path: root/sound/soc
2012-08-27asoc: aic326x machine: Add supp. for new TI driverManoj Gangwal
Add support for latest TI codec aic326x driver. Bug 1034241 Change-Id: I387693ed2de466d1704c6f7ff0a1b15c7cbff32f Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/125180 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
2012-08-27asoc: codecs: Add TI aic326x driverManoj Gangwal
Add latest TI aic326x driver. Bug 1034241 Change-Id: I8457538025b2989c4baa5eaefef48bdd5535def9 Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/125167 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
2012-08-03asoc: tegra: fix compilation error in max98095Rhyland Klein
change 4b70cc537cadc787b748c7c246d703a240b08985 introduced a compilation error. Signed-off-by: Rhyland Klein <rklein@nvidia.com> Change-Id: I59e54537d9bb4b30e807478e5b7634db0813a739 Reviewed-on: http://git-master/r/120443 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-08-02asoc: codecs: max98088: fix no audio after resetSayak Ghosh Choudhury
98088 codec register value is altered to fix no audio issue after reset. Previously after reset the register value was getting wiped out. Bug 1017782 Change-Id: I060929bfb868c48dc4db9def171a3bdd167a3913 Reviewed-on: http://git-master/r/120319 Tested-by: Sayak Choudhury <sayakc@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Vijay Mali <vmali@nvidia.com> Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-07-30asoc: tegra: i2s: Fixes for audio_clock_2x rateNitin Pai
audio_clock_2x parent needs to be set first before changing the rate, else it will not work. Bug 1019017 Signed-off-by: Nitin Pai <npai@nvidia.com> Reviewed-on: http://git-master/r/116682 (cherry picked from commit fdc4da6d96e7be4aa2accf098de48543e745cf11) Change-Id: I93aeb1afed8732e8a1b1cff4ab03b9a9f654804f Reviewed-on: http://git-master/r/118250 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bob Johnston <bjohnston@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-07-27asoc: tegra: integration of slave mode support.Ankit Gupta
Add master/slave configurability support interface for all codecs. Currently, complete slave mode functionality is added only for MAX98088 and WM8903 codec only. By default, board parameters will set i2s master mode for all codecs. asoc: tegra: utils: add support for i2s master/slave mode. Support for i2s in master or slave mode is made generic by obtaining information from platform data. Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: Ided0fcefb6cdb124b78aab423bfd8c7dccd4bf6e Reviewed-on: http://git-master/r/111553 (cherry picked from commit bb1ad7222f9c75424a45976d16de418bc927dc04) asoc: tegra: wm8903 machine: add support for i2s in slave mode. Add support for i2s as slave for playback and capture use cases. Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I1f6b73a0a1b690ecd311b0ff4107aadbb1f037d8 Reviewed-on: http://git-master/r/111472 (cherry picked from commit 0434f8ba74adefe60597d95d30a455b9b2ece9b8) asoc: tegra: wm8753 machine: add support for i2s in slave mode. Add support for i2s as slave for playback and capture use cases. Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: Ib0596955cd0c6ac5ec57b0f3c6ecc9e4ed41268c Reviewed-on: http://git-master/r/113208 (cherry picked from commit 0fc6b5e3a98d9f8866f73d7914b0c590334ce862) asoc: tegra: aic326x machine: add support for i2s in slave mode. Support for i2s in slave mode is added for playabck and capture use cases. Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I41f6459765f075703ad7f5f8dc9d4628dd853820 Reviewed-on: http://git-master/r/112874 (cherry picked from commit 9a89ede36a1dca6f53250444e819443fb6f28d09) asoc: tegra: rt5640 machine: add support for i2s in slave mode. Add support for i2s as slave for playback and capture use cases. Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I850ec62149b8a8d244445b70658b632dbce06558 Reviewed-on: http://git-master/r/112878 (cherry picked from commit 1d51561c8edf47d8557a825450a48ee8743a185b) asoc: tegra: max98088 machine: add support for codec i2s as slave. Add support for codec i2s as slave during voice Call. (Bug 998682) Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I8fc54d367e9acd5417d270869cb5a9398b3b527f Reviewed-on: http://git-master/r/110559 (cherry picked from commit 78a490867e131b1cc892094ddd844c2b892cafb6) asoc: tegra: max98095 machine: add support for i2s in slave mode. Add support for i2s as slave for playback and capture use cases. Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I80944d403be94c55ad2ce31aea921d80ea7c088a Reviewed-on: http://git-master/r/112875 Reviewed-on: http://git-master/r/118080 Reviewed-by: Scott Peterson <speterson@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
2012-07-18asoc: tegra2: fix ac97 das build dependencyMarcel Ziswiler
Building an ac97 only configuration failed due to missing SND_SOC_TEGRA20_DAS. While at it fix build time warning caused by two unused local variables.
