This makes it that little bit easier to spot the diagnostics in the
logs.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Speaker amplifier is controlled by TWL4030 GPIO which may sleep. Therefore
use gpio_set_value_cansleep to get rid of runtime warning that is introduced
after the commit 9c4ba94 and to get a stack trace if ever executing this
code in atomic context.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
aic3x_init does a soft reset first and thus TLV320AIC3x GPIO setup must be
done after doing the basic init. Before multi-component the init was done
at i2c probe time and GPIO setup at soc probe time.
'struct of_device' no longer exists, and its functionality has been merged
into platform_device. Update the MPC8610 HPCD audio drivers (fsl_ssi, fsl_dma,
and mpc8610_hpcd) accordingly.
Also add a #include for slab.h, which is now needed for kmalloc and kfree.
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into for-2.6.37
Otherwise we generate worrying (but benign) warnings for amps.
This is an ALSA codec for the Texas Instruments WL1273 FM Radio.
Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com>
The Freescale P1022 is a dual-core e500-based SOC with multimedia capabilities,
specifically the same SSI audio controller on the MPC8610. The P1022 DS
reference board includes a P1022 and a Wolfson Microelectronics WM8776
codec.
Fix reference to moved header file, which was unused anyway.
This change fixes below build error:
CC sound/soc/pxa/pxa2xx-ac97.o
sound/soc/pxa/pxa2xx-ac97.c:27:24: error: pxa2xx-pcm.h: No such file or directory
make[3]: *** [sound/soc/pxa/pxa2xx-ac97.o] Error 1
make[2]: *** [sound/soc/pxa] Error 2
make[1]: *** [sound/soc] Error 2
make: *** [sound] Error 2
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
This patch adds support for the tlv320aic3007 codec to the tlv320aic3x
driver.
The tlv320aic3007 is similar to the aic31, but has an additional class-D
speaker amp. The speaker amp control register overlaps with the mono
output register of other codecs in this family, so we add logic to
identify the actual codec being registered to set things up accordingly.
Signed-off-by: Randolph Chung <tausq@parisc-linux.org>
Some codecs have separate DAIs for playback and capture, so the DMA driver
should allocate a DMA buffer only for the streams that are valid when the
driver is opened.
In e740_init(), we call gpio_request() for
GPIO_E740_MIC_ON, GPIO_E740_AMP_ON and GPIO_E740_WM9705_nAVDD2.
We should free the these gpio accordingly in e740_exit().
In the process of unification of codec DAI names while implementing
multi-component, the CX20442 codec DAI has been renamed to "cx20442-hifi".
This new name seems not adequate for a 8kHz voice codec.
Use a better name, "cx20442-voice", as suggested by Liam Girdwood.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
The tlv320aic3x codec driver only supports symmetric rates for capture/
playback. Set the flag in the DAI accordingly.
Add code that programs the DMA and SSI controllers differently based on the
FIFO depth of the SSI.
The SSI devices on the MPC8610 and the P1022 are identical in every way except
one: the transmit and receive FIFO depth. On the MPC8610, the depth is eight.
On the P1022, it's fifteen. The device tree nodes for the SSI include a
"fsl,fifo-depth" property that specifies the FIFO depth.
88PM860x codec is used in Marvell saarb development board. 88PM860x codec
is used as master mode for SSP communication. Only I2S format is supported.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Add 88PM860x codec driver. 88PM860x codec supports two interfaces. And it
also supports headset/mic/hook/short detection.
Since the SSC is already being registered as a device under arch and
the DMA and SSC hardware are pretty much the same provide a simplified
device registration function for the Atmel SSC which will add the
ASoC-specific devices within the ASoC code, parenting the SSC device
off the actual SSC device. Also use it in the sam9g20-ek driver.
A couple of typos in the multi-component conversion.
Instead of unconditionally enabling the crystal oscillator on the WM8731
only enable it when explicitly selected via set_sysclk(), allowing machine
drivers to specify that they drive a clock into MCLK alone. This avoids
any conflicts between the oscillator and the external MCLK source and saves
power for systems which do not need the oscillator.
This should also deliver a small power saving on systems using the crystal
since the oscillator will only be enabled when the ADC or DAC is active.
Output size_t type as a "%Zu" to avoid warnings.
