This is the 5.3.10 stable release
commit 7b2db65b59c30d58c129d3c8b2101feca686155a upstream.
24 bits is supported in all modes and 16 bit only when the codec is slave
and the DAI is set to RIGHT_J.
Remove the unsupported sample format.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Link: https://lore.kernel.org/r/20190919071652.31724-1-peter.ujfalusi@ti.com
Signed-off-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
[ Upstream commit 95a32c98055f664f9b3f34c41e153d4dcedd0eff ]
All the kcontrol put() functions are currently returning 0 when
successful. This does not go well with alsamixer as it does
not seem to get notified on SND_CTL_EVENT_MASK_VALUE callbacks
when values change for (some of) the sof kcontrols.
This patch fixes that by returning true for volume, switch
and enum type kcontrols when values do change in put().
Signed-off-by: Dragos Tarcatu <dragos_tarcatu@mentor.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Link: https://lore.kernel.org/r/20191018123806.18063-1-pierre-louis.bossart@linux.intel.com
[ Upstream commit e5f0d490fb718254a884453e47fcd48493cd67ea ]
sof_audio_probe misses a check for devm_clk_get and may cause problems.
Add a check for it to fix the bug.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Link: https://lore.kernel.org/r/20191017025044.31474-1-hslester96@gmail.com
[ Upstream commit bcab05880f9306e94531b0009c627421db110a74 ]
This patch adds missing MIX2 path on RX1/2 which take IIR1 and
IIR2 as inputs.
Without this patch sound card fails to intialize with below warning:
ASoC: no sink widget found for RX1 MIX2 INP1
ASoC: Failed to add route IIR1 -> IIR1 -> RX1 MIX2 INP1
ASoC: no sink widget found for RX2 MIX2 INP1
ASoC: Failed to add route IIR1 -> IIR1 -> RX2 MIX2 INP1
ASoC: Failed to add route IIR2 -> IIR2 -> RX1 MIX2 INP1
ASoC: Failed to add route IIR2 -> IIR2 -> RX2 MIX2 INP1
Reported-by: Stephan Gerhold <stephan@gerhold.net>
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Tested-by: Stephan Gerhold <stephan@gerhold.net>
Link: https://lore.kernel.org/r/20191009111944.28069-1-srinivas.kandagatla@linaro.org
[ Upstream commit b1e620e7d32f5aad5353cc3cfc13ed99fea65d3a ]
If rockchip_pcm_platform_register() fails, e.g. upon deferring to wait
for an absent DMA channel, we return without disabling RPM, which makes
subsequent re-probe attempts scream with errors about the unbalanced
enable. Don't do that.
Fixes: ebb75c0bdba2 ("ASoC: rockchip: i2s: Adjust devm usage")
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Link: https://lore.kernel.org/r/bcb12a849a05437fb18372bc7536c649b94bdf07.1570029862.git.robin.murphy@arm.com
[ Upstream commit 3ae7359c0e39f42a96284d6798fc669acff38140 ]
User space always expects to be able to read ALSA controls, so ensure
no kcontrols are generated without an appropriate READ flag. In the case
of a read of such a control zeros will be returned.
Signed-off-by: Stuart Henderson <stuarth@opensource.cirrus.com>
Signed-off-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Link: https://lore.kernel.org/r/20191002084240.21589-1-ckeepax@opensource.cirrus.com
[ Upstream commit 2bdf194e2030fce4f2e91300817338353414ab3b ]
When removing sof module the support_button_press function will oops
because hp_jack pointer is not checked for NULL. So add a check to fix
this.
Signed-off-by: Jaska Uimonen <jaska.uimonen@intel.com>
Link: https://lore.kernel.org/r/20190927201408.925-2-pierre-louis.bossart@linux.intel.com
[ Upstream commit 6ba5041c23c1062d4e8287b2b76a1181538c6df1 ]
When removing sof module the rt5682 jack handler will oops
if jack detection is not disabled. So add remove function,
which disables the jack detection.