2012-07-17asoc: tegra: p852: Added machine driver for P852Nitin Pai
Renamed P1852 machine driver to VCM so that can be used for P1852/P852 and E1853 as well. Bug 1008391 Signed-off-by: Nitin Pai <npai@nvidia.com> Reviewed-on: http://git-master/r/113886 (cherry picked from commit 5eb23e30bab716b28146b85438989e58761c7136) Change-Id: I8d1363a6419c6381b8d23ebd38d625fb482084dc Reviewed-on: http://git-master/r/116056 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-07-12asoc: codecs: max98088: Headset DetectionNikesh Oswal
Add code for headset detection according to that state transitions mentioned for JKSNS field in the max98088 codec datasheet Bug: 110529 Bug: 1008246 Signed-off-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-on: http://git-master/r/112127 (cherry picked from commit 12a2259e0e9cf7da4bf64bad2a97c32cec41477c) Change-Id: I7d45b210dd02f181e71a08d9b3de7cff109dd88b Reviewed-on: http://git-master/r/114445 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-07-12asoc: tegra: Change HW disabling dequence and I2S clock parentNikesh Oswal
Change HW disabling dequence and I2S clock parent in slave mode for voice call use-case Bug: 1005176 Signed-off-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-on: http://git-master/r/110529 (cherry picked from commit 4b138cdeb3374575bde9f49d0c644faa91ced68f) Change-Id: Ia037ed5ef45d38972c3e1e1a78b4b7b7f39d8f72 Reviewed-on: http://git-master/r/114444 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-06-22asoc: tegra2: ac97 audio capture functionalityMarcel Ziswiler
Migrate AC97 audio capture aka record functionality.
2012-06-15sound: soc: tegra: fix compilation errorsRhyland Klein
Several compilation errors popped up when building the 3.1 kernel for chrome. Warnings included callback structure changing and not being updated in the max98095 codec driver and unused labels. With these change I am able to compile in the max98095 codec support and wm8903 without build errors. Bug 986933 Change-Id: Ia8b2511f54b031eadcad8c74efa88be9288f25fb Signed-off-by: Rhyland Klein <rklein@nvidia.com> Reviewed-on: http://git-master/r/105464 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-06-11asoc: max98095: probe with no device there fixRhyland Klein
There is path through which registering a card will fail to probe, but that error code is not propogated back to the tegra machine driver. To catch this case in the machine driver's probe routine, we need to ensure that after registering the card, the card is instantiated and fail probe if not. Change-Id: I64ba952685ef193a3b248502943771c518396808 Signed-off-by: Rhyland Klein <rklein@nvidia.com> Reviewed-on: http://git-master/r/106837 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-06-08Initial Toradex Colibri T20 L4T R15 support.Marcel Ziswiler
2012-06-06asoc: tegra: Fix setting rate for clk_audio_2xNitin Pai
- For slave mode, clk_audio_2x needs to be programmed to bitclock value. Setting this frequency is not possible if the parent clock has different frequency. Hence change the parent of this clock to i2s_sync clock first before setting the rate. - Fixed setting uninitialized variables. Bug 948478 Change-Id: Ieb4656e6e114d3a9b815f44003a476c4b9892059 Signed-off-by: Nitin Pai <npai@nvidia.com> Reviewed-on: http://git-master/r/104445 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bob Johnston <bjohnston@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-06-04asoc: tegra: p1852: Use pcm-driver from platformNitin Pai
Use the pcm-driver specified from platform/board specified file. Bug 991926 Change-Id: I9e4c9a3f76bacb22de817273a2281ac9b8959c43 Signed-off-by: Nitin Pai <npai@nvidia.com> Reviewed-on: http://git-master/r/105415 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bob Johnston <bjohnston@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-31ASoC: tegra: remove compilation warningJuha Tukkinen
Ensure i2s_client_bits and i2s_audio_bits do not get used uninitialized. Bug 949219 Change-Id: Ibdd7f2598278639388d2c2afb5843f2471375ea2 Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com> Reviewed-on: http://git-master/r/105426 Reviewed-by: Sachin Nikam <snikam@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
2012-05-31asoc: codecs: ALC5639/40: Change to reduce codec pwr in lp0Manoj Gangwal