Dead pxa2xx-pcm.h includes and a missing ,
This patch contains two small fixes for the sound board driver for the qi_lb60
introduced by the multi-component patches:
* Remove unnecessary includes: Those includes where only used to get the
definitions for the DAI devices and are thus not needed anymore.
* Fix a typo.
Signed-off-By: Lars-Peter Clausen <lars@metafoo.de>
Reported-by: Seungwhan Youn <claude.youn@gmail.com>
The RX and TX directions were inverted.
Fairly simple conflicts, the most serious ones are the i.MX ones which I
suspect now need another rename.
arch/arm/mach-mx2/clock_imx27.c
arch/arm/mach-mx2/devices.c
arch/arm/mach-omap2/board-rx51-peripherals.c
arch/arm/mach-omap2/board-zoom2.c
sound/soc/fsl/mpc5200_dma.c
sound/soc/fsl/mpc5200_dma.h
sound/soc/fsl/mpc8610_hpcd.c
sound/soc/pxa/spitz.c
This is not supported by current hardware revisions.
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: sound/usb/format: silence uninitialized variable warnings
MAINTAINERS: Add Ian Lartey as comaintaner for Wolfson devices
MAINTAINERS: Make Wolfson entry also cover CODEC drivers
ASoC: Only tweak WM8994 chip configuration on devices up to rev D
ASoC: Optimise DSP performance for WM8994
ALSA: hda - Fix dynamic ADC change working again
ALSA: hda - Restrict PCM parameters per ELD information over HDMI
sound: oss: sh_dac_audio.c removed duplicated #include
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into for-2.6.37
Trivial overlap with the removal of the local revision variable.
sound/soc/codecs/wm8994.c
The DAC OSR should be selected based on the sample clock ratio.
Drive a minimal supported number of clocks required for the current
bit format in master mode. In slave mode this setting has no effect.
Implement set_sysclk() and then rather than assuming 256fs use the
supplied value to calculate and configure the clock ratio for the
currently used sample rate. As a side effect we also end up
implementing clock selection for the ADC path.
In order to avoid confusion remove the existing set_clkdiv() based
configuration of the clock source for the DAC and update the SMDK64xx
driver (which is the only in-tree user of the CODEC).
In the case of the BCLK rate the defines are at best misleading anyway.
All the cool kids are using snd_soc_update_bits() these days.
There's much more needed but this'll get us started.
SCFR bit is required to be always set if pxa ssp is in slave mode. This bit
indicates clock input to SSPSCLK is only active during data transfers.
Since pxa2xx-pcm.h is removed from sound/soc/pxa, we need to update the
path in related files.
Tested-by: Ian Lartey <ian@opensource.wolfsonmicro.com>
anyway.
Removed #include of pxa2xx-pcm.h
Signed-off-by: Ian Lartey <ian@opensource.wolfsonmicro.com>
Since the core now includes deduplication in the name of CODEC
devices there's no need to add extra for the debugfs directory name.
Since the debugfs directory is current per CODEC we should only init
it when the CODEC is initialised, otherwise we end up with errors
being generated when an attempt is made to add duplicate debugfs
entries.
Since most of this stuff is actually for the card we should refactor
but this can come later.
Any subsequent revisions will have these configuration changes applied
by default.
Change the chip defaults to optimise performance of some of the DSP
functionality.
ASoC: add AD1980 obsolete information
ASoC: register cache should be 1 byte aligned for 1 byte long register
ALSA: hda - Adding support for new IDT 92HD87XX codecs
ASoC: Fix inverted mute controls for WM8580
ALSA: HDA: Use model=auto for LG R510
ALSA: hda - Update model entries in HD-Audio-Models.txt
ALSA: hda: document VIA models
ALSA: hda - patch_nvhdmi.c: Add missing codec IDs, unify names
ALSA: hda - add support for Conexant CX20584
ALSA: hda - New snd-hda-intel model/pin config for hp dv7-4000
ALSA: hda - Fix missing stream for second ADC on Realtek ALC260 HDA codec
ALSA: hda - Make converter setups sticky
ALSA: hda - Add support for Acer ZGA ALC271 (1025:047c)
sound/oss: Adjust confusing if indentation
sound: oss: au1550_ac97.c removed duplicated #include
ASoC: Fix for changed Eureka Kconfig symbol names
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