Link: https://lore.kernel.org/r/20190927201408.925-5-pierre-louis.bossart@linux.intel.com
[ Upstream commit a315e76fc544f09daf619530a7b2f85865e6b25e ]
Implement NULL handler in set_jack function to disable
irq's.
Link: https://lore.kernel.org/r/20190927201408.925-4-pierre-louis.bossart@linux.intel.com
[ Upstream commit 43b2ab9009b13bfff47fcc1893de9244b39bdd54 ]
There is a known issue on some Intel platforms which causes
pause/release to run into xrun's during capture usecases.
The suggested workaround to address the issue is to
disable the entry of lower power L1 state in the physical
DMI link when there is a capture stream open.
Signed-off-by: Ranjani Sridharan <ranjani.sridharan@linux.intel.com>
Link: https://lore.kernel.org/r/20190927200538.660-14-pierre-louis.bossart@linux.intel.com
[ Upstream commit ff2be865633e6fa523cd2db3b73197d795dec991 ]
FW mailbox offset was not set before use and HDR size was not validated.
Fix this.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Link: https://lore.kernel.org/r/20190927200538.660-12-pierre-louis.bossart@linux.intel.com
[ Upstream commit 4ff5f6439fe69624e8f7d559915e9b54a6477684 ]
The "snd_pcm_substream" handle was not initialized properly
in hda-loader.c for firmware load.
When the HDA DMAs were used to load the firmware,
the interrupts related to firmware load also triggered
calls to snd_sof_pcm_period_elapsed() on a non-existent ALSA
PCM stream.
This caused runtime kernel warnings from
pcm_lib.c:snd_pcm_period_elapsed().
Signed-off-by: Kai Vehmanen <kai.vehmanen@linux.intel.com>
Link: https://lore.kernel.org/r/20190927200538.660-11-pierre-louis.bossart@linux.intel.com
[ Upstream commit 2e305a074061121220a2828f97a57d315cf8efba ]
We are using sof_parse_word_tokens() to parse tokens with
bool/byte/short/word tuple types, here add the missing check, to fix the
parsing failure at byte/bool tuple types.
Signed-off-by: Keyon Jie <yang.jie@linux.intel.com>
Link: https://lore.kernel.org/r/20190927200538.660-3-pierre-louis.bossart@linux.intel.com
[ Upstream commit 798614885a0e1b867ceb0197c30c2d82575c73b0 ]
When we fail to boot the firmware, we encounter a kernel oops in
hda_dsp_get_registers(), which is called conditionally in
hda_dsp_dump() when the sdev_>boot_complete flag is set.
Setting this flag _after_ dumping the data fixes the issue and does
not change the programming flow.
Link: https://lore.kernel.org/r/20190927200538.660-2-pierre-louis.bossart@linux.intel.com
[ Upstream commit 752c938a5c14b8cbf0ed3ffbfa637fb166255c3f ]
The "template.id" variable is an enum and in this context GCC will
treat it as an unsigned int so it can never be less than zero.
Fixes: 8a9782346dcc ("ASoC: topology: Add topology core")
Link: https://lore.kernel.org/r/20190925110624.GR3264@mwanda
[ Upstream commit ca2347190adb5e4eece73a2b16e96e651c46246b ]
In case of WM1811 device there are currently being registered controls
referring to registers not existing on that device.
It has been noticed when getting values of "AIF1ADC2 Volume", "AIF1DAC2
Volume" controls was failing during ALSA state restoring at boot time:
"amixer: Mixer hw:0 load error: Device or resource busy"
Reading some registers through I2C was failing with EBUSY error and
indeed these registers were not available according to the datasheet.
To fix this controls not available on WM1811 are moved to a separate
array and registered only for WM8994 and WM8958.
There are some further differences between WM8994 and WM1811,
e.g. registers 603h, 604h, 605h, which are not covered in this patch.
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Link: https://lore.kernel.org/r/20190920130218.32690-2-s.nawrocki@samsung.com
[ Upstream commit fb629fa2587d0c150792d87e3053664bfc8dc78c ]
Ensure there is no OF node references kept when the driver
is removed/unbound.