Bug 964287 1) Add support for resetting the codec while entering in lp0 state to save codec power in lpo for KAI. 2) Fix for cache sync. 3) Add index sync functionality. Change-Id: I04039eb55944bfe7f06e6a1405ac3c810c5688a1 Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/104480 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Tested-by: Daniel Solomon <daniels@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-28ASoC: Tegra: Add support for AVP renderingSumit Bhattacharya
Add alsa controls to specify which alsa device is used by AVP to render audio. Also add support for disabling DMA interrupt when AVP renders audio. Also add couple of alsa controls to query DMA channel ID and DMA buffer physical address. Bug 968814 Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com> Change-Id: If593329db72bf00d97f7433f5c54e13500281253 Reviewed-on: http://git-master/r/97916 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-05-25ASoC: tegra: treat compilation warning as errorSanjay Singh Rawat
Bug 949219 Change-Id: Ic8976b008772220299369369427a80dd370df596 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/104419 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-25ASoC: resolve compilation time warningsSanjay Singh Rawat
Bug 949219 Change-Id: If7b4dd928cc5a808fd1a674bcc5f31c9a396a043 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/103772 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-24asoc: tegra: utils: fix for multiple instances of extern1 clock.Ankit Gupta
The extern1 codec clock was not getting switched off whenever codec goes below BIAS_OFF level. Moreover, there were two instances of extern1 clock whenever codec was on. Reason behind this was that, those codecs for which probe function was called and were not present on board, turned on their extern1 clock, but clean up routine (for switch device register failure) was not able to turn off the clock. With this change, a conditional check is put to turn off the clock. (Bug 984678) Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I585ecf73c0cabca856592dcd84e67588dfe13beb Reviewed-on: http://git-master/r/104073 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com> Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-23asoc: tegra: P1852 machine: Add TDM mode settingsNitin Pai
Pass TDM mode variables for CPU dai. Codec Id is not passed properly, hence use dual instances of the dai_link operations. Bug 948478 Change-Id: I13188d5001b8f9c2f2f67ee7a9d3bec89311037d Signed-off-by: Bob Johnston <bjohnston@nvidia.com> Reviewed-on: http://git-master/r/103793 Reviewed-by: Nitin Pai <npai@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-23asoc: tegra: Add TDM mode supportNitin Pai
Added TDM mode support in I2S driver. Added support functions in AHUB to pass audio/client bits. Added support functions in AHUB to pass audio/client channels. Fixed the stopping of I2S/TDM by clearing the fifo. Bug 948478 Signed-off-by: Nitin Pai <npai@nvidia.com> Change-Id: I560f4ab5b71e4833931934275272a094241241fe Reviewed-on: http://git-master/r/103840 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-15asoc:codecs: tiaic326x: remove mini dsp supportNikesh Oswal
disable the compilation of minidsp specific code, we are disabling the minidsp in codec because the driver is not stable and different customers are using different process flows for mini dsp Change-Id: I08f8f485f1a379773f2f1f7ae2fd1b3a89c45d07 Signed-off-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-on: http://git-master/r/101232 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-14asoc: tegra: MAX98088 machine: Add support for setting bias levelAnkit Gupta
Allow setting bias level to turn off clock extern1 when codec is idle for enterprise board. (Maxim 98088 codec) Bug 984678 Change-Id: Ib01be71362ab0c5525f570693b41db73777875e6 Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Reviewed-on: http://git-master/r/102240 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-14asoc:tegra: Enable I2S tx in voice callNikesh Oswal
Associated with I2S there is a playback ref count, when we open the I2S for plyabck it is incremented and during voice call we check if its not zero then enable the tX. This logic fails if the start-trigger is not called for the prior playback stream. Hence we unconditionally enable the tx, which is harmless Bug: 981806 Change-Id: I66aafda596e2b2b03745e93f3e851dedc3b8ef5d Signed-off-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-on: http://git-master/r/101996 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-14asoc: codecs: spdif: Add support for setting bias levelAnkit Gupta
