Add support for AC97 controllers found in Cirrus Logic EP93xx family SoCs.
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch replace magic code with defined name,
and remove unnecessary settings which set default value
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Remove unused vol from struct access_mask
Reduces object size ~3kb.
$ size sound/soc/codecs/wm8994.o*
40727 4384 4480 49591 c1b7 sound/soc/codecs/wm8994.o.new
43879 4384 4480 52743 ce07 sound/soc/codecs/wm8994.o.old
Current FSI driver had not cared about simultaneous
playback/capture on same port.
This patch add new fsi_stream struct to care it,
This patch add S/PDIF machine driver to support S/PDIF PCM audio
on SMDKC100, SMDKC110 and SMDKV210 boards.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
This patch adds S/PDIF CPU driver for various Samsung SoCs.
The driver can specify a DAI ID number so use that.
WM8994 relies on the DAIs having IDs that match the AIF numbers.
We unconditionally require SYSCLK since while only microphone detection
specifically requires SYSCLK any actual use case would enable it via
some other means but microphone detection may have nothing active other
than the bias itself.
So that modprobe can load the driver automatically when the platform device
appears.
With generic AC97 ASoC glue driver (codec/ac97.c), we get following warning when
the device is registered (slightly stripped the backtrace):
kobject (c5a863e8): tried to init an initialized object, something is seriously
wrong.
[<c00254fc>] (unwind_backtrace+0x0/0xec)
[<c014fad0>] (kobject_init+0x38/0x70)
[<c0171e94>] (device_initialize+0x20/0x70)
[<c017267c>] (device_register+0xc/0x18)
[<bf20db70>] (snd_soc_instantiate_cards+0x924/0xacc [snd_soc_core])
[<bf20e0d0>] (snd_soc_register_platform+0x16c/0x198 [snd_soc_core])
[<c0175304>] (platform_drv_probe+0x18/0x1c)
[<c0174454>] (driver_probe_device+0xb0/0x16c)
[<c017456c>] (__driver_attach+0x5c/0x7c)
[<c0173cec>] (bus_for_each_dev+0x48/0x78)
[<c0173600>] (bus_add_driver+0x98/0x214)
[<c0174834>] (driver_register+0xa4/0x130)
[<c001f410>] (do_one_initcall+0xd0/0x1a4)
[<c0062ddc>] (sys_init_module+0x12b0/0x1454)
This happens because the generic AC97 glue driver creates its codec->ac97 via
calling snd_ac97_mixer(). snd_ac97_mixer() provides own version of
snd_device.register which handles the device registration when
snd_card_register() is called.
To avoid registering the AC97 device twice, we add a new flag to the
snd_soc_codec: ac97_created which tells whether the AC97 device was created by
SoC subsystem.
It is not needed since snd_ac97_mixer() will create a new ac97 object for us.
Removing the call also fixes a memory leak since codec->ac97 is set to NULL at
the beginning of snd_ac97_mixer().
Some FSI register have similar bit array for PortA/B and In/Out.
This patch add new macro and shift for it
It is not so important for now.
But will be used in future.
There is a typo here that got copy and pasted to several probe
functions. kzalloc() returns NULL on allocation failures and not an
ERR_PTR.
Acked-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Reduce the source code size still futher by only specifying non-zero
rows in the WM8962 access map.
Dramatically reduce the code size for the WM8962 register defaults table
by switching to explicitly initialise only defined registers, relying on
static defaulting to zero for the overwelming bulk of the register map.
Similar treatement for the register access table will come later and will
produce a similarly dramatic code size shrink.
It's not needed with multi-component.
Acked-by: Timur Tabi <timur@freescale.com>
Rather than block the workqueue by sleeping to do the debounce use delayed
work to implement the debounce time. This should also means that we extend
the debounce time on each new bounce, potentially allowing shorter debounce
times for clean insertions.
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
It doesn't need to be exported with multi-component.
Remove duplicated include.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Platform driver ID table must be zero-element terminated.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Be verbose and print out the device revision.
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Ensure that all drivers that use SPI and I2C will work properly
by providing SPI write functions for all different I/O types.
Since only 4 mainline ASoC codecs support the trigger
callback, we cannot rely upon them stopping the frame clock
if they are master and must assume it is running even if the
sound is paused. Thus we cannot start the ASP until the trigger
method.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Signed-off-by: Martin Ambrose <martin@ti.com>
The PLL is disabled when the corresponding bit is set not the other
way around. This commit depends on my other commit with Subject
"ASoC: WM8804: Refactor set_pll code to avoid GCC warnings".
Ensure that no uninitialised variable warnings are generated by
GCC.
Make sure the DAI name does not include a '/' since we might have
per DAI debugfs or sysfs entries in the future.
GPIO2 and GPIO3 on the WM8962 are MFPs and need to be put into GPIO mode
before the GPIO block can be used to control them. We're already doing
this when used via gpiolib, factor out the code for use when setting static
configurations via platform data as well.
Allow microphone detection on WM8962 to be performed using the interrupt
signal, allowing the detection of both microphone presence and button
presses with a signal singal from the CODEC to CPU. Currently a 250ms
debounce time is applied to both short circuit and presence detection,
this has not been optimised.
The WM8962 features five GPIOs, add support for controlling their output
state via gpiolib.
While it is a generic serial port in practice the i.MX SSI is only supported
in Linux as an audio port (the i.MX has dedicated SPI controllers and so on).
This means we don't need to disambiguate against other uses of the hardware
and so can drop the -dai suffix from the driver name which fixes merge
issues with the i.MX tree in -next.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
The restrictions on configuring BCLK are overly cautious, other constraints
in the system should ensure that reconfiguration is not possible when the
device is sufficiently active to be unable to support reclocking.
The WM8804 is a high performance consumer mode S/PDIF transceiver with
support for 1 received channel and 1 transmitted channel.
No need to explicitly set the bus type, spi_register_driver does
that for us.
Add the widget for MICBIAS power control and allow configuration of the
microphone bias setup via the platform data for the WM8962. When
microphone status signals are brought out to GPIO this should be
sufficient to enable microphone detection.
There are some status bits for microphone detection in here.
Provide an initial hookup for interrupts on the WM8962. Currently we simply
report error status via log messages if an IRQ is provided for the device.
For consistency.
When configuring the FLL we preserve the FLL enable configuration in order
to allow us to reenable the FLL after configuration but we do not clear
the other bits in the register, causing old configuration to be preserved.
Since we are using custom get/put handlers
use SOC_ENUM_SINGLE_EXT_DECL instead of the original SOC_ENUM_SINGLE_DECL
macro.
sound/soc/codecs/wm8985.c: In function 'wm8985_hw_params':
sound/soc/codecs/wm8985.c:731:2: warning: format '%d' expects type 'int', but argument 4 has type 'size_t'
Actually the variable is fine as int.
We are not using the private data in this function, so get rid of it.
Remove version number and clean up some indentation.