Reviewed-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Link: https://lore.kernel.org/r/20190920130218.32690-3-s.nawrocki@samsung.com
commit 22e58665a01006d05f0239621f7d41cacca96cc4 upstream.
Unlike other format-related DAI parameters, rdai->bit_clk_inv flag
is not properly re-initialized when setting format for new stream
processing. The inversion, if requested, is then applied not to default,
but to a previous value, which leads to SCKP bit in SSICR register being
set incorrectly.
Fix this by re-setting the flag to its initial value, determined by format.
Fixes: 1a7889ca8aba3 ("ASoC: rsnd: fixup SND_SOC_DAIFMT_xB_xF behavior")
Cc: Andrew Gabbasov <andrew_gabbasov@mentor.com>
Cc: Jiada Wang <jiada_wang@mentor.com>
Cc: Timo Wischer <twischer@de.adit-jv.com>
Cc: stable@vger.kernel.org # v3.17+
Signed-off-by: Junya Monden <jmonden@jp.adit-jv.com>
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Link: https://lore.kernel.org/r/20191016124255.7442-1-erosca@de.adit-jv.com
This is the 5.3.6 stable release
commit b1f373a11d25fc9a5f7679c9b85799fe09b0dc4a upstream.
VAG power control is improved to fit the manual [1]. This patch fixes as
minimum one bug: if customer muxes Headphone to Line-In right after boot,
the VAG power remains off that leads to poor sound quality from line-in.
I.e. after boot:
- Connect sound source to Line-In jack;
- Connect headphone to HP jack;
- Run following commands:
$ amixer set 'Headphone' 80%
$ amixer set 'Headphone Mux' LINE_IN
Change VAG power on/off control according to the following algorithm:
- turn VAG power ON on the 1st incoming event.
- keep it ON if there is any active VAG consumer (ADC/DAC/HP/Line-In).
- turn VAG power OFF when there is the latest consumer's pre-down event
come.
- always delay after VAG power OFF to avoid pop.
- delay after VAG power ON if the initiative consumer is Line-In, this
prevents pop during line-in muxing.
According to the data sheet [1], to avoid any pops/clicks,
the outputs should be muted during input/output
routing changes.
[1] https://www.nxp.com/docs/en/data-sheet/SGTL5000.pdf
Fixes: 9b34e6cc3bc2 ("ASoC: Add Freescale SGTL5000 codec support")
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Cezary Rojewski <cezary.rojewski@intel.com>
Link: https://lore.kernel.org/r/20190719100524.23300-3-oleksandr.suvorov@toradex.com
commit 810f3b860850148788fc1ed8a6f5f807199fed65 upstream.
If ipc->ops.reply_msg_match is NULL, we may end up using uninitialized
mask value.
reported by smatch:
sound/soc/intel/common/sst-ipc.c:266 sst_ipc_reply_find_msg() error: uninitialized symbol 'mask'.
Signed-off-by: Amadeusz Sławiński <amadeuszx.slawinski@intel.com>
Link: https://lore.kernel.org/r/20190827141712.21015-3-amadeuszx.slawinski@linux.intel.com
Reviewed-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
commit 17d29ff98fd4b70e9ccdac5e95e18a087e2737ef upstream.
For copying from __iomem, we should use __ioread32_copy.
reported by sparse:
sound/soc/intel/skylake/skl-debug.c:437:34: warning: incorrect type in argument 1 (different address spaces)
sound/soc/intel/skylake/skl-debug.c:437:34: expected void [noderef] <asn:2> *to
sound/soc/intel/skylake/skl-debug.c:437:34: got unsigned char *
sound/soc/intel/skylake/skl-debug.c:437:51: warning: incorrect type in argument 2 (different address spaces)
sound/soc/intel/skylake/skl-debug.c:437:51: expected void const *from
sound/soc/intel/skylake/skl-debug.c:437:51: got void [noderef] <asn:2> *[assigned] fw_reg_addr
Link: https://lore.kernel.org/r/20190827141712.21015-2-amadeuszx.slawinski@linux.intel.com
commit 855a06da37a773fd073d51023ac9d07988c87da8 upstream.
oem_table_id is 8 chars long, so we need to limit it, otherwise it
may print some unprintable characters into dmesg.