Allow setting bias level to turn off clock extern1 on enterprise when codec is idle. Added a dummy widget to make the target_bias_level to BIAS_OFF as per required by the new ALSA kernel. Bug 984678 Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I29de405c26286eee0a49e655f1d4236f6093ce8a Reviewed-on: http://git-master/r/100287 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com> Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
2012-05-14asoc: tegra: pcm: Add support for setting bias levelAnkit Gupta
Allow setting bias level to turn off clock extern1 when codec is idle for Enterprise (Maxim 98088 codec). Bug 984678 Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com> Change-Id: I09538dafe6c6f01547ff989de3c23933c9745db0 Reviewed-on: http://git-master/r/100286 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com> Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com> Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
2012-05-14asoc: codecs: resolve compilation time warningsSanjay Singh Rawat
Bug 949219 Change-Id: I9c2a0aa22432c586a7e72273ad935d42332e873f Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/95087 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
2012-05-11Revert "asoc: tegra: Add TDM mode support"Nikesh Oswal
This reverts commit dfa00e184b5fe0d4d48fa62a15fc956de9b6b65c. This is causing a regresssion. Bug: 977319 Change-Id: I4fe6daf88b2988978f089194f2931691eeb0eb09 Signed-off-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-on: http://git-master/r/101687 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Vijaya Bhaskar <vbhaskar@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-08Revert "asoc:codecs: tiaic326x: remove minidsp support"Simone Willett
This reverts commit 774fa71fc9834fbdcb297048d9e9a4bc7b944b48 Change-Id: Ib187dff51d3b2fd2b2ac0c98a53abe07c99148aa Reviewed-on: http://git-master/r/101359 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-08asoc: codecs: rt5640: resolve compilation time warningsSanjay Singh Rawat
bug 949219 Change-Id: I4409eaff4042967133cc948452ca8e52d15b2d18 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/92279 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-05-08asoc: tegra: pcm: If there is no dma information exit from triggerNikesh Oswal
If there is no dma information exit from trigger, this is required for the dummy voice call playback and capture streams Change-Id: I5276e7ebb72c17268a9785204fea9f395b2e5d3a Signed-off-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-on: http://git-master/r/101235 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-08asoc:codecs: aic326x: change alsa ctrls for headphone driverNikesh Oswal
Use non-inverting type alsa control for headphones as same have been used for spk and recv Change-Id: I39d2613071063782dff8151b07ef46ca8e16db5c Signed-off-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-on: http://git-master/r/101234 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-08asoc:codecs: tiaic326x: remove minidsp supportNikesh Oswal
disable the flags for turning off the mini dsp support Change-Id: Ieb0b18fc3cc1143cbd0a315c85688d2f1ae4efe1 Reviewed-on: http://git-master/r/101233 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Nikesh Oswal <noswal@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-04dmaengine/dma_slave: fix merge issue.Linqiang Pu
Change-Id: I0931f4ef7a5464dd32d8c703288a137fc77857ce Signed-off-by: Linqiang Pu <dpu@nvidia.com> Reviewed-on: http://git-master/r/100090 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-05-01asoc: codecs: spdif: Add support for setting bias levelManoj Gangwal
Allow setting bias level to turn off clock extern1 on KAI when codec is idle. Added a dummy widgets to make the target_bias_level to BIAS_OFF as per required by the new ALSA kernel. Bug 964287 Change-Id: I628744040866a9879eedc41ed4ee25af38ed86fb Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/99667 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Hunk Lin <hulin@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-01asoc: tegra: pcm: Add support for setting bias levelManoj Gangwal
Allow setting bias level to turn off clock extern1 when codec is idle. Bug 964287 Change-Id: I48056b86a9fdaea70202bee9326debaaddf69c0c Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/99665 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-05-01asoc: tegra: ALC5640 machine: Add support for setting bias levelManoj Gangwal
