path: root/sound/sparc
2007-05-11[ALSA] Fix compilation error in sparc/cs4231.cTakashi Iwai
Removed the unnecessary line I forgot in the last clean-up patch wrt snd_pcm_group_for_each_entry(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-26[SPARC/64] constify of_get_property return: soundStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-09[ALSA] sparc dbri comment fixKrzysztof Helt
This is a comment fix to avoid misleading about locking in the dbri_cmdsend. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-01-03[SOUND] Sparc CS4231: Use 64 for period_bytes_minDavid S. Miller
This matches what the ISA cs4231 driver uses. Tested by Georg Chini. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-03[SOUND] Sparc CS4231: Fix IRQ return value and initialization.Georg Chini
SBUS: Change IRQ-handler return value from 0 to IRQ_HANDLED and fix some initialisation problems. Change period_bytes_min from 4096 to 256 to allow driver to work with low latency (VOIP) applications. Hope this does not break EBUS. Signed-off-by: Georg Chini <georg.chini@triaton-webhosting.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-29[PATCH] sound/sparc/dbri: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[SOUND] sparc/amd7930: Use __devinit and __devinitdata as needed.David S. Miller
Fixes section-mismatch errors. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-24[PATCH] NULL noise removalAl Viro
2006-09-23[ALSA] sparc dbri: SMP fixesKrzysztof Helt
The dbri driver hangs when used in kernel compiled with SMP support due to inproper locking. The patch fixes it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: OSS layer fixKrzysztof Helt
This patch removes setting of incorrect stop_threshold value inside the driver. After the change, playback through the OSS layer works correctly. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] dbri sparc: fixes TS leakKrzysztof Helt
This patch fixes time slot leak in the dbri driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: recording is backKrzysztof Helt
This patch fixes sound recording after the driver convertion to ring buffered version. It also contains small clean ups to the driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: hardware constrains addedKrzysztof Helt
This patch adds ALSA hardware constrains so stereo is possible only with 16-bit format. It contains small cleanups to ring buffered code as well. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: ring buffered versionKrzysztof Helt
It is a complete rework of low level layer to work on ring buffers for comands and data descriptors. This removes annoying noise due to delay in data buffer switching. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: simplifed linking time slot functionKrzysztof Helt
A simplified routines to link and unlink time slots. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: fixed setting of burst size after resetKrzysztof Helt
A proper way to set DBRI's burst size. The size must be set after each chip reset. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: more driver cleanupKrzysztof Helt
A general clean up and redudant code removal. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of dri_desc structKrzysztof Helt
The structure is in big part redudant. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of redudant volatile keywordsKrzysztof Helt
It removes redudant volatile keywords. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of unused struct membersKrzysztof Helt
It removes unused or rarely used members of defined structures. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri removal of DBRI_NO_INTSKrzysztof Helt
This patch removes define DBR_NO_INTS and all code related to handling more than one dbri irq statuses block. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] dbri driver cleanupKrzysztof Helt
This is a small clean up of the dbri driver for sparc machines. It contains also a fix to DBRI interrupt queue initialization. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-03[PATCH] sparc: resource warning fixAndrew Morton
sound/sparc/amd7930.c: In function 'amd7930_attach_common': sound/sparc/amd7930.c:1040: warning: format '%08lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' sound/sparc/cs4231.c:2043: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' sound/sparc/dbri.c: In function 'dbri_attach': sound/sparc/dbri.c:2650: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30typo fixes: specfic -> specificAdrian Bunk
2006-06-27[PATCH] 64bit resource: fix up printks for resources in sound driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[SOUND] sparc: Port amd7930 to new SBUS device layer.David S. Miller
2006-06-23[SPARC64]: Use in-kernel PROM tree for EBUS and ISA.David S. Miller
2006-06-22[ALSA] Remove zero-initialization of static variablesTakashi Iwai
Removed zero-initializations of static variables. A tiny optimization. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-24BUG_ON() Conversion in sound/sparc/cs4231.cEric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-22[ALSA] semaphore -> mutex (Archs, misc buses)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-17[SOUND]: sparc/cs4231: Fix some typos which wrecked the build.David S. Miller
2006-01-03[ALSA] Remove xxx_t typedefs: SPARC CS4231Takashi Iwai
Remove xxx_t typedefs from the SPARC CS4231 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] dbri - Don't return errors without CONFIG_PROC_FSTakashi Iwai
Modules: SPARC DBRI driver Don't return errors if the proc file can't be created (for the case without CONFIG_PROC_FS). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove snd_card_generic_dev()Takashi Iwai
Remove the obsolete snd_card_generic_dev(). CONFIG_SND_GENERIC_DRIVER is also removed from Kconfig. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: SPARC DBRITakashi Iwai
Modules: SPARC DBRI driver Remove xxx_t typedefs from the SPARC DBRI driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: SPARC AMD7930Takashi Iwai
Modules: SPARC AMD7930 driver Remove xxx_t typedefs from the SPARC AMD7930 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-12-22[SPARC]: introduce a SPARC Kconfig symbolAdrian Bunk
Introduce a Kconfig symbol SPARC that is defined on both the sparc and sparc64 architectures. This symbol makes some dependencies more readable. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[SPARC]: More abstractions and cleanups of dma handling in cs4231.Georg Chini
From: Georg Chini <georg.chini@triaton-webhosting.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[SPARC]: Make SBUS dma code similar to EBUSGeorg Chini
From: Georg Chini <georg.chini@triaton-webhosting.com> Introduce some sbus_dma routines similar to the ebus_dma stuff to make the code look nearly the same for both cases. Thanks to Christopher for testing. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-04[ALSA] Remove obsolete chip_tTakashi Iwai
Modules: Documentation,MIPS AU1x00 driver,PPC Beep,SPARC DBRI driver Removed the use of chip_t, which was obsoleted. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-21[SPARC] cs4231: Fix SBUS support in this driver.Christopher Zimmermann
From: Christopher Zimmermann <madroach@zakweb.de> This patch enables SBus support for the cs4231 sound driver. It is tested on an Ultra2. Capture and playback both work. I experienced lags and crashes using certain threaded players like ogg123 and mp3blaster, while the former is lagging far more. This behavior may be specific to SMP systems. It is reproducable using the dummy sound card driver. Sox works flawlessly. Setting up the calculation of ptr in snd_cs4231_playback_pointer was a bit strange. I got it to work by not incrementing the [pc]_periods_sent counter when starting DMA the first time in cs4231_dma_trigger. Therefore this dummy thing. [ I did some minor cleanups -DaveM ] Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-12[ALSA] Several fixes for the Sun DBRI driverMartin Habets
SPARC DBRI driver This patch contains the following fixes to the Alsa DBRI driver: - Remove 2.6.13 build warning on the prom_getproperty() call. - Rework command synchronization: send a sequence number with D_WAIT, and check it in the completion interrupt. Move synchronization delays from _cmdsend() to _cmdlock() allowing the CPU to do other usefull things while the DBRI is processing the commands. - Fix first argument of printk() calls. - Enable burst transfers for DBRI. Original 2.4 patch from Krzysztof Helt - Make dbri_debug module parameter writable from sysfs. Remove obsolete write access to the /proc debug file. - Replace udelay() with msleep_interruptible() where possible. - Update documentation comments. Signed-off-by: Martin Habets <errandir_news@mph.eclipse.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