Link: https://lore.kernel.org/r/20190827141712.21015-7-amadeuszx.slawinski@linux.intel.com
[ Upstream commit 2ec42f3147e1610716f184b02e65d7f493eed925 ]
Some tools use the snd_pcm_info_get_name() to try to identify PCMs or for
other purposes.
Currently it is left empty with the dmaengine-pcm, in this case copy the
pcm->id string as pcm->name.
For example IGT is using this to find the HDMI PCM for testing audio on it.
Reported-by: Arthur She <arthur.she@linaro.org>
Link: https://lore.kernel.org/r/20190906055524.7393-1-peter.ujfalusi@ti.com
[ Upstream commit ca964edf0ddbfec2cb10b3d251d09598e7ca9b13 ]
Apart from Haswell machines, all other devices have their private data
set to snd_soc_acpi_mach instance.
Changes for HSW/ BDW boards introduced with series:
https://patchwork.kernel.org/cover/10782035/
added support for dai_link platform_name adjustments within card probe
routines. These take for granted private_data points to
snd_soc_acpi_mach whereas for Haswell, it's sst_pdata instead. Change
private context of platform_device - representing machine board - to
address this.
Fixes: e87055d732e3 ("ASoC: Intel: haswell: platform name fixup support")
Fixes: 7e40ddcf974a ("ASoC: Intel: bdw-rt5677: platform name fixup support")
Fixes: 2d067b2807f9 ("ASoC: Intel: broadwell: platform name fixup support")
Signed-off-by: Cezary Rojewski <cezary.rojewski@intel.com>
Link: https://lore.kernel.org/r/20190822113616.22702-2-cezary.rojewski@intel.com
Tested-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
[ Upstream commit 696d05225cebffd172008d212657be90e823eac0 ]
The test case is
arecord -Dhw:0 -d 10 -f S16_LE -r 48000 -c 2 temp.wav &
aplay -Dhw:0 -d 30 -f S16_LE -r 48000 -c 2 test.wav
There will be error after end of arecord:
aplay: pcm_write:2051: write error: Input/output error
Capture and Playback work in parallel in master mode, one
substream stops, the other substream is impacted, the
reason is that clock is disabled wrongly.
The clock's reference count is not increased when second
substream starts, the hw_param() function returns in the
beginning because first substream is enabled, then in end
of first substream, the hw_free() disables the clock.
This patch is to move the clock enablement to the place
before checking of the device enablement in hw_param().
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
Link: https://lore.kernel.org/r/1567012817-12625-1-git-send-email-shengjiu.wang@nxp.com
[ Upstream commit f972d02fee2496024cfd6f59021c9d89d54922a6 ]
This patch fix setting table of Headphone mixer volume.
Current code uses 4 ... 7 values but these values are prohibited.
Correct settings are the following:
0000 -12dB
0001 -10.5dB
0010 -9dB
0011 -7.5dB
0100 -6dB
1000 -4.5dB
1001 -3dB
1010 -1.5dB
1011 0dB
Signed-off-by: Katsuhiro Suzuki <katsuhiro@katsuster.net>
Reviewed-by: Daniel Drake <drake@endlessm.com>
Link: https://lore.kernel.org/r/20190826153900.25969-1-katsuhiro@katsuster.net
[ Upstream commit 988b59467b2b14523a266957affbe9eca3e99fc9 ]
If hw_free() gets called after hw_params(), GCLK remains prepared,
preventing further use of it. This patch fixes this by unpreparing the
clock in hw_free() or if hw_params() gets an error.