Allow setting bias level to turn off clock extern1 when codec is idle. Bug 964287 Reviewed on: http://git-master/r/#change,93950 Change-Id: Icc11e8bfb359b432f0bfd9ba214877259188de2b Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/99659 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Hunk Lin <hulin@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-05-01ASoC: tegra: Fix bit-format checkingJubeom Kim
condition to check bit-format is always false because TEGRA20_I2S_CTRL_BIT_FORMAT_I2S is zero. Bug 947429 Change-Id: Ieb92f0732b092100dc1bf323ad60aff4439d5b3d Signed-off-by: Jubeom Kim <jubeomk@nvidia.com> Reviewed-on: http://git-master/r/99341 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-05-01asoc: tegra: Add PCM driver for TDM modeNitin Pai
Modified existing pcm driver to take dma mode/ hw structure. Exported the functions needed for other pcm mode driver. Added new TDM mode hw param structure. Added pass SINGLE/DOUBLE buffered dma mode params. Bug 948478 Change-Id: I58309d52748f813b3303a8d6a052fbb6cc7ca87a Signed-off-by: Nitin Pai <npai@nvidia.com> Reviewed-on: http://git-master/r/99146 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-04-26asoc: tegra: ALC5640 machine:Add support to detect HP in LP0Manoj Gangwal
Add Support to detect the HP insertion or removal during LP0 state. Bug 969405 Change-Id: Ibedf1769338e16877240ea9cc82fa7469eb7ff9e Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/98745 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-04-26ASoC: Tegra: Make dma_req count easily configurableSumit Bhattacharya
Instead of always using 2 dma_req count pass max dma_req_count through a macro. Ensure dma_req_count does not cross period_count. Bug 968814 Change-Id: Iddfbd77017992ccb8c90441213e191133dadb347 Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com> Reviewed-on: http://git-master/r/97915 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-04-26ASoC: Tegra: Pass snd_soc_card handle in tegra_asoc_utils_initSumit Bhattacharya
Change prototype of tegra_asoc_utils_init to pass snd_soc_card handle. It is needed to move common tegra machine driver codes to tegra_asoc_utils interface. Bug 968814 Change-Id: I98490ffdda51cf7d0b89adadb23c31892183bc0e Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com> Reviewed-on: http://git-master/r/97914 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-04-24asoc: tegra: Add TDM mode supportNitin Pai
Added TDM mode support in I2S driver. Added support functions in AHUB to pass audio/client bits. Added support functions in AHUB to pass audio/client channels. Fixed the stopping of I2S/TDM by clearing the fifo. Bug 948478 Change-Id: I246942b3a07ffcfbcfafbc820208190bd3acc5d4 Signed-off-by: Nitin Pai <npai@nvidia.com> Reviewed-on: http://git-master/r/98456 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-04-19ASoC: resolve compilation time warningsSanjay Singh Rawat
bug 949219 Change-Id: I52969e8dd1a5ed4dc76ac360ec08b0afb18cd4a5 Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com> Reviewed-on: http://git-master/r/92833 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-04-17ASoC: WM8903: fix the resume sequenceJoseph Lo
The bias control must be done after the default register value been restored. Bug 964400 Change-Id: Iefbd96506573d5ea0e1b3123bb34c38e34e75068 Signed-off-by: Joseph Lo <josephl@nvidia.com> Reviewed-on: http://git-master/r/96658 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-04-16asoc: codecs: rt5639/40: Fix false Headset detectionManoj Gangwal
1. Use rt5639/40 internal clk source during jack insert detection. 2. Add delay to 100ms. Bug 955019 Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-on: http://git-master/r/93510 Reviewed-by: Chandler Zhang <chazhang@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com> (cherry picked from commit 4c07fc1b10ac8abbbf167952071e47aa6179a635) Change-Id: I4021232674f5432392dc013ddc76c3bf08b44ed0 Reviewed-on: http://git-master/r/95874 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Manoj Gangwal <mgangwal@nvidia.com> Reviewed-by: Scott Peterson <speterson@nvidia.com>
2012-04-10asoc: wm8753 machine: use common platform dataRavindra Lokhande
use common platform data for machine driver Change-Id: I90e0d2f47aed46da650305d98f6525287adfaf04 Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com> Reviewed-on: http://git-master/r/95101 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Scott Peterson <speterson@nvidia.com>
