warning reported by Dmitry Baryshkov. Cc: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] mpc8610: Add mmap supportTimur Tabi
Enable mmap support in the MPC8610 ASoC driver. The driver can use ALSA's default mmap functionality, it was just not enabled previously. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Add ASoC drivers for the Freescale MPC8610 SoCTimur Tabi
Add the ASoC drivers for the Freescale MPC8610 SoC and the MPC8610 HPCD reference board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Preliminary ac97 drivers for Toshiba e800 PDAsIan Molton
Currently only the AUX channel is used (touchscreen) Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] S3C2412: suspend and resume supportBen Dooks
Support for suspend/resume for the S3C2412 ASoC IIS core driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ASoC: S3C2412 IIS driverBen Dooks
S3C2412 SoC IIS support for ALSA/ASoC Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Support suspend and resume of the I2S interface on s3c24xxGraeme Gregory
Signed-off-by: Graeme Gregory <graeme@openmoko.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Reinitialise DMA on every resumeGraeme Gregory
This one changes the DMA initialisation as it turns out the DMA driver in s3c24xx doesnt store registers between suspend/resume so you have to re-initialise the channels on every resume. Signed-off-by: Graeme Gregory <graeme@openmoko.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Initial WM8753 TLV support for capture mixerLiam Girdwood
Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Don't lock the codec list in snd_soc_dapm_new_widgets()Mark Brown
snd_soc_dapm_new_widgets() takes the codec lock when adding new widgets, causing lockdep warnings when applications later call down through ALSA to adjust controls. Since widgets are only added during probe this lock should be unneeded so don't take it. Thanks to Dmitry Baryshkov <dbaryshkov@gmail.com> for reporting this issue. Cc: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Add support for passing kcontrols with eventsLaim Girdwood
Signed-off-by: Laim Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Clean up tabsLiam Girdwood
Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Fix power switching support for DAPM_SWITCH widgetsMilan plzik
Signed-off-by: Milan plzik <milan.plzik@gmail.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Ensure PCMs are suspendedLiam Girdwood
This fixes a bug whereby PCMs were not being suspended when the rest of the audio subsystem was suspended. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Add D1 power event to power down event sequenceLiam Girdwood
2008-01-31[ALSA] ASoC TLV supportPhilipp Zabel
Add TLV support to ASoC. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Add device level DAPM eventLiam Girdwood
Added a device level dapm event so that both the machine and codec are informed when dapm events occur. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Fix inverted Phone volume WM9712 mixer controlJoe Sauer
Signed-off-by: Joe Sauer <jsauer@vernier.com> Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound: Use time_before, time_before_eq, etc.Julia Lawall
The functions time_before, time_before_eq, time_after, and time_after_eq are more robust for comparing jiffies against other values. A simplified version of the semantic patch making this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ change_compare_np @ expression E; @@ ( - jiffies <= E + time_before_eq(jiffies,E) | - jiffies >= E + time_after_eq(jiffies,E) | - jiffies < E + time_before(jiffies,E) | - jiffies > E + time_after(jiffies,E) ) @ include depends on change_compare_np @ @@ #include <linux/jiffies.h> @ no_include depends on !include && change_compare_np @ @@ #include <linux/...> + #include <linux/jiffies.h> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] neo1973: ASoC include pathname fixHarald Welte
Fix s3c24xx include file path changes in asoc driver Signed-off-by: Harald Welte <laforge@openmoko.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] cs4270: wrong sample rate when CONFIG_SND_SOC_CS4270_VD33_ERRATA is setTimur Tabi
When CONFIG_SND_SOC_CS4270_VD33_ERRATA is set, there was a mismatch between the mclk_ratios[] and cs4270_mode_ratios[] arrays. The two arrays have been merged and code has been shuffled. One side effect is that the cs4270_set_dai_sysclk() and cs4270_set_dai_fmt() functions are available only if I2C has been enabled. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc/wm8731: Fix stereo mixer controlsVille Syrjala
Disable the simultaneous load feature for the line in and headphone out volume registers. This allows left and right volume levels to be controlled separately. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ASoC TLV320AIC3X codec driverVladimir Barinov
This patch adds ALSA SoC support for TI TLV320AIC3X audio codecs. The features that are supported: o Capture/Playback/Bypass. o 16/20/24/32 bit audio. o 8k - 96k sample rates. o codec master only mode o DAPM. Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] use convenient treble scale on WM8750Stanislav Brabec
On Zaurus SL-C3200 (terrier/spitz) based on WM8750, treble scale is inconveniently reverted (increase level = decrease treble), in opposite to bass scale, which uses convenient scale. Fix ALSA WM8750 mixer treble to use convenient treble scale (increase = increase treble level) From: Stanislav Brabec <utx@penguin.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ASoC: sh: improve generated code for HAC module (AC97)Manuel Lauss
Change loops in ac97_read/write functions to count down to zero rather than up. Gcc will then use the 'dt' (decrement-and-test) op instead of an increment/compare op-pair. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - ln2440sbc ac97 supportIvan Kuten
This patch adds ac97 support for ln2440sbc board from LittleChips. This board is based on s3c2440 SoC + AC97 Realtek ALC650 codec. Existing s3c2443 implementation is slightly modified because s3c2440 and s3c2443 have different AC97 interrupts. Signed-off-by: Ivan Kuten <ivan.kuten@promwad.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] soc - Add 'Mono Playback Switch' to WM9712 codec driverMike Rapoport
The following patch adds 'Mono Playback Switch' control to WM9712 codec SoC driver. Also, it fixes Treble, Bass and Mono playback volume inversion bits. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-27i2c: normal_i2c can be made const (remaining drivers)Jean Delvare
2007-12-08Merge branch 'pxa-fixes'Russell King
2007-12-08[ARM] 4690/1: PXA: fix CKEN corruption in PXA27x AC97 cold reset codeMichael Brunner
Fix CKEN register corruption in the PXA27x cold reset code located in sound/arm/pxa27x-ac97.c. The problem has been introduced with a pxa_set_cken() function change in linux 2.6.23. This patch is based on patch 4527/1 that fixes the same problem in the ASoC PXA-AC97 driver. Additionally a definition for the CKEN index value is added and applied to both PXA AC97 drivers. Signed-off-by: Michael Brunner <mibru@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-20[ALSA] fix private data pointer calculation in CS4270 driverTimur Tabi
Fix the calculation of the private_data pointer in the CS4270 driver. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-11-20[ALSA] s3c2443-ac97: compilation fixKrzysztof Helt
The Samsung S3C24xx uses new architecture file layout in the post 2.6.23 kernel. This patch fixes include path for the s3c2443-ac97.c. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