Fixes: 7e0cdf545a55 ("ASoC: mchp-i2s-mcc: add driver for I2SC Multi-Channel Controller")
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@microchip.com>
Link: https://lore.kernel.org/r/20190820162411.24836-2-codrin.ciubotariu@microchip.com
[ Upstream commit 0f6fc97501b790c971b11b52a654009d21c45238 ]
Since hw_free() can be called multiple times and not just after a stop
trigger command, we should check whether the RX or TX ready interrupt was
truly enabled previously. For this, we assure that the condition of the
wait event is always true, except when RX/TX interrupts are enabled.
Link: https://lore.kernel.org/r/20190820162411.24836-3-codrin.ciubotariu@microchip.com
[ Upstream commit 7df8f9a20196072162d9dc8fe99943f2d35f23d5 ]
The BCLK divider should be calculated using the parameters that actually
make the BCLK rate: the number of channels, the sampling rate and the
sample width.
We've been using the oversample_rate previously because in the former SoCs,
the BCLK's parent is MCLK, which in turn is being used to generate the
oversample rate, so we end up with something like this:
oversample = mclk_rate / sampling_rate
bclk_div = oversample / word_size / channels
So, bclk_div = mclk_rate / sampling_rate / word_size / channels.
And this is actually better, since the oversampling ratio only plays a role
because the MCLK is its parent, not because of what BCLK is supposed to be.
Furthermore, that assumption of MCLK being the parent has been broken on
newer SoCs, so let's use the proper formula, and have the parent rate as an
argument.
Fixes: 7d2993811a1e ("ASoC: sun4i-i2s: Add support for H3")
Fixes: 21faaea1343f ("ASoC: sun4i-i2s: Add support for A83T")
Fixes: 66ecce332538 ("ASoC: sun4i-i2s: Add compatibility with A64 codec I2S")
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
Link: https://lore.kernel.org/r/c3595e3a9788c2ef2dcc30aa3c8c4953bb5cc249.1566242458.git-series.maxime.ripard@bootlin.com
[ Upstream commit c372a35550c8d60f673b20210eea58a06d6d38cb ]
When transitioning to supend state, uniphier_aio_dai_suspend() is called
and asserts reset lines and disables clocks.
However, if there are two or more DAIs, uniphier_aio_dai_suspend() are
called multiple times, and double reset assersion will cause.
This patch defines the counter that has the number of DAIs at first, and
whenever uniphier_aio_dai_suspend() are called, it decrements the
counter. And only if the counter is zero, it asserts reset lines and
disables clocks.
In the same way, uniphier_aio_dai_resume() are called, it increments the
counter after deasserting reset lines and enabling clocks.
Fixes: 139a34200233 ("ASoC: uniphier: add support for UniPhier AIO CPU DAI driver")
Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com>
Link: https://lore.kernel.org/r/1566281764-14059-1-git-send-email-hayashi.kunihiko@socionext.com
[ Upstream commit 804cbf4bb063204ca6c2471baa694548aab02ce3 ]
There is a race between hda codec device removing and the
jack-detecting work, which will lead to a page fault issue as the
latter work is accessing codec device which could be already removed.
Here add the cancellation of jack-detecting work before codecs are actually
removed to avoid the race and fix the issue.
Bug: https://github.com/thesofproject/linux/issues/1067
Link: https://lore.kernel.org/r/20190807145030.26117-1-pierre-louis.bossart@linux.intel.com
[ Upstream commit 06e8f5c842f2dbb232897ba967ea7b422745c271 ]
ADG is using clk_get_rate() under atomic context, thus, we might
have scheduling issue.
To avoid this issue, we need to get/keep clk rate under
non atomic context.
We need to handle ADG as special device at Renesas Sound driver.
From SW point of view, we want to impletent it as
rsnd_mod_ops :: prepare, but it makes code just complicate.
To avoid complicated code/patch, this patch adds new clk_rate[] array,
and keep clk IN rate when rsnd_adg_clk_enable() was called.
Reported-by: Leon Kong <Leon.KONG@cn.bosch.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Tested-by: Leon Kong <Leon.KONG@cn.bosch.com>
Link: https://lore.kernel.org/r/87v9vb0xkp.wl-kuninori.morimoto.gx@renesas.com
[ Upstream commit f1b1b9b136827915624136624ff54aba5890a15b ]
If last_busy value is not set at runtime PM enable, the device will be
suspend immediately after usage counter is 0. Set the last_busy value to
make sure delay is working at first boot up.
Signed-off-by: Pan Xiuli <xiuli.pan@linux.intel.com>
Link: https://lore.kernel.org/r/20190722141402.7194-2-pierre-louis.bossart@linux.intel.com
[ Upstream commit 04c8027764bc82a325d3abc6f39a6a4642a937cb ]
When application goes through SUSPEND/STOP->PREPARE->START
cycle, we should always reprogram the SOF device to start
DMA from a known state so that hw_ptr/appl_ptrs remain valid.
This is expected by ALSA core as it resets the buffer
state as part of prepare (see snd_pcm_do_prepare()).
Fix the issue by forcing reconfiguration of the FW with
STREAM_PCM_PARAMS in prepare(). Use combined logic to handle
prepare and the existing flow to reprogram hw-params after
system suspend.
Without the fix, first call to pcm pointer() will return
an invalid hw_ptr and application may immediately observe XRUN
status, unless "start_threshold" SW parameter is set to maximum
value by the application.
Link: https://lore.kernel.org/r/20190722141402.7194-3-pierre-louis.bossart@linux.intel.com
[ Upstream commit b6319b061ba279577fd7030a9848fbd6a17151e3 ]
If VDDA != VDDIO and any of them is greater than 3.1V, charge pump
source can be assigned automatically [1].
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Link: https://lore.kernel.org/r/20190719100524.23300-7-oleksandr.suvorov@toradex.com
[ Upstream commit 631bc8f0134ae9620d86a96b8c5f9445d91a2dca ]
To enable "zero cross detect" for ADC/HP, change
HP_ZCD_EN/ADC_ZCD_EN bits only instead of writing the whole
CHIP_ANA_CTRL register.
Link: https://lore.kernel.org/r/20190719100524.23300-6-oleksandr.suvorov@toradex.com
[ Upstream commit b7e814deae33eb30f8f8c6528e8e69b107978d88 ]
Both the supplies and reset GPIO might need a probe deferral for the
resource to be available. Don't print a error message in that case, as
it is a normal operating condition.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Andrew F. Davis <afd@ti.com>
Link: https://lore.kernel.org/r/20190719143637.2018-1-l.stach@pengutronix.de
[ Upstream commit ef9bec27485fefb6b93168fea73fda0dc9638046 ]
snd_hdac_ext_bus_device_exit() has been recently modified
to no longer free the hdac device. SOF allocates memory for
hdac_device and hda_hda_priv with kzalloc. Make them
device-managed instead so that they will be freed when the
SOF driver is unloaded.
Because of the above change, hda_codec is device-managed and
it will be freed when the ASoC device is removed. Freeing
the codec in snd_hda_codec_dev_release() leads to kernel
panic while unloading and reloading the ASoC driver. So,
avoid freeing the hda_codec for ASoC driver. This is done in
the same patch to avoid bisect failure.
Signed-off-by: Libin Yang <libin.yang@intel.com>
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Link: https://lore.kernel.org/r/20190626070450.7229-1-ranjani.sridharan@linux.intel.com
Deferred probes shouldn't cause error messages in the boot log. Avoid
printing with dev_err() in case EPROBE_DEFER is the return value.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Lots of small fixes at this time since we've received the ASoC fix
batch now.
- Some coverage in ASoC core mostly for minor issues like NULL checks
for DPCM and proper error handling in DAI instantiation
- A collection of small device-specific changes in various ASoC codec
and platform drivers
- OF-tree refcount fixes in a few ASoC drivers
- Fixes of memory leaks in the error paths of various ASoC / ALSA
drivers
- A workaround for a long-standing issue on AMD HD-audio device
- Updates of MAINTAINERS, mail addresses, file permission fixups"
* tag 'sound-5.3-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (38 commits)
ALSA: firewire: fix a memory leak bug
sound: fix a memory leak bug
ALSA: hda - Workaround for crackled sound on AMD controller (1022:1457)
ALSA: hiface: fix multiple memory leak bugs
ALSA: hda - Don't override global PCM hw info flag
ALSA: usb-audio: fix a memory leak bug
ASoC: max98373: Remove executable bits
ASoC: amd: acp3x: use dma address for acp3x dma driver
ASoC: amd: acp3x: use dma_ops of parent device for acp3x dma driver
ASoC: max98373: add 88200 and 96000 sampling rate support
ASoC: sun4i-i2s: Incorrect SR and WSS computation
MAINTAINERS: Update Intel ASoC drivers maintainers
ASoC: ti: davinci-mcasp: Correct slot_width posed constraint
ASoC: rockchip: Fix mono capture
ASoC: Intel: Fix some acpi vs apci typo in somme comments
ASoC: ti: davinci-mcasp: Fix clk PDIR handling for i2s master mode
ASoC: Fail card instantiation if DAI format setup fails
ASoC: SOF: Intel: hda: remove misleading error trace from IRQ thread
ASoC: qcom: apq8016_sbc: Fix oops with multiple DAI links
ASoC: dapm: fix a memory leak bug
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v5.3
Incremental fix removing executable bits added in a prior patch
accidentally.
A relatively large batch of mostly unremarkable fixes here, a couple of
small core fixes for fairly obscure issues, more comment/email updates
with no code impact than usual and a bunch of small driver fixes.
The support for new sample rates in the max98373 driver is a fix for the
fact that the driver declared support for those rates but would in fact
return an error if these rates were selected.
We shouldn't assume CPU physical address we get from page_to_phys()
is same as DMA address we get from dma_alloc_coherent(). On x86_64,
we won't run into any problem with the assumption when dma_ops is
nommu_dma_ops. However, DMA address is IOVA when IOMMU is enabled.
And it's most likely different from CPU physical address when AMD
IOMMU is not in passthrough mode.
This patch fixes page faults when IOMMU is enabled.
Signed-off-by: Vijendar Mukunda <vijendar.mukunda@amd.com>
Link: https://lore.kernel.org/r/1564753899-17124-2-git-send-email-Vijendar.Mukunda@amd.com
AMD platform device acp3x_rv_i2s created by parent PCI device
driver. Pass struct device of the parent to
snd_pcm_lib_preallocate_pages() so dma_alloc_coherent() can use
correct dma_ops. Otherwise, it will use default dma_ops which
is nommu_dma_ops on x86_64 even when IOMMU is enabled and
set to non passthrough mode.
Link: https://lore.kernel.org/r/1564753899-17124-1-git-send-email-Vijendar.Mukunda@amd.com
88200 and 96000 sampling rate was not enabled on driver, so can't be played.
The error information:
max98373 3-0031:rate 96000 not supported
max98373 3-0031:ASoC: can't set max98373-aif1 hw params: -22
Signed-off-by: fengchunguo <chunguo.feng@amlogic.com>
Link: https://lore.kernel.org/r/20190731074156.5620-1-chunguo.feng@amlogic.com
The A64 audio codec uses the original I2S block but the SR and
WSS computation currently assigned is for the newer block.
Fixes: 619c15f7fac9 (ASoC: sun4i-i2s: Change SR and WSS computation)
Signed-off-by: Marcus Cooper <codekipper@gmail.com>
Link: https://lore.kernel.org/r/20190729152130.27955-1-codekipper@gmail.com
The slot_width is a property for the bus while the constraint for
SNDRV_PCM_HW_PARAM_SAMPLE_BITS is for the in memory format.
Applying slot_width constraint to sample_bits works most of the time, but
it will blacklist valid formats in some cases.
With slot_width 24 we can support S24_3LE and S24_LE formats as they both
look the same on the bus, but a a 24 constraint on sample_bits would not
allow S24_LE as it is stored in 32bits in memory.
Implement a simple hw_rule function to allow all formats which require less
or equal number of bits on the bus as slot_width (if configured).
Link: https://lore.kernel.org/r/20190726064244.3762-2-peter.ujfalusi@ti.com
